AUDIO-GD HE-27 DAC Preamplifier Headphone Amplifier Black
The AUDIO-GD HE-27 is a high-end DAC / preamplifier and headphone amplifier featuring a fully discrete and balanced architecture along with proprietary ACSS technology without feedback. It incorporates four PCM1704UK R-2R conversion chips, renowned for their natural sound reproduction, combined with an Amanero 384 asynchronous USB interface with FPGA-synchronized clocking, supporting PCM streams up to 32bit / 384kHz.
By buying this product you get 289 loyalty points
Reference : 22098
2 899,00 €tax incl.
2 415,83 € tax excl.
Shipping date: 12-11-2026.
Audio-GD HE-27 DAC Preamplifier Headphone Amplifier 4x PCM1704UK 32bit 384kHz Black
AUDIO-GD HE-27
The Audio-GD HE-27 is a high-end DAC / preamplifier and headphone amplifier featuring a fully discrete and balanced architecture along with proprietary ACSS technology without feedback. It incorporates four PCM1704UK R-2R conversion chips, renowned for their natural sound reproduction, combined with an Amanero 384 asynchronous USB interface with FPGA-synchronized clocking, supporting PCM streams up to 32bit / 384kHz. Two ultra-high precision Accusilicon TCXO oscillators operating at 90MHz and 98MHz synchronize all sampling rates without relying on PLL oversampling. All digital circuits and digital inputs are fully isolated from the analog stages to minimize interference. The HE-27 also features an IN2 coaxial input that can be reconfigured via firmware update into a 10MHz / 75Ω external clock input.
Its fully balanced preamplifier and headphone amplifier section operates in pure Class A and is based on four no-feedback output stages composed of eight transistors, each capable of handling 15A / 150W. The internal power supply relies on four R-Core transformers delivering a total of 160W and a filtering capacitance of 50,000µF. The unit delivers up to 10W into 25Ω and 1000mW into 300Ω, allowing it to drive the majority of headphones available on the market. Volume control is achieved through relay-controlled I/V attenuation using 0.05% precision resistors, offering 100 adjustment steps and perfect channel matching across all four channels.
Audio-GD HE-27: PCM1704UK R-2R conversion and FPGA jitter elimination
The HE-27 employs four PCM1704UK converters, regarded as a benchmark among R-2R architectures for their exceptionally natural and analog-like sound reproduction. Incoming audio data is first stored in memory and then entirely reclocked by the FPGA using the internal Accusilicon oscillators, thereby eliminating the influence of jitter originating from the source. This asynchronous architecture ensures extremely accurate synchronization and more realistic sound reproduction without depending on the quality of the incoming signal clock. A 10MHz external clock input is also available after a firmware update for integration into reference-grade systems.
AUDIO-GD HE-27: PCM1704UK R-2R conversion and FPGA jitter elimination
AUDIO-GD HE-27: ACSS no-feedback technology and Class A amplification
Audio-GD HE-27: ACSS no-feedback technology and Class A amplification
The preamplifier and headphone amplifier section takes advantage of proprietary ACSS (Audio-GD Current Signal System) technology, a fully discrete current transmission architecture without global feedback. The gain and output stages operate entirely in Class A, with an exceptionally short signal path to minimize sonic coloration. The four output channels employ eight power transistors and can deliver up to 10W into 25Ω, providing substantial current reserves to drive both low-impedance and high-impedance headphones.
Audio-GD HE-27: Analog regenerative power supply
One of the HE-27's key features lies in its analog regenerative power supply, comparable to an integrated electrical generator. It recreates a pure 50Hz sine wave using dedicated analog circuits powered by Class A parallel regulators. This technology significantly reduces mains interference and improves transparency as well as channel separation.
AUDIO-GD HE-27: Analog regenerative power supply
Audio-GD HE-27: I/V volume control
The volume control adopts an original design based on passive I/V conversion controlled by relays and 0.05% precision resistors, ensuring perfectly linear frequency response without any loss of detail or channel imbalance, regardless of the volume setting.
AUDIO-GD HE-27: I/V volume control
Overview of the Audio-GD HE-27
Overview of the AUDIO-GD HE-27
1ON-OFF
2Input selection
3Display
4Volume control
56.35mm headphone output
64-pin XLR headphone output
7Right/Left analog outputs (XLR, RCA, ACSS)
8I2S input via HDMI
9Toslink optical input
10USB-B input
11AES/EBU input
12Coaxial input / 10MHz clock input
13Coaxial input
14Firmware update port
15Balanced stereo XLR input
16AC power input
Product typeDAC / Preamplifier / Headphone Amplifier
Chipset4x PCM1704UK
Inputs1x USB-B
1x I2S via HDMI
1x Toslink optical
1x Coaxial / 10MHz clock
1x Coaxial
1x Balanced stereo XLR
Outputs1x Stereo RCA
1x ACSS
1x 6.35mm headphone output
1x XLR headphone output
SNR>120dB
THD+N<0.03%
GainL mode: +13dB
H mode: +26dB
Channel balance<0.05dB
Frequency response20Hz - 20kHz (< -0.25dB)
20Hz - 150kHz (< -3dB)
Output levelVariable output (Preamp): 18V max (XLR) / 9V max (RCA)
Fixed output (DAC): 2-5V (XLR) / 1-2.5V (RCA)
4-pin XLR headphone output power25 ohm: 10W
40 ohm: 6500mW
100 ohm: 2500mW
300 ohm: 850mW
6.35mm headphone output power25 ohm: 2800mW
40 ohm: 1800mW
100 ohm: 750mW
300 ohm: 250mW
Digital input sensitivity75-ohm coaxial: 0.4-1Vp-p
Toslink: 19dBm
XLR input impedance94kOhm
Compatible OS (USB)Windows, OSX, Linux, iOS
Supported sampling ratesUSB and I2S via HDMI: 32bit 384kHz DSD512
AES/EBU and coaxial: 24bit 192kHz
Toslink: 24bit 96kHz
Power supply220-240V AC 50/60Hz
Power consumption42W
Dimensions430 x 445 x 80mm
Package contents1x Audio-GD HE-27
1x USB cable
1x Remote control
1x Power cable
InputI2S via HDMI
OutputACSS
OutputJack 6.35mm
DAC / ADC ChipPCM1704UK
Max sampling rateDSD512
Max sampling rate384kHz
ClassClass A / AB
Remote ControlYes
AUDIO-GD HE-27 DAC Preamplifier Headphone Amplifier 4x PCM1704UK 32bit 384kHz Black
The AUDIO-GD HE-27 is a high-end DAC / preamplifier and headphone amplifier featuring a fully discrete and balanced architecture along with...
