EVERSOLO DAC-Z10 DAC 2x AK4499+AK4191
The Eversolo DAC-Z10 is a high-end digital-to-analog converter (DAC) designed for demanding audiophiles, combining technical precision and musicality. It features a fully isolated architecture (FIA), which physically and electrically separates the digital and analog circuits to minimize interference and preserve signal purity. Equipped with two AKM decoding chips (AK4191 + AK4499EX) per channel, it offers high-resolution conversion up to 32-bit 768kHz PCM and DSD512, ensuring highly refined sound reproduction with low distortion.
By buying this product you get 199 loyalty points
Reference : 21277
1 990,00 €tax incl.
1 658,33 € tax excl.
Eversolo DAC-Z10 DAC 2x AK4499+AK4191 I2S HDMI ARC Bluetooth 5.0 32bit 768kHz DSD512
Eversolo DAC-Z10
The DAC-Z10 also incorporates a high-precision clock system, the Eversolo Precision Core™, combining a temperature-controlled crystal oscillator (OCXO), PLL (phase-locked loop) technology, and FPGA clock reconstruction, ensuring optimal time consistency and reduced jitter. Its R2R volume control and integrated preamplifier enable analog signal management, while its comprehensive connectivity (USB, XLR, RCA, HDMI ARC/eARC, Bluetooth 5.0) makes it a versatile device, suitable for HiFi systems as well as home theater or headphone setups. With a total harmonic distortion plus noise of only 0.00008% and a dynamic range of 130dB, this DAC is the complete solution for high-fidelity audio enthusiasts.
Eversolo DAC-Z10: Key features
Eversolo DAC-Z10: Fully isolated FIA architecture
The DAC-Z10 is based on Eversolo's fully isolated architecture (FIA), which completely separates the digital and analog sections to minimize interference and preserve signal purity. Three independent linear power supplies individually power the left channel, system, and right channel, allowing each to operate in a very low-noise environment. Its decoding architecture features two independent sets of AK4191 + AK4499 DACs for the left and right channels, combined with a fully balanced analog preamplifier that uses precise dual-channel R2R volume control. This configuration delivers high dynamic range and extremely low THD+N.
Eversolo DAC-Z10: FIA insulation architecture diagram
Eversolo DAC-Z10: Three independent power supplies
With three independent toroidal transformers for the left channel, right channel, and system power supply, the DAC-Z10 maintains ultra-low noise down to 42µV. This design minimizes interference, giving each channel its own clean, isolated voltage supply for stable, detailed sound.
Eversolo DAC-Z10: Dual DAC modules
Eversolo DAC-Z10: Dual decoding modules
Designed with a fully symmetrical architecture, the DAC-Z10 is equipped with two independent AK4191 + AK4499 DAC modules for the left and right channels. Combined with AKM's Velvet Sound™ technology, it offers a perfect balance between precision and tonal richness. The DAC-Z10 also supports high-resolution files up to PCM 32-bit 768kHz and DSD512.
Eversolo DAC-Z10: R2R volume control
The DAC-Z10 uses a precise R2R resistor network for volume control, preserving the original signal at all levels. Whether at low volume or full volume, every nuance remains intact, delivering clear, accurate, and faithful sound.
Eversolo DAC-Z10: Fully balanced preamplifier
The Eversolo DAC-Z10 features a high-performance, fully balanced preamplifier with XLR and RCA analog inputs offering up to +10dB of gain. Combined with a precision R2R analog volume control network, it delivers ultra-low noise and distortion, significantly improving dynamic range and signal integrity, allowing every nuance of the music to be reproduced with clarity and authenticity.
Eversolo DAC-Z10: Balanced preamplifier
Eversolo DAC-Z10: Phase-locked loop technology
The DAC-Z10 incorporates an OCXO temperature-controlled quartz oscillator and PLL (Phase-Locked Loop) technology to achieve precise clock reconstruction. Accurate synchronization is fundamental to high-resolution audio reproduction. Thanks to the stability of the OCXO and the precision of the PLL correction, the DAC-Z10 ensures that every note is reproduced exactly as intended.
