USTARS AUDIO BD93 DAC Module
The Ustars Audio BD93 is a DIY DAC module based on a dual AK4493SEQ architecture, designed for high-resolution digital-to-analogue conversion. It supports streams up to 32-bit 768kHz as well as DSD512, relying on a dual-mono topology to isolate each channel and limit crosstalk, resulting in more stable reproduction and improved retrieval of fine detail.
Reference : 22144
79,00 €tax incl.
65,83 € tax excl.
USTARS AUDIO BD93 DAC Module 2xAK4493SEQ 32bit 768kHz DSD512
USTARS AUDIO BD93 : Front view
This approach extends to the integration of a dedicated MCU controller, enabling precise exploitation of the converters' capabilities while providing access to advanced settings such as multiple digital filters and DSD NOS mode, allowing the conversion behaviour to be adapted according to listening preferences or system constraints.
Ustars Audio BD93: Dual AK4493SEQ DAC
The use of two AK4493SEQ chips, each dedicated to a single channel, ensures effective channel separation, reducing interference and enabling cleaner, more detailed reproduction. This architecture promotes a balanced output with coherent tonal continuity, while the internal processing ensures fast and accurate conversion, contributing to a sense of transparency and fluidity.
Beyond conversion itself, advanced digital filter management — including multiple roll-off profiles and a low-dispersion mode — allows the impulse response and bandwidth to be adjusted, providing a practical means of optimisation depending on the content and the associated signal chain.
Ustars Audio BD93: I2S Interface
The BD93 relies on an I2S interface compatible with Amanero USB modules, enabling direct ribbon cable integration without additional adaptation, while compatibility with digital cards in interconnect mode extends control and synchronisation possibilities. This modularity allows a complete system to be built by combining power supply, digital interface and control, while maintaining a scalable architecture.
Ustars Audio BD93: Output Stages and Power Supply
The module provides dual analogue outputs with a level of 2.1Vrms on RCA and 4.2Vrms on XLR, relying on a balanced topology to ensure broad compatibility with preamplifiers and amplifiers, while maintaining a signal level suited to Hi-Fi standards.
The split power supply — +5V for the digital section and ±12 to ±15V for the analogue stage — isolates the critical stages, helping to reduce interference and stabilise overall operation.
USTARS AUDIO BD93 : Diagram
Product typeDAC module
InputI2S
Outputs1x Stereo RCA
1x Stereo XLR
DAC2x AK4493SEQ
Supported sample ratesPCM up to 32bit 768kHz
DSD up to DSD512
Output levelRCA : 2.1Vrms
XLR : 4.2Vrms
I2S Input Interface
DA (DATA / DSD_R)PCM data input / DSD right channel data input
BC (BCK / DSD_BCK)PCM bit clock input / DSD clock input
LR (LRCK / DSD_L)PCM channel clock input / DSD left channel data input
MC (MCLK)PCM master clock input
DE (DSD_ON)DSD selection input — 1: DSD input / 0: PCM input
MU (MUTE)Mute input — 1: mute / 0: normal operation
SC (SCL)Communication with B18 board
SD (SDA)Communication with B18 board
G (GND)Ground
NCUnconnected pin (leave open)
PCM Filter Configuration (0: connected / X: open)
J2 = X, J3 = 0, J4 = 0Sharp roll-off filter with short delay (default)
J2 = X, J3 = X, J4 = XSharp roll-off filter with short delay
J2 = 0, J3 = X, J4 = XSlow roll-off filter with short delay
J2 = X, J3 = 0, J4 = XSharp roll-off filter
J2 = 0, J3 = 0, J4 = XSlow roll-off filter
J2 = X, J3 = X, J4 = 0Super Slow filter (very slow roll-off)
J2 = 0, J3 = X, J4 = 0Low-dispersion short-delay filter
J2 = 0, J3 = 0, J4 = 0Interconnect mode (B18 board only)
Interconnect Communication Configuration (0: connected / X: open)
J8 = X, J9 = XStandalone mode (standard B18 connection or other inputs)
J8 = 0, J9 = 0Interconnect mode (dedicated B18 board only)
Manual DSD Mode (0: connected / X: open)
J5 = XPCM mode (default)
J5 = 0DSD mode
DSD NOS Mode (0: connected / X: open)
J6 = XNormal mode (default)
J6 = 0DSD NOS mode / volume bypass
DSD Filter (0: connected / X: open)
J7 = XDSD_Filter1 (fc = 39kHz, DSD64 mode) (default)
J7 = 0DSD_Filter2 (fc = 76kHz, DSD64 mode)
DSD Channel Inversion (0: connected / X: open)
J1 = XLRCK → DSD_L (left channel via LRCK)
DATA → DSD_R (right channel via DATA)
J1 = 0LRCK → DSD_R (right channel via LRCK)
DATA → DSD_L (left channel via DATA)
Power supply voltage+5V DC
±12V DC
Dimensions100 x 100mm
PackageSold individually
InputI2S
DAC / ADC ChipAK4493EQ
Max sampling rate768kHz
Max sampling rateDSD512
The Ustars Audio BD93 is a DIY DAC module based on a dual AK4493SEQ architecture, designed for high-resolution digital-to-analogue conversion. It...
