SMSL VMV D2R DAC ROHM BD34301 XMOS XU316 Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA
The SMSL VMV D2R is a top-of-the-range DAC, offering very high performance thanks to its meticulous design and carefully selected components. In particular, it is equipped with an excellent ROHM BD34301 conversion chip and a XMOS XU316 USB interface, guaranteeing rich, precise sound reproduction.
4.3 / 5
By buying this product you get 113 loyalty points
Reference : 18245
1 139,00 €tax incl.
949,17 € tax excl.
Shipping date: 23-06-2026.
SMSL VMV D2R
The SMSL VMV D2R is a top-of-the-range DAC, offering very high performance thanks to its meticulous design and carefully selected components. In particular, it is equipped with an excellent ROHM BD34301 conversion chip and a XMOS XU316 USB interface, guaranteeing rich, precise sound reproduction. It's also a particularly versatile model that will fit in with the vast majority of audio systems thanks to its complete connectivity, and even wireless connectivity with an on-board Bluetooth 5.1 receiver.
ROHM BD34301 DAC
The ROHM BD34301 digital-to-analog conversion chip is the brand's most powerful model, with THD+N measured at -117dB! It ensures efficient decoding for rich, precise and clear sound reproduction. It also supports high-resolution audio signals, both PCM and DSD.
XMOS XU-316 USB interface
The SMSL VMV D2R's USB-B input uses a 3rd-generation XMOS XU-316 interface. Capable of high-performance decoding and in association with the device's ROHM BD34301 DAC chip, this USB input lets you enjoy high-resolution audio streams up to PCM 32bit 768kHz and DSD512.
High-end components
In addition to its excellent DAC and USB interface, the VMV D2R benefits from an overall design featuring numerous high-end, high-performance components. These include a proprietary CK-03 clock circuit with Accusilicon oscillators for minimal jitter, an ultra-low-noise on-board linear power supply with multiple voltage regulators and a Noratel toroidal transformer, as well as a host of discrete components.
MQA
The SMSL VMV D2R benefits from an MQA (Master Quality Authenticated) decoder, enabling it to read this type of file, guaranteeing sound quality as close as possible to that of a studio recording. These files are approved directly by the artist, the record company or the rights holders, and offer a particularly faithful reproduction.
Bluetooth 5.0
In addition to its comprehensive and versatile connectivity, the VMV D2R features a Bluetooth 5.1 receiver using a Qualcomm chip. This makes it possible to stream music wirelessly from a smartphone, for example. What's more, the device supports high-resolution aptX, aptX HD and LDAC codecs for high quality wireless sound.
1Screen
2LED indicator
3IR receiver
4Multifunction button
5Balanced XLR output
6Single-ended RCA output
7AES/EBU input
8Coaxial input
9Optical input
10USB-B input
11I2S input
12Bluetooth antenna
13Power connector and power button
Modern, luxurious design
The SMSL VMV D2R boasts a sublime CNC-machined aluminum enclosure, giving it a modern yet luxurious aesthetic. Its front panel features a beautiful color display, protected by a sturdy tempered glass pane. The D2R also comes with an all-aluminum remote control for convenient remote control.
Technical characteristics
Product typeDAC
DAC chipROHM BD34301
InputsBluetooth 5.1
1* USB-B
1* Optical
1* Coaxial
1* AES/EBU
1* I2S via HDMI
Outputs1* Single-ended stereo RCA
1* Balanced stereo XLR
Output levelRCA : 2Vrms (fixed volume) / 2.6Vrms (variable volume)
XLR : 4Vrms (fixed volume) / 5.1Vrms (variable volume)
Output impedanceRCA : 100 Ohm
XLR : 200 Ohm
THD+NRCA : 0.00014% (-117dB)
Dynamic rangeRCA : 125dB
XLR : 129dB
SNRRCA : 124dB
XLR : 129dB
USB transmissionAsynchrone
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11
Mac OSX
Linux
Supported sampling ratesUSB / I2S : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Consumption5W
Standby consumption< 0.5W
Dimensions280*235.5*43mm
Weight3.2kg
Package1* SMSL VMV D2R
1* Power supply
1* Antenna
1* Remote control
SMSL VMV D2R DAC ROHM BD34301 XMOS XU316 Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA SMSL VMV D2R DAC ROHM BD34301 XMOS XU316 Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA SMSL VMV D2R DAC ROHM BD34301 XMOS XU316 Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipROHM BD34301EKV
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
Remote ControlYes
3 reviews
Hélas mitigé.
L'appareil en soi est très bon. Construction irréprochable, son à l'avenant, connectique complète.
Malheureusement, pour moi qui écoute beaucoup de SACD, cet appareil n'est pas adapté à cet usage car je n'utilise pas de préampli et donc le réglage du volume sur le DAC est primordial, ce que ce D2R n'est pas en mesure de faire.
En effet, malgré le paramètre PRE MODE sur variable, le volume avec un stream DSD est irrémédiablement réglé à 0.0db, c'est à dire sortie à fond sur mes blocs de puissance ce qui a failli faire sauter mes enceintes.
J'ai contacté SMSL Chine et j'ai reçu la réponse suivante, je vous la livre telle quelle (littéralement) :
"The DSD of D2R cannot control the volume. It is Normal, there is a chip issue". Sans plus de formes.
Ceci est non seulement extrêmement malpoli mais surtout totalement inacceptable d'autant moins que nulle part ce défaut n’est indiqué, ni dans le marketing ni dans la notice sous forme de mise en garde vu les implications potentielles léthales pour vos HP. Que le circuit intégré ne fasse pas le job est une chose, ne pas prévenir le futur acheteur de cette situation en est une autre.
Bref je suis mitigé et ça m’embête car le son en PCM (NAS, Qobuz, transport CD) est vraiment excellent, surtout à ce prix.
J’ai deux autres DAC SMSL, M400 et M500, au demeurant excellent eux aussi. Les deux convertisseurs ont toujours fonctionné sortis de leurs boites sans rechigner et avec tous les formats d’encodage disponibles. Là ce n’est pas le cas et j’en suis navré puisque forcé de le retourner.
5 * pour tout sauf pour la conception (1 *) clairement baclée et la mésinformation inexcusable et dangereuse pour l'équipement.
This review has been posted for SMSL VMV D2R DAC ROHM BD34301 XMOS XU316 Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA
VMV D2R
The DAC has excellent sound, detail and space.
The aluminum body and remote control make the device an elegant addition to the audio set.
Crackling when changing the sample rate of the track being played.
In variable mode, the DSD signal is at full volume. Need to convert the signal DSD to PCM!
When turn on DAC and start playing, transmit the signal for 1 second in full power! Only in Variable mode !
DAC is ideal to connect it to a preamplifier.
D2R
The elegant, very musical DAC surprised me with its sound clarity, its range and space of sound delivery, fast and accurate high-resolution sound delivery, excellent setting options, only when switching the type of sound resolution, you can hear a slight banging, but that will definitely be solved by later controls, I extremely satisfied with this thing
The SMSL VMV D2R is a top-of-the-range DAC, offering very high performance thanks to its meticulous design and carefully selected components. In...
