LA FRAPPE ULTIME MIEUX QUE DES DA à 4-5k
By buying this product you get 89 loyalty points
Topping's D90 III Sabre balanced DAC is an evolution of the Topping D90SE DAC. In this improved version, Topping has chosen new components and added new features for enhanced performance and a better user experience. This D90 III DAC incorporates an ESS ES9039SPRO DAC chip per channel, a USB XMOS interface upgraded to an XU-316, a new Qualcomm QCC5125 Bluetooth 5.1 receiver chip and a 12V trigger input and output on the rear panel. The high-end components present on the previous version, such as the Altera Max CPLD, are also present. The evolutions made to the D90 III enable it to achieve better SNR, better dynamic range and an even lower level of distortion. The extensive connectivity of this balanced DAC makes it a versatile device with high-end audiophile features.
Topping's balanced DAC is equipped with one ESS ES9039PRO DAC chip per channel for independent signal processing. These DAC chips enable it to support high-resolution PCM 32Bit 768kHz and native DSD streams up to DSD512, while maintaining excellent performance. This is also reflected in the D90 III's THD+N of less than 0.00006% (RCA) and 0.000045% (XLR), and SNR of 129dB (RCA) and 135dB (XLR).
The D90 III is equipped with an MQA decoder that performs the entire MQA decoding process in-house, so you can enjoy audio files as close as possible to the original studio recordings, on a multitude of its inputs: USB, coaxial, optical and AES/EBU.
The D90 III DAC is equipped with a third-generation XU-316 USB XMOS interface, the performance of which has already been proven. This ensures excellent processing of digital signals passing through the device's USB port. It also offers a high level of Plug & Play compatibility (Win10, Win11, MAC, Linux, IOS, Android) and excellent stability thanks to a Thesycon driver.
A driver and settings are still required for ASIO on Windows.
Topping has chosen to replace its Bluetooth chip with Qualcomm's flagship Bluetooth 5.1 QCC5125 receiver chip, enabling the D90 III to support high-resolution codecs: SBC, ACC, aptX, aptX HD, aptX Adaptive and LDAC. So you can enjoy a wireless connection supporting streams up to PCM 24bit 96kHz, a higher resolution than the CD quality standard.
The D90's Altera MAX II CPLD is used to process the clock signal and optimize the quality of the digital sound signal, considerably reducing jitter.
The D90 III features a selectable output system. Audio can be routed to the XLR output, to the RCA output, or to both. In addition, an output level can be selected. For example, the XLR output can operate at 4V or 5V, and the RCA output at 2V or 2.5V.
In addition to the DAC mode with fixed output level, the D90 III offers a DAC + preamplifier mode. In this mode, you can control the volume level. In this way, the D90 III can be directly combined with a power amplifier or active loudspeakers.
The D90 III lets you switch from one mode to another with ease. So you can quickly switch from default mode to valve mode or transistor mode, and enjoy a different listening experience.
This function enables the D90 III to be controlled, or to control other devices so that they can be switched on and off simultaneously.
| 1 | XLR balanced stereo output |
| 2 | RCA single-ended stereo output |
| 3 | I2S input via HDMI |
| 4 | Toslink optical input |
| 5 | SPDIF coaxial input |
| 6 | USB-B input |
| 7 | Bluetooth antenna connector |
| 8 | AES/EBU input |
| 9 | Trigger in/out 12V |
| 10 | Power connector and power switch |
The Topping D90 III SABRE supports various I2S transmission protocols: I2S PHASE STD, I2S PHASE REV, I2S DSDR DATA, I2S DSDR LRCLK, DSD FLAG 14 and DSD FLAG 15. It is therefore compatible with most digital interfaces on the market.
| Specifications | |
| Product type | Balanced DAC |
| DAC chip | 2x ES9039SPRO |
| USB interface | XMOS XU-316 |
| Inputs | 1x USB-B 1x AES/EBU 1x SPDIF Coaxial 1x Optical Toslink 1x I2S via HDMI Bluetooth 5.1 |
| Outputs | 1x Single-ended RCA stereo 1x Balanced XLR stereo |
| Supported sample rates | PCM 32bit 768kHz DSD512 MQA |
| Supported Bluetooth codecs | SBC, ACC, aptX, aptX HD, aptx Adaptative, LDAC |
| Trigger | |
| DAC + preamplifier function | |
| RCA LINE OUTPUT MEASUREMENTS (USB IN @96KHZ) | |
| THD+N @ A-Weighted | < 0.00006% @ 1kHz |
| THD @ No-Weighted, 90kBw | < 0.0003% @20Hz-20kHz |
| SNR @ A-Weighted | 129dB @ 1kHz |
| Dynamic range @ A-Weighted | 129dB @ 1kHz |
| Frequency response | 20Hz - 20kHz (+/- 0.1dB) 20Hz - 40kHz (+/- 0.3dB) |
| Output level | 2.1Vrms @0dBFS (mode 4V) 2.6Vrms @0dBFS (mode 5V) |
| Noise @ A-Weighted | < 1.1uVrms |
| Channel crosstalk | -133dB @ 1kHz |
| Channel balance | 0.3dB |
| Output impedance | 50 Ohm |
| XLR LINE OUTPUT MEASUREMENTS (USB IN @96KHZ) | |
| THD+N @ A-Weighted | < 0.000045% @ 1kHz |
| THD @ No-Weighted, 90kBw | < 0.0001% @20Hz-20kHz |
| SNR @ A-Weighted | 135dB @ 1kHz |
| Dynamic range @ A-Weighted | 135dB @ 1kHz |
| Output level | 4.2Vrms @0dBFS (mode 4V) 5.2Vrms @0dBFS (mode 5V) |
| Channnel separation | -149dB @ 1kHz |
| Output impedance | 100 Ohm |
| General | |
| Dimensions | 222 x 160 x 45mm |
| Color | Black |
| Package | 1x Topping D90 III Sabre Black 1x Bluetooth remote control 1x USB cable 1x Bluetooth antenna 1x Power cable |
| Input | SPDIF |
| Input | Bluetooth |
| Input | AES/EBU |
| Input | USB |
| Input | Optical |
| Input | I2S via HDMI |
| Output | XLR |
| Output | RCA |
| DAC / ADC Chip | ES9039MPro / ES9039MSPro |
| Max sampling rate | MQA |
| Color | Black |
| Class | N/A |
| Networking | No |
| Remote Control | Yes |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Marc W.
Tom K.
