The iFi Audio Zen Air DAC 2 is a USB DAC with an integrated headphone amplifier designed to deliver high-quality audio reproduction in a compact and accessible format. It is based on a bit-perfect Cirrus Logic MasterHiFi DAC compatible with DSD and DXD, combined with an optimized internal architecture and a USB interface developed in-house by iFi. Compatible with PCM streams up to 32bit / 384kHz, native DSD256, and DXD, it ensures precise and faithful digital-to-analog conversion.
The Zen Air DAC 2 also features a headphone amplifier capable of delivering up to 286mW at 32Ω via its 6.35mm jack output and up to 484mW at 64Ω via its balanced 4.4mm jack output. It offers a stereo RCA line output with fixed or variable level (2V to 3.4V depending on preamp mode), allowing use with a power amplifier or active speakers. It includes proprietary PowerMatch (gain adjustment) and XBass+ (analog bass enhancement) technologies, as well as a front-panel analog volume control. Power is supplied via USB-C, with optimized consumption and plug & play operation. Compact and versatile, it is an ideal solution for use with a computer or in a desktop HiFi system.
The Zen Air DAC 2 is based on a Cirrus Logic converter designed for faithful reproduction of the digital signal. It supports demanding high-resolution formats, including PCM up to 384kHz, native DSD256, and DXD.
This wide compatibility allows you to fully enjoy high-definition audio files, with detailed playback that respects the original recording.
The device includes a high-performance headphone amplifier capable of delivering substantial power suitable for a wide variety of headphones. It features a balanced 4.4 mm jack output delivering up to 484 mW at 64Ω, as well as an unbalanced 6.35 mm jack output delivering 286 mW at 32Ω, ensuring excellent versatility for both demanding and more sensitive headphones.
The PowerMatch function allows adjustment of the gain according to the headphones used, optimizing output level and ensuring better volume control, with increased dynamics and ideal adaptation to different impedances.
The Zen Air DAC 2 features XBass+ technology, an analog circuit designed to enhance low frequencies without affecting mids or highs.
This function is particularly useful with certain headphones or speakers lacking presence in the low-end, enabling a more balanced and immersive listening experience.
Thanks to its stereo RCA output, the Zen Air DAC 2 can be used as a standard DAC or as a preamplifier.
Users can choose between:
This flexibility allows easy integration into different types of audio systems.
| 1 | Power |
| 2 | LED indicator |
| 3 | Power Match function |
| 4 | Volume control |
| 5 | 6.35mm headphone output |
| 6 | Balanced 4.4mm headphone output |
| 7 | XBass+ function |
| 8 | RCA output |
| 9 | Power supply / USB DAC input |
Technical specifications
| Specifications | |
| Product type | USB DAC |
| DAC chip | Cirrus Logic |
| Input | 1x USB-C |
| Output | 1x RCA output (fixed or variable) 1x Balanced 4.4mm headphone output 1x Single-ended 6.35mm headphone output |
| Supported sample rates | PCM 32bit 768kHz, DSD256, DXD |
| RCA output measurements | |
| Output level | 2 to 3.4V |
| SNR | 118dBA |
| DNR | 118dBA |
| Frequency response | 20Hz-90kHz |
| Output impedance | ≤ 50Ω |
| 6.35mm jack output measurements | |
| Output level | 286mW at 32 ohms |
| Output impedance | < 0.7 ohm |
| SNR | 118dBA |
| THD+N | 0.0011% |
| 4.4mm jack output measurements | |
| Output level | 484mW at 64 ohms |
| Output impedance | < 1.4 ohm |
| SNR | 118dBA |
| THD+N | 0.0015% |
| General | |
| Power supply | 5V DC >1A via USB-C |
| Power consumption | No signal: ~0.55W Max.: < 3.55W max. |
| Dimensions | 158 x 35 x 100mm |
| Weight | 315g |
| Package contents | 1x iFi Audio Zen Air DAC 2 1x USB-A to USB-C 2.0 cable |
| Input | USB |
| Output | Jack 4.4mm |
| Output | Jack 6.35mm |
| Output | RCA |
| DAC / ADC Chip | NC |
| Max sampling rate | DSD256 |
| Color | Blue |
| Networking | No |
| Remote Control | No |
