THINKYA K10 Battery-Powered CD Player
The Thinkya K10 is a compact CD player integrating digital conversion and amplification, designed to ensure stable disc playback while expanding usage to dematerialized sources. It leverages optimized read mechanics with anti-jitter system, coupled with hybrid connectivity including optical output and bidirectional Bluetooth 5.1, thereby guaranteeing coherent signal transmission in both wired and wireless modes.
Reference : 22240
79,90 €tax incl.
66,58 € tax excl.
Shipping date: 17-11-2026.
Thinkya K10 Battery-Powered CD Player Bluetooth 5.1
Thinkya K10 : Front view
Intended for domestic or mobile use, it combines CD playback, USB playback and integrated amplification, enabling autonomous listening or integration into an existing Hi-Fi chain. This approach enables it to serve as a central versatile audio source, while maintaining stable and exploitable restitution across different system types.
Thinkya K10: Connectivity and extended playback
The Thinkya K10 integrates versatile connectivity articulated around a Toslink optical output, enabling isolated digital transmission to an external DAC, while the 3.5 mm jack headphone output authorizes direct listening. This approach extends to an AUX input in the same format, facilitating integration of analogue sources, while USB playback ensures support for WAV, APE, AAC and WMA formats, thereby extending usage beyond CD media. Additionally, bidirectional Bluetooth 5.1 allows both reception and emission of audio signal, enabling flexible use with wireless peripherals.
Thinkya K10 : Rear panel
Thinkya K10: Integrated equalization
The embedded equalization system allows adjustment of frequency response based on audio content and listening preferences, acting directly on tonal balance. This real-time adaptation translates to modulable restitution, allowing compensation for recording characteristics or associated listening devices, while maintaining overall signal coherence.
Thinkya K10: Optimized read mechanism
The read head rests on an architecture designed to limit mechanical disturbances, integrating an anti-jitter system that stabilizes disc playback to reduce tracking errors. This design extends to anti-reflection treatment that improves optical beam read precision, thereby ensuring more stable restitution and limiting artifacts related to surface irregularities.
Thinkya K10 : Read head
Thinkya K10: Integrated sound restitution
The K10 integrates a speaker configuration combining stereo restitution with two dedicated bass-frequency transducers, allowing extended bass response while preserving channel separation. This architecture delivers 2 + 2 W power at a distortion rate below 0.1%, ensuring coherent near-field listening without requiring external systems.
Thinkya K10: 2600 mAh battery
The unit embeds a 2600 mAh battery enabling up to 6 hours of continuous playback, authorizing independent use from AC power. This autonomy translates to usage flexibility, whether for portable operation or configurations where access to a power source is limited.
Thinkya K10 : Battery
Product typeCD player
Inputs1x 3.5mm jack
1x USB-A
CD
Bluetooth
Outputs1x Toslink optical
1x 3.5mm jack headphone
Bluetooth
Bluetooth version5.1
Supported formatsCD / CD-DA / CD-R / CD-RW / MP3 / WAV / WMA / AAC
Signal-to-noise ratio (SNR)≥80dB
Frequency response20Hz-20kHz
Output power2x 2W
Bit rate320Kbps
Chassis materialWood
Battery2600mAh
Runtime6h
Charging time3h
Charging portUSB-C
Supply voltage5V 2A
Weight626g
Dimensions195 x 160 x 48.5mm
ColorWood
Package1x Thinkya K10
1x Remote control
THINKYA K10 Battery-Powered CD Player Bluetooth 5.1
The Thinkya K10 is a compact CD player integrating digital conversion and amplification, designed to ensure stable disc playback while expanding...
