AUDIOPHONICS U-Sabre LTE Asynchronous USB DAC 24bit/96kHz SA9023 / ES9023
Reference : 11074
32,90 €tax incl.
27,42 € tax excl.
AUDIOPHONICS U-SABRE LTE
USB DAC 24bit/96kHz - SA9023 / ES9023
U-SABRE LTE Audiophonics
A USB-B cable (not-included) is required for input signal.
A simple, compact and efficient DAC...
The Audiophonics DAC U-SABRE LTE is equipped with a modern USB Audio input interface. The decoding chip is ESS's famous ES9023 Sabre, known for its ease of use and efficiency. Thanks to this small device, you can enjoy high fidelity sound quality at a lower price, up to 24 bit / 96kHz.
u-sabre sa9027 es9023
A USB DAC with variable function.
The DAC's RCA analog output allows it to be paired with a stereo amplifier, or even a dedicated headphone amplifier. In short, you are in the company of a USB DAC with high quality features in a compact format.
Musical & Performing
Audiophile Audio Plug & Play USB DAC
The Audiophonics U-Sabre LTE DAC is self-supplied USB powered by any laptop or computer. This makes it a simple and functional Plug & Play digital interface.
You will enjoy dematerialized sources without sacrificing your current HiFi installation, by connecting it to your stereo amplifier for example. The musicality of the ES9023 will do the job perfectly.
SA9023
This Bravo SA9023 USB interface is an important part of our U-Sabre LTE, in fact this last one is Asynchronous. In addition, it allows you to accept your music files up to 24 bit / 96kHz, passing of course through the digital signals 32kHz, 44.1kHz, 48kHz and 88.2kHz. In short, Saviaudio's quality and expertise can be found in this modern USB interface.
Saviaudio sa9027
ESS es9023
ES9023P
This nomadic High Definition DAC is equipped with the famous SABRE ES9023 24-bit / 96kHz, which incorporates Hyperstream technology to overcome the usual faults of the classic Delta Sigma DACs. The result is immediately perceptible, thanks to a feeling and sound precision above the Delta Sigma competitors
CompatibilityNative / Plug & Play on Windows, Linux, OS X
USBAsynchronous
DACSabre ES9023 Asynchronous
Analog outputDirect Out
Power supply5V DC (Via USB) - No external power supply required
USB input (SA9023 SAVIAUDIO)Up to 24bit 96kHz (We recommend the use of qualitative cable with a length of less than 1.5m.)
Stereo RCA outputGold plated
Dimensions58 x 69 x 24mm
Case materialAluminium
u-sabre es9023 sa9027
DAC / ADC ChipES9023
Max sampling rate96kHz
24 reviews
Parfait
Utilisé avec Mpd et Rapberry Pi OS sur un Raspberry 4 sans aucun problème.
Le Dac est reconnu out of the box.
This review has been posted for AUDIOPHONICS U-Sabre LTE Asynchronous USB DAC 24bit/96kHz SA9023 / ES9023
Excellent petit Dac
En plus il est autoalimenté, pas besoin de transfo !
Excellent
La différence est clairement perceptible dès que le DAC est connecté.
Une qualité de son incomparable avec la carte son de l'ordinateur.
Les tonalités naturelles des voix sont tres bien restituées avec beaucoup de detail.
Un équilibre entre graves et aigus parfaitement respecté.
Le DAC s'installe tout seul, pas besoin de pilote.
Une excellente decouverte !
Qualité
petit Dac qui transforme votre PC en PC audiophile pour pas cher
Fait le job
J'ai acheté ce produit pour faire des mesures sur des enceintes
avec un ampli analogique depuis un PC.
Fonctionne sans problème avec REW.