Eversolo DAC-Z10: External clock support
Precise synchronization is essential for capturing all musical nuances. With support for a high-precision external clock, the Eversolo DAC-Z10 offers unmatched stability and accuracy. It is possible to connect a 10MHz or 25MHz external clock, and the DAC-Z10 provides a 50Ω input and a 75Ω input.
Eversolo DAC-Z10: FPGA
Eversolo DAC-Z10: High-end FPGA
The Eversolo DAC-Z10 incorporates an FPGA that shapes the I2S data and refines the clock. Each digital signal is thus optimized to achieve its purest form before reaching the DAC.
Eversolo DAC-Z10: Captures every nuance of the music
The DAC-Z10 delivers exceptional sound quality that is both rich and detailed. With an ultra-low THD+N of 0.00008% and a wide dynamic range of 130dB, every note sounds with unparalleled clarity.
Eversolo DAC-Z10
Eversolo DAC-Z10: Multi-core USB audio processor
The DAC-Z10 is equipped with a multi-core USB audio processor, offering high processing speed and bandwidth to ensure lossless transmission and high resolution. The DAC-Z10's USB input supports files up to PCM 32-bit 768 kHz and native DSD512. Its optical and coaxial inputs support resolutions up to PCM 24-bit 192 kHz and DSD64 DoP.
Eversolo DAC-Z10: USB-B Input
Eversolo DAC-Z10: Grounding terminal block
The DAC-Z10's ground terminal dissipates noise, eliminating even minor interference and preserving the purity of every note.
Eversolo DAC-Z10: Rear view
Eversolo DAC-Z10: I2S audio input with 8 modes
Via its I2S digital audio input, the Eversolo DAC-Z10 offers 8 switchable modes and supports resolutions up to PCM 32-bit 768kHz and native DSD512. Its fully isolated hardware design separates the signal and ground between devices, ensuring clean signals and improved audio clarity.
Eversolo DAC-Z10: I2S operating modes
Eversolo DAC-Z10: A particularly comprehensive range of connectors
The Eversolo DAC-Z10 is definitely versatile, thanks in particular to its extremely comprehensive range of connections, designed to meet all needs and integrate with all systems.
  • Dual coaxial input: The DAC-Z10 features two isolated coaxial inputs, supporting up to 24-bit 192kHz PCM. This design effectively protects against external interference, preserving every detail with clarity and precision.
  • Isolated AES/EBU input : To preserve signal purity, the DAC-Z10 features a dedicated isolated AES/EBU input, which completely separates electrical noise between source and destination devices.
  • Dual optical input: The DAC-Z10 supports two optical inputs, providing greater flexibility and connectivity to your audio system.
  • USB Audio input: USB is often the most convenient choice for digital audio, but electrical noise and ground loops can subtly compromise its purity. The DAC-Z10 introduces an isolated USB audio input, which transmits only clean data while blocking all electrical interference.
  • Trigger input and output: Manually turning each device on and off can be tedious. The DAC-Z10's trigger interfaces act as a control channel, allowing for seamless, linked control of your entire system.
Eversolo DAC-Z10: Connectors
Eversolo DAC-Z10: HDMI ARC integration
The Eversolo DAC-Z10 is equipped with HDMI ARC connectivity, supporting ARC and eARC modes for easy integration into your home theater system. It not only decodes high-fidelity music, but also delivers cinematic sound with breathtaking clarity and realism.
Eversolo DAC-Z10
Eversolo DAC-Z10: Headphone output
Eversolo DAC-Z10: Headphone amplifier module and Jack 6.35mm output
The DAC-Z10 features a dedicated headphone amplifier module with a 6.35mm jack output that automatically detects impedance and adjusts gain, delivering powerful and detailed sound. Gain settings—high, medium, and low—allow you to tailor playback to different headphones and listening preferences.
