DOUK AUDIO Q100 DAC
The Douk Audio Q100 is a high-resolution desktop DAC designed for digital-to-analogue conversion, relying on a dissociated architecture combining the AK4191 and AK4499EX to isolate digital processing from analogue rendering and minimise internal interference. It supports streams up to PCM 768kHz / 32-bit and DSD512, enabling wide-bandwidth content to be reproduced with the temporal precision required by high-definition sources.
By buying this product you get 54 loyalty points
Reference : 22156
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 24-11-2026.
Douk Audio Q100 DAC AKM AK4191+AK4499EX XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512
Douk Audio Q100 : Front view
Douk Audio Q100: AK4191 + AK4499EX DAC
The Douk Audio Q100 is a desktop DAC designed for high-definition digital stream conversion, relying on a dual-stage architecture pairing an AK4191 modulator with an AK4499EX converter to isolate digital processing from analogue rendering and reduce internal interference. This functional separation, supported by an XMOS XU316 USB interface and a QCC5125 Bluetooth receiver, enables support for streams up to PCM 768kHz / 32-bit and DSD512, allowing wide-bandwidth signals to be reproduced with the temporal stability required by modern sources.
Douk Audio Q100 : AKM AK4191+AK4499EX DAC
Douk Audio Q100 : Bluetooth 5.1 chip
Douk Audio Q100: Comprehensive connectivity
Beyond its conversion capability, the Q100 structures exhaustive connectivity integrating USB-C, AES, optical and coaxial inputs, accommodating both computer sources and dedicated digital transports, while Bluetooth 5.1 with LDAC and aptX HD support ensures high-bitrate wireless transmission. This input versatility allows multiple sources to be unified at a single conversion point, while maintaining consistent reproduction regardless of the transmission mode.
Douk Audio Q100: Balanced output stages
The Q100 integrates balanced XLR outputs alongside an unbalanced RCA output, allowing the output level and transmission mode to be matched to the installation's requirements while limiting ground loop interference on long cable runs. This architecture is supported by measured performance of ≥124dB SNR and 0.0002% THD+N, ensuring faithful reproduction of the converted signal while preserving dynamic range across the full spectrum.
Douk Audio Q100: Extended USB compatibility
This approach extends to the integration of a UAC switch enabling toggling between UAC1.0 and UAC2.0 protocols, allowing on one hand driverless plug-and-play compatibility with consoles or embedded systems, and on the other access to high-resolution streams in compatible environments. This switching ensures continuity of use across multimedia, gaming and audio playback applications, while retaining a single conversion interface.
Douk Audio Q100 : OLED display
Douk Audio Q100: Digital filters
For those wishing to fine-tune the DAC's behaviour, the Q100 offers several PCM digital filters acting on the impulse response and roll-off management, allowing the trade-off between transient precision and reverb rendering to be adjusted. Sharp roll-off modes (Sharp / Short Delay Sharp) favour a structured reproduction with pronounced attack definition, while progressive roll-off variants (Slow / Super Slow) attenuate pre-ringing effects to produce a more continuous and natural presentation.
This approach extends further with intermediate profiles (Short Delay Slow, Low Dispersion) that adjust temporal dispersion and spatial perception, enabling the converter's behaviour to be tailored to the content being played. The full feature set is accessible via a user interface incorporating an OLED display.
Product typeDAC with volume control
Inputs1x USB-C
1x Coaxial
1x Optical Toslink
1x AES
Bluetooth 5.1
1x Balanced stereo XLR
DAC chipsAK4499+AK4191
USB interfaceXU316
Bluetooth chipQCC5125
Op-amps5x OPA1612
Supported sampling ratesUSB: PCM up to 32bit 768kHz, DSD up to DSD512 (Native), DSD DoP up to DSD256
Coaxial/Optical: PCM up to 24bit 192kHz, DSD DoP up to DSD256
AES: PCM up to 24bit 192kHz
Frequency response20Hz-20kHz (±0.1dB)
Signal-to-noise ratio (SNR)≥ 124dB
Total harmonic distortion more noise (THD+N)0.0002% @ 1kHz
Output levelRCA: 2.3V
XLR: 4.5V
OS compatibilityWindows 7/8/10/11, macOS, Linux, Android, iOS
Supported Bluetooth codecsSBC/AAC/aptX/aptX-HD/LDAC
Power supply voltage100-130V AC / 200-240V AC
Dimensions228 x 170 x 46mm
Weight1.73kg
ColorSilver
Package1x Douk Audio Q100
1x Remote control
1x Bluetooth antenna
1x Power cable
1x USB-A to USB-C cable
1x Optical Toslink cable
InputAES/EBU
DAC / ADC ChipAK4499
DAC / ADC ChipAK4191
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Remote ControlYes
DOUK AUDIO Q100 DAC AKM AK4191+AK4499EX XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512
The Douk Audio Q100 is a high-resolution desktop DAC designed for digital-to-analogue conversion, relying on a dissociated architecture combining...
