SMSL SU-9 ULTRA DAC AK4499EX + AK4191 XMOS XU316 Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512 MQA MQA-CD
An updated version of the SU-9 Pro, the SMSL SU-9 Ultra includes all the features that made its predecessor a high-performance DAC, plus a number of improvements. This time, the SU-9 Ultra features an AK4191 digital filter interface coupled with an AK4499EX DAC chip, both from AKM. This AKM chip combination delivers rich, precise sound reproduction, while decoding high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA.
By buying this product you get 54 loyalty points
Reference : 18381
549,00 €tax incl.
457,50 € tax excl.
SMSL SU-9 ULTRA
SMSL SU-9 ULTRA DAC AK4191 + AK4499EX XMOS XU316 Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512 MQA MQA-CD
An updated version of the SU-9 Pro, the SMSL SU-9 Ultra includes all the features that made its predecessor a high-performance DAC, plus a number of improvements. This time, the SU-9 Ultra features an AK4191 digital interface coupled with an AK4499EX DAC chip, both from AKM. This AKM chip combination delivers rich, precise sound reproduction, while decoding high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA.
Inside this DAC, you'll find high-quality components such as an XMOS XU-316 USB interface, a CK-03 clock circuit that considerably reduces jitter, and a shielded, regulated power supply stage capable of delivering a clean, stable electrical signal.
SMSL SU-9 ULTRA
SMSL SU-9 PRO
Year of release
2023
2022
DAC chip
AK4499EX + AK4191
ES9039MPro
Connector / USB interface
USB-C / XMOS XU-316
USB-B / XMOS XU-316
Jitter elimination technology
CK-03
CK-03
THD+N
0.00006% (-124dB, un-wtd)
0.00005% (-125dB, un-wtd)
DAC : AK4191 + AK4499EX
The SU-9 Ultra incorporates an AK4499EX DAC chip coupled with an AKM AK4191 digital interface. This combination of chips enables it to decode up to PCM 32bit 768kHz and DSD up to DSD512. They also accept MQA streams and offer a distortion level of less than 0.00006% (-124dB).
Support MQA and MQA-CD streams
The SMSL SU-9 Ultra supports the decoding of MQA (Master Quality Authenticated) files, offering sound quality as close as possible to the studio recording. It also supports the MQA-CD format, enabling this format to be read from a CD player. MQA streams are supported by optical, coaxial and USB-C digital inputs.
XMOS XU-316 USB interface with USB-C connector
A 16-core XMOS XU316 USB interface is integrated into the SU-9 Ultra. This interface enables it to process high-resolution streams (PCM 32bit 768kHz, DSD DoP and DSD512) via its USB-C input port. This may be ideal, for example, for users wishing to use their computer as a source device.
Bluetooth HD
The SMSL SU-9 Ultra features a Bluetooth 5.0 receiver chip, enabling you to stream your music wirelessly via a source such as your smartphone. The SU-9 Ultra supports the standard Bluetooth transmission codecs SBC and AAC, as well as the high-definition codecs aptX, aptX HD and LDAC.
SMSL SU-9 Ultra overview
1IR receiver
2Display
3Multifunction knob
4Bluetooth antenna
5Toslink optical input
6RCA stereo output
7Power supply connector
8USB-C input
9SPDIF coaxial input
10XLR balanced stereo output
Product typeDAC
DAC chipAKM AK4499EX + AK4191
USB interfaceXMOS XU-316
Inputs1x USB-C
1x Toslink optical
1x Coaxial
Bluetooth
Outputs1x Stereo single-ended RCA
1x Stereo balanced XLR
Output powerXLR: 5Vrms
RCA: 2.5Vrms
THD+N0.00006% (-124dB, Un-wtd)
USB transmission protocolUSB 2.0 asynchronous
USB CompatibilityWindows 7 / 8 / 9 / 10 / 11 (with driver)
Mac OSX10.6 ou plus
Linux
Supported sample ratesUSB: PCM 32Bit 768kHz, DSD DoP256, DSD512, MQA
Coaxial & Toslink: PCM 24Bit 192kHz, DSD DoP64, DSD512, MQA
Bluetooth5.0
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Power consumption10W
Standby power consumption<0.5W
Dimensions187.5 x 154 x 40mm
Weight0.79kg
Package1x SMSL SU-9 Ultra DAC
1x Remote control
1x Power cable
DAC / ADC ChipAK4499EX
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
An updated version of the SU-9 Pro, the SMSL SU-9 Ultra includes all the features that made its predecessor a high-performance DAC, plus a number...