Eversolo DAC-Z10: High quality Bluetooth module
The DAC-Z10 is equipped with a Qualcomm QCC5125 Bluetooth module. Whether you're streaming from your phone or connecting directly via a tablet, it delivers a high-fidelity wireless listening experience.
Eversolo DAC-Z10: Bluetooth chip
Eversolo DAC-Z10: A resolutely modern design
The Eversolo DAC-Z10 boasts a sleek and modern aesthetic. Its chassis is made from aerospace-grade aluminum. Both rigid and lightweight, it combines precision engineering with refined design.
Eversolo DAC-Z10
Eversolo DAC-Z10: A seamless user experience
The DAC-Z10 features a large 8.8-inch IPS touchscreen with a clear and intuitive interface. Changing inputs, adjusting volume, and checking format information are all operations that can be performed at your fingertips.
Eversolo DAC-Z10
Eversolo DAC-Z10: Un design qui s'adapte à vos préférences
To allow each user to customize the DAC-Z10 according to their personal taste and the aesthetics of their space, the color of the LED surrounding the main button can be changed.
Eversolo DAC-Z10: Control button
Eversolo DAC-Z10: Intuitive signal path display
On this DAC-Z10 interface, the signal path is highlighted. Sources, master clock, filter characteristics, XLR/RCA outputs, and R2R volume control balance: everything is clearly presented for immediate understanding.
Eversolo DAC-Z10 : Chemin du signal
Eversolo DAC-Z10: Your music, your style
The Eversolo DAC-Z10 offers a variety of vintage VU meters and dynamic spectrum displays, allowing you to visualize your music during your listening sessions.
Eversolo DAC-Z10: Display and VU meters
Eversolo DAC-Z10: Adjustable channel balance
The DAC-Z10 offers left/right channel balance gain adjustment of up to 15dB, allowing you to fine-tune each channel to suit your listening preferences.
Eversolo DAC-Z10
Eversolo DAC-Z10: Tailored listening
The Eversolo DAC-Z10 offers 6 filters, allowing you to switch freely between them depending on the type of music you are listening to. With its versatile filter curves, the DAC-Z10 shapes the sound to suit your preferences.
Eversolo DAC-Z10
Eversolo DAC-Z10: Adjustable XLR polarity
To ensure faithful sound reproduction, the DAC-Z10 offers two XLR polarity modes, allowing precise adjustment to suit different system requirements. This ensures stable and accurate signal transmission.
Eversolo DAC-Z10 : Pinout XLR
Eversolo DAC-Z10: Control your music with the touch of a finger
The DAC-Z10 supports control via the mobile app, touchscreen, and remote control. Manage your system remotely from your smartphone or interact directly via the large touchscreen. Whichever you choose, your music is always at your fingertips.
Eversolo DAC-Z10: Control application
EVERSOLO DAC-Z10 review by ON-MAG
“The musical qualities of the Eversolo DAC-Z10 DAC and preamplifier are indisputable. It goes far beyond entry-level models in various criteria such as bandwidth exploration, soundstage width, separation, and transients. It scores top marks in terms of input diversity.”
