Connector
Impedance (Ω)
Max cable diameter (mm)
Max sampling rate
DAC / ADC Chip
Rated current (A)
Connectic
Length
0 m - 5 m
Section (mm²)
0 mm - 50 mm
Conductors material (Cable)
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
1 - 19
Input
Output
Mounting type
Accepts Banana Plugs
Max panel thickness
mm
mm
Remote Control
Networking
Color
Insulation material
Connectors and adapters
Vincent B.
Bof
Shigeo I.
Couldn't be more satisfied
A flawless power amplifier. The extension of the sound and the precision of left-right imaging are excellent—especially in solo...
Shigeo I.
outstanding cost-performance!
Purchased together with the Audiophonics LPA-S450ET. Since the power amplifier has a balanced architecture, when used with...
We offer a wide range of products in terms of connectors and adapters. You will of course discover all the connectors intended for Audio, such as RCA connectors, XLR connectors, or speaker terminals.
On the adapter side, you will certainly find the adapter you are looking for to solve a problem encountered when connecting to your audio system: Jack adapter, HDMI adapter, USB adapter, and many others.
  • Adapters
    Adapters
    Find on our website our complete range of adapters for all types of connections: RCA, Jack, XLR, Toslink Optics, Antenna / Sat, HDMI, etc...
    Whatever the problem you are facing in your installation, you will find the solution here among all our adapters.
  • Connectors
    Connectors
    Whatever the intention and the desired result for your HiFi audio installation, find our complete range of connectors of all kinds: USB, DC Jack, DIN, XLR, RCA, Banana, Fork, Sector, Antenna / Sat / BNC, Toslink Optics, etc...
    For all audio realizations or DIY assemblies, you will need high quality connectors to fully meet your expectations.
  • Connectors for PCB
    Connectors for PCB
