IFI AUDIO IDSD VALKYRIE Portable Headphone Amplifier DAC Black
The iFi Audio iDSD Valkyrie is a portable DAC with a built-in headphone amplifier, designed for high-resolution playback and driving demanding loads. It supports PCM streams up to 768kHz and native DSD up to DSD512, with internal upsampling to DSD1024 via FPGA, utilising a Burr-Brown quad DAC architecture to improve linearity and channel separation. This digital foundation is complemented by an amplification stage capable of delivering up to 5700mW peak power, enabling it to provide power supply for both low- and high-impedance headphones whilst maintaining stable dynamics.
By buying this product you get 166 loyalty points
Reference : 21756
1 669,00 €tax incl.
1 390,83 € tax excl.
iFi Audio iDSD Valkyrie Portable Headphone Amplifier DAC Burr-Brown Bluetooth 32bit 768kHz DSD512 Black
iFi Audio iDSD Valkyrie : Front view
Designed for portable or hybrid use, it combines extensive wired connectivity with Bluetooth streaming featuring aptX Lossless, LDAC or LHDC, enabling playback at up to 24bit 96kHz without any noticeable intermediate conversion, whilst its 20000mAh power supply provides up to 18 hours of listening time whilst minimising mains-related interference. This approach is further enhanced by the integration of K2HD processing, which restores harmonics above 22kHz to add depth to compressed recordings, thereby enabling the Valkyrie to act as a central link between various digital sources and high-fidelity headphones, whilst maintaining consistent sound reproduction throughout the entire system.
Product typeDAC
Headphone amplifier
Inputs1x USB-C
1x Coaxial
1x Jack 3.5mm
1x Jack 4.4mm
Outputs2x Jack 3.5mm
1x Jack 4.4mm
1x Stereo RCA
1x Jack 3.5mm line-out
1x Jack 4.4mm line-out
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Signal-to-noise ratio (SNR)116dB
Dynamic range116dB
Total harmonic distortion more noise (THD+N)0.002%
Maximum balanced output power13.5V/5700mW @ 32Ω
19.6V/640mW @ 600Ω
Maximum single-ended output power8.9V/2475mW @ 32Ω
9.8V/160mW @ 600Ω
RMS balanced output power12.0V/2250mW @ 64Ω
19.6V/640mW @ 600Ω
RMS single-ended output power8.5V/2258mW @ 32Ω
9.8V/160mW @ 600Ω
Amplified output impedanceJack 4.4mm: ≤ 0.3Ω
Jack 3.5mm: ≤ 0.2Ω
Line-out impedanceJack 4.4mm: 205Ω
Jack 3.5mm: 105Ω
Battery20 000mAh
Fast chargingPD/QC3.0 @ 20V
QC2.0 @ 5-12V
Supported Bluetooth codecsaptX Lossless, aptX Adaptive, aptX, LDAC, LHDC/HWA, AAC, SBC
Weight882g
Dimensions172 x 160 x 30mm
Package1x iFi Audio iDSD Valkyrie
1x Carry bag
2x USB-C to USB-C cable
1x USB-C to coaxial cable
1x USB-C to Lightning cable
1x Mains adapter
InputJack 3.5mm
InputJack 4.4mm
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipBurr Brown
Max sampling rateDSD512
Max sampling rate768kHz
ClassN/A
IFI AUDIO IDSD VALKYRIE Portable Headphone Amplifier DAC Burr-Brown Bluetooth 32bit 768kHz DSD512 Black
The iFi Audio iDSD Valkyrie is a portable DAC with a built-in headphone amplifier, designed for high-resolution playback and driving demanding...