Logo ON-MAG
1Jack 6.35mm headphone output
2Screen
3ON/OFF button
4IR receiver
5LED
6Volume button
7Remote control
8Grounding terminal block
9Analog output, right channel
10Analog input, right channel
112x Coaxial inputs
12External clock input
13Analog input, left channel
14Analog output, left channel
15Power connector and power button
16Trigger input and output
172x Optical inputs
18AES/EBU input
19HDMI ARC input
20I2S via HDMI input
21USB audio input
22USB port for firmware updates
23Remote control
Product typeDAC
InputsBluetooth
1x USB-B
1x I2S via HDMI
2x Coaxial
2x Optical Toslink
1x AES/EBU
1x HDMI ARC
1x Single-ended stereo RCA
1x Balanced stereo XLR
Outputs1x Single-ended stereo pre-out RCA
1x Balanced stereo pre-out XLR
1x Jack 6.35mm headphone output
Grounding terminal blockYes
Trigger1x Trigger input
1x Trigger output
External clock inputsSupport 10M/25M :
1x 75Ω clock input
1x 50Ω clock input
Firmware update portYes (1x USB-A 2.0)
DAC2x AK4191+AK4499
Main processorDCP8568
Audio processorMulti-core USB audio processor
OPAOPA1612
Touchscreen8.8" IPS
Power supply circuitTriple ultra-low noise linear power supply
Control appYes
Bluetooth chipQCC5125
Bluetooth version5.0
Supported Bluetooth codecsSBC, AAC
USB compatibilityWindows 10 et ultérieur
macOS
Android
iOS
Supported sampling ratesUSB, I2S via HDMI: PCM up to 32bit 768kHz, DSD up to DSD512
AES/EBU, Optical, Coaxial: PCM up to 24bit 192kHz, DSD64 DoP
HDMI ARC: PCM up to 24bit 192kHz
I2S modes8 configurations
Recommended headphone impedance
16-300Ω (Low gain: 16-32Ω / High gain: 32-300Ω)
Audio measurements
Output levelXLR: 5Vrms @ 0dBFS
RCA: 2.5Vrms @ 2dBFS
Headphone output (low gain mode): 4Vrms @ 0dBFS
Headphone output (mid gain mode): 5.6Vrms @ 0dBFS
Headphone output (high gain mode): 7Vrms @ 0dBFS
THD+N (@ No-wt)XLR : 0.00008% @ 1kHz (-122dB @1kHz)
RCA : 0.000097% @ 1kHz (-120dB @1kHz)
Headphone output (low gain mode): 0.0003% @ 1kHz (-110dB @ 1kHz)
Headphone output (mid gain mode): 0.00018% @ 1kHz (-115dB @ 1kHz)
Headphone output (high gain mode): 0.00013% @ 1kHz (-118dB @ 1kHz)
Bruit (@ No-wt)XLR : 0.00008% @ < 1.2µVrms
RCA : < 1.5µVrms
Headphone output (low gain mode): < 2.5µVrms
Headphone output (mid gain mode): < 2.5µVrms
Headphone output (high gain mode): < 2.5µVrms
SNR (@ A-wt)XLR : 130dB
RCA : 128dB
Headphone output (low gain mode): 124dB
Headphone output (mid gain mode): 126dB
Headphone output (high gain mode): 127dB
Réponse en fréquenceXLR : 20Hz-20kHz (±0.1dB)
RCA : 20Hz-20kHz (±0.1dB)
Headphone output (low gain mode): 20Hz-20kHz (±0.1dB)
Headphone output (mid gain mode): 20Hz-20kHz (±0.1dB)
Headphone output (high gain mode): 20Hz-20kHz (±0.1dB)
Supply voltageAC 100-240V 50/60Hz
Consumption32W
Dimensions365 x 310 x 88mm
Weight9kg
Housing materialAluminum alloy
Package1x DAC-Z10
1x Remote control
1x Power cable
1x USB-B to USB-A cable
1x Trigger cable
1x Cleaning cloth
InputI2S
InputI2S via HDMI
InputClock (BNC)
InputXLR
InputAES/EBU
InputHDMI ARC
OutputJack 6.35mm
DAC / ADC ChipAK4191
DAC / ADC ChipAK4499
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
EVERSOLO DAC-Z10 DAC 2x AK4499+AK4191 I2S HDMI ARC Bluetooth 5.0 32bit 768kHz DSD512
The Eversolo DAC-Z10 is a high-end digital-to-analog converter (DAC) designed for demanding audiophiles, combining technical precision and...
