SMSL DO100 DAC 2x ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
The SMSL DO100 is a compact, affordable and very powerful DAC, offering a careful design characterized by the knowledge of the brand. It embeds in particular two ES9038Q2M conversion chips allowing it to deliver an extremely fine and rich sound restitution.
4.0 / 5
By buying this product you get 23 loyalty points
Reference : 16344
239,00 €tax incl.
199,17 € tax excl.
Last items in stock !
Shipping date: 23-06-2026.
This model has been replaced by the new one: SMSL DO100 PRO DAC ES9039Q2M.
SMSL DO100
ES9038Q2M Dual DAC & OPA1612
At the heart of the digital/analog conversion stage are two DAC ES9038Q2M chips from ESS, a model renowned for its ability to provide a very transparent sound reproduction. To these, the DO100 associates audiophile components with for example four double OPA1612 AOP.
USB XMOS Interface
 Behind the USB-C input of the DO100, a second generation XMOS interface allows it to decode the audio stream efficiently from this input. It also offers the possibility to enjoy high definition audio files, up to PCM 32bit 768kHz and DSD512.
Low noise linear power supply
The DO100's power supply stage, which is responsible for providing a clean and stable electrical signal to the audio circuits, uses a linear power supply with many discrete components and low-noise PSUs for the analog circuits.
PCM Filter
The SMSL DO100 provides seven selectable PCM filters to modify its response curve and adapt the sound reproduction to your listening and your audio system.
  • FL1 : Fixed minimum phase fast roll-off
  • FL2 : Linear slow roll-off
  • FL3 : Apodizing filter
  • FL4 : Minimum phase fast roll-off
  • FL5 : Minimum phase slow roll-off
  • FL6 : Linear fast roll-off
  • FL7 : Brickwall mixing filter
Bluetooth 5.0
Equipped with a Qualcomm QCC5125 Bluetooth 5.0 receiver chip, the DO100 offers the possibility of remote control, as playback can be started and managed directly from your smartphone. In addition, it supports the high-definition codecs aptX, aptX-HD and LDAC for high-quality wireless sound reproduction.
1Display
2IR Receiver
3Multi-function button
4Stereo RCA output
5Bluetooth antenna
6Optical input
7Stereo XLR output
8Coaxial input
9USB-C input
10Power connector
Product typeDAC
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth 5.0
1x Balanced stereo XLR
Output amplitude (adjustable volume)XLR : 4Vrms
RCA : 2Vrms
THD+N0.00008% (-121dB)
Dynamic rangeXLR : 127dB
RCA : 125dB
SNRXLR : 126dB
RCA : 124dB
Output impedance100Ω
USB TransmissionUSB1.1, USB2.0 (asynchronous)
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DoP64
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD, LDAC
Supply voltage100-240VAC
Consumption5W
Standby consumption< 0.5W
Dimensions150 x 128 x 39mm
Package1x DO100
1x Remote control
1x Power cable
1x USB cable
1x Bluetooth antenna
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
Récepteur Bluetooth très complet
Pratique et bien équipé, au niveau de sortie réglable par télécommande, ce récepteur BT souffre d'un manque d'indication quant aux nombreux choix de qualité audio, pas facile de s'y retrouver...
La qualité est là, mais on aurait apprécié une sortie AES-EBU
This review has been posted for SMSL DO100 DAC 2x ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
The SMSL DO100 is a compact, affordable and very powerful DAC, offering a careful design characterized by the knowledge of the brand. It embeds in...
