The Lyreman Audio-2 combines an DAC ES9039Q2M with an amplification based on two OPA1612 and two SGM8262, in a 95 × 50 × 45mm format. This architecture supports PCM streams up to 32bit 384kHz and DSD512, while the BP2668Ax USB controller and the optical input allow it to be integrated with various digital sources.
Its 3.5mm single-ended jack and 4.4mm balanced jack headphone outputs deliver 180mW and 750mW respectively into 32Ω. The balanced output thus provides more power to compatible headphones, while the frequency response of 20Hz to 20kHz (±0.06 dB), the THD+N rated at ≤ 0.001% and the SNR reaching up to 120dB characterize its conversion and amplification performance.
Technical specifications
| Specifications | |
| Product type | DAC Headphone amplifier |
| Inputs | 1x USB-C 1x Optical Toslink 1x Coaxial |
| Outputs | 1x Jack 3.5mm 1x Jack 4.4mm |
| Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD512 |
| DAC chips | ES9039Q2M |
| USB interface | BP2668Ax |
| Amplification chip | 2x OPA1612 2x SGM8262 |
| Output level | Jack 3.5mm: 2.4V (180mW @32Ω) Jack 4.4mm: 4.9V (750mW @32Ω) |
| Frequency response | 20Hz-20kHz (±0.06dB) |
| Total harmonic distortion more noise (THD+N) | ≤ 0.001% |
| Dynamic range | Jack 3.5mm: 115dB Jack 4.4mm: 120dB |
| Signal-to-noise ratio (SNR) | Jack 3.5mm: 115dB Jack 4.4mm: 120dB |
| Noise | ≤10µV |
| General | |
| Dimensions | 95 x 50 x 45mm |
| Color | Black |
| Package | 1x Lyreman Audio-2 |
| Input | USB |
| Input | Optical |
| Input | SPDIF |
| Output | Jack 4.4mm |
| Output | Jack 3.5mm |
| DAC / ADC Chip | ES9039Q2M |
| Max sampling rate | 384kHz |
| Color | Black |
| Class | Class D / T |
| Networking | No |
| Remote Control | No |
