LYREMAN AUDIO-1 DAC Headphone Amplifier
New
The Lyreman Audio-1 combines an ES9039Q2M DAC with a headphone amplification stage based on the TPA6120A2 chip. It supports PCM streams up to 32bit / 768kHz and DSD512, while its 3.5mm headphone output delivers 320 mW + 320 mW into 32 Ω.
Reference : 22554
129,00 €tax incl.
107,50 € tax excl.
Lyreman AUDIO-1 DAC Headphone Amplifier ES9039Q2M 32bit 768kHz DSD512
LYREMAN Audio-1: Front view
The Lyreman Audio-1 combines an ES9039Q2M DAC with a headphone amplification stage based on the TPA6120A2 chip. It supports PCM streams up to 32bit 768kHz and DSD512, while its 3.5mm headphone output delivers a power of 320mW + 320mW into 32Ω.
Its frequency response from 20Hz to 20kHz (±0.06dB), its total harmonic distortion more noise of 0.0004% and its signal-to-noise ratio of 123dB specify the stated performance. The optical and coaxial inputs accept digital sources, while the stereo RCA outputs transmit the signal to an amplifier or audio system. The 3.5mm microphone input completes this connectivity for desktop integration, in a 95 × 95 × 40 mm format.
Technical specifications
Product typeDAC
Headphone amplifier
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
1x Jack 3.5mm (microphone)
Outputs1x Stereo RCA
1x Jack 3.5mm headphone output
Supported sampling ratesPCM 32bit 768kHz
DSD512
DAC chipsES9039Q2M
USB interfaceXMOS A316
Frequency response20Hz-20kHz (±0.06dB)
Output level2.55V
Total harmonic distortion more noise (THD+N)0.0004%
Signal-to-noise ratio (SNR)123dB
Dynamic range123dB
Noise≤ 3µV
Dimensions95 x 95 x 40mm
Package1x Lyreman Audio-1
InputJack 3.5mm
OutputJack 3.5mm
DAC / ADC ChipES9039Q2M
Max sampling rateDSD512
Max sampling rate768kHz
LYREMAN AUDIO-1 DAC Headphone Amplifier ES9039Q2M 32bit 768kHz DSD512
The Lyreman Audio-1 combines an ES9039Q2M DAC with a headphone amplification stage based on the TPA6120A2 chip. It supports PCM streams up to 32bit...
