AUDALYTIC DR70 DAC Silver
The Audalytic DR70 is a high-end DAC designed for demanding audiophiles, combining discrete R2R architecture, and extensive compatibility with high-resolution audio formats. Developed by Gustard, this model stands out for its R2R module, native 1-bit DSD converter, and dedicated FPGA, all synchronized by a CK-01 femtosecond oscillator for exceptionally precise and musical sound reproduction.
Reference : 22165
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 24-11-2026.
Audalytic DR70 R2R DAC Bluetooth 5.0 32bit 768kHz DSD512 Silver
Audalytic DR70
The Audalytic DR70 is a high-end DAC designed for demanding audiophiles, combining a discrete R2R architecture with extended compatibility with high-resolution audio formats. Developed by Gustard, this model stands out with its R2R module, its native 1bit DSD converter and its dedicated FPGA, all synchronized by a CK-01 femtosecond oscillator for sound reproduction of exceptional precision and musicality. Whether listening to music via USB, coaxial, optical or Bluetooth 5.0, the DR70 establishes itself as a versatile and high-performance solution, suitable for home audio systems or high-end headphones.
Audalytic DR70: Main features
Audalytic DR70: R2R module
Audalytic DR70: Discrete R2R architecture and native DSD conversion
The core of the DR70 is based on a discrete R2R module, providing PCM conversion of remarkable purity, without digital artifacts. For DSD formats, the DR70 integrates a native 1bit converter, capable of handling DSD64 to DSD512 streams without intermediate conversion to PCM, thus preserving the integrity of the original signal. This approach ensures a natural timbre, extended dynamics and resolution of micro-details, even on the most demanding recordings.
Audalytic DR70: FPGA
Audalytic DR70: FPGA & Clock
The custom FPGA of the DR70 manages signal processing logic, clock management and seamless switching between PCM and DSD modes, while the CK-01 femtosecond oscillator reduces jitter to an imperceptible level, improving stereo imaging accuracy and soundstage depth.
Audalytic DR70: Extended Connectivity and Integrated Streaming
The DR70 easily connects to all your sources:
  • USB (XMOS XU316): Supports PCM streams up to 32bit 768kHz and native DSD up to DSD512, as well as DoP64 to DoP256.
  • Coaxial / Optical: Compatible with PCM streams up to 24bit 192kHz and DSD DoP64.
  • Bluetooth 5.0: Integrates LDAC (24bit / 96kHz), aptX, AAC and SBC codecs for high-resolution wireless listening.
This versatility allows integration of the DR70 into various configurations, whether a wired system or a wireless setup.
Audalytic DR70: Connectivity diagram
1Unbalanced RCA output (left channel)
2Coaxial input
3Bluetooth antenna
412-18V DC power connector
5110-220V AC power connector
6Balanced XLR output (right channel)
7Balanced XLR output (left channel)
8Unbalanced RCA output (right channel)
9Coaxial input
10Optical Toslink input
11USB-C input
12Fuse
Audalytic DR70: Analog outputs and Power supply
The DR70 offers simultaneous RCA (2Vrms) and XLR (4Vrms) outputs, both at fixed level, for optimal compatibility with preamplifiers or active speakers. The output impedance is around 100Ω, ensuring a stable connection with most equipment.
The low-noise internal power supply is designed to minimize interference, but the DR70 also accepts an external 12-18V DC power supply for users wishing to further optimize performance.
Audalytic DR70: Output stage and power supply circuits
Audalytic DR70: Design and Ergonomics
The anodized aluminum chassis of the DR70 combines robustness and elegance. An LCD screen with adjustable brightness and an infrared remote control facilitate everyday use. The DR70 is compact and lightweight, integrating discreetly into any audio environment.
Technical specifications
Product typeDAC
InputsBluetooth 5.0
1x USB-C
2x Coaxial
1x Optical Toslink
Outputs1x Single-ended stereo RCA output
1x Balanced stereo XLR output
Supported sample ratesUSB: PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DoP256
Coaxial / Optical: PCM up to 24bit 192kHz, DSD DoP64
Supported Bluetooth codecsSBC, AAC, aptX, LDAC
USB compatibilityWindows 7/8/10/11
macOS
Linux
Frequency response20Hz-20kHz (±0.2dB, OS mode)
Dynamic range> 111dB
Crosstalk-125dB @ 1kHz
THD+N≤ 0.004% @ 1kHz
IMD~ 0.009% @ -2dBFS
Output levelRCA: 2Vrms
XLR: 4Vrms
Output impedance100Ω
Power supplyAC 115V / 230V, 50/60Hz
Power consumption10W
Dimensions (excluding feet and connectors)220 x 170 x 50mm
Weight1.5kg
ColorSilver
Package1x Audalytic DR70
1x Power cable
Audalytic DR70: Measurements
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Remote ControlYes
AUDALYTIC DR70 R2R DAC Bluetooth 5.0 32bit 768kHz DSD512 Silver
The Audalytic DR70 is a high-end DAC designed for demanding audiophiles, combining discrete R2R architecture, and extensive compatibility with...
