DENAFRIPS ENYO 15TH Balanced R2R DAC Black
The Denafrips Enyo 15TH DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R technology enables Enyo to deliver a natural, faithful and musical sound reproduction.
By buying this product you get 85 loyalty points
Reference : 19477
859,00 €tax incl.
715,83 € tax excl.
Denafrips Enyo 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black
Denafrips Enyo : Front view
To obtain a high-performance R2R DAC, Denafrips Enyo 15TH uses a network of ultra-precise resistors. Each resistor is rigorously measured and matched by a machine and validated by human intervention.
Denafrips Enyo 15TH uses a fully symmetrical R2R design. Each channel is decoded by 4 sets of R2R networks. This design features very low linear error, high decoding speed and low digital noise, guaranteeing not only low distortion of the audio signal, but also very low background noise, enabling the listener to fully enjoy his or her music. The DAC also provides the user with NOS or OS and Slow or Sharp filters.
Key features:
  • Low-noise power supply
  • FPGA-based digital signal processing
  • Reclocking and adaptive FIFO buffer
  • Supports PCM 1536kHz and DSD1024 streams via USB
  • Proprietary USB audio solution via STM32F446 microcontroller
  • Proprietary USB interface via STM32F446 microcontroller based on AMR technology
  • Pilote USB Thesycon
Product typeBalanced R2R DAC
Inputs1x Coaxial
1x Optical Toslink
1x USB-B
1x I2S
1x Balanced stereo XLR
Supported sampling ratesUSB: PCM up to 1536kHz, DSD up to DSD1024
Optical / Coaxial: PCM up to 24bit 192kHz, DSD up to DSD64 (DoP)
Sampling rate modesNon onversampling (NOS)
Oversampling (OS)
Output impedances / levelsRCA : 625Ω @ 2Vrms
XLR : 1250Ω @ 4Vrms
FiltersSlow
Sharp
Frequency response20Hz - 70Hz (-3dB)
THD+N0.004%
SNR115dB
Dynamic range> 119dB
Crosstalk-124dB
Supply voltage100-240VAC 50/60Hz (selectable voltage)
Consumption≤ 20W
Dimensions230 x 215 x 45mm
Weight3.5kg
Package1x Denafrips Enyo 15th DAC
1x Power supply cable
InputI2S
DAC / ADC ChipR2R LADDER DAC
Max sampling rate1536kHz
Max sampling rateDSD1024
Remote ControlN/A
7 reviews
DAC surprenant
Je voulais un son numérique qui soit doux avec une nostalgie pour les années 70 avec les vinyles.
Avant mes recherches, je n'avais jamais fait attention à la différence entre les 2 architectures de DAC "Delta Sigma" et "R2R". En fonction des descriptions, mon choix s'est rapidement dirigé vers le "R2R" et en détaillant un peu plus j'ai vu "Denafrips" qui était très reconnu par des audiophiles anglais. Mon choix final a donc été l'ENYO 15th.
J'avais déjà passé des commandes chez Audiophonics et je n'avais jamais été déçu, je fus donc très heureux de constater qu'ils étaient un revendeur de cette marque.
Comme d'habitude, la commande s'est très bien passée avec une livraison parfaite (timing et conditionnement).
Ensuite j'ai écouté ce DAC et j'avoue que je ne suis pas déçu. Le son n'est pas agressif tout en ayant beaucoup de détails et de profondeur. Je me surprends à rester des heures à l'écouter sans ressentir aucune fatigue.
Je recommande vivement ce DAC et merci à Audiophonics.
This review has been posted for DENAFRIPS ENYO 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black
Diabolique!
Déçu par le DAC de mon Parasound P6 dont je trouvais le son propre et clair mais manquant de volume et après avoir essayé plusieurs DAC delta sigma d'un peu toutes marques et prix qui ne m'apportaient jamais pleine satisfaction (trop froid, pas assez détaillé, spatialisation médiocre) J'en étais presque à penser que je ne pourrais simplement pas égaler mon système analogique (Planar P6 et Lehmann Audio Black Cube SE) et que le son de mes Electra 1038 Be2 serait forcément plus directif en numérique...
Cette petite brique (ça donne l'impression d'être construit comme un tank) a tout simplement révolutionné mon système!
Dès le premier morceau j'ai été surpris d'entendre des effets de fonds et des reverbes que je n'avais tout simplement jamais entendu avant sur des morceaux que j'ai écouté des milliers de fois.
La spatialisation est tout simplement magnifique, chaque instrument étant clairement à sa place, chaque clochette, cymbale, charlestone... tout est précis et détaillé. Les attaques de caisses claires, tommes et grosse caisse sont percutantes au point de donner l'impression de voir le batteur taper sur chaque composants de sa batterie avec une précision spatiale tout simplement bluffante. Les riffs de guitares donnent l'impression que le guitariste est dans la pièce...
J'ai vite abandonné le coté écoute analytique de mon système pour simplement écouter et apprécier la musique (au point de me faire danser dans mon salon!)
Tout simplement magique!
Pour faire simple je dirais qu'avant j'avais de la musique dans mon salon mais que cette petite chose a fait entrer la musique dans mon salon
DAC absolument exceptionnel
Je partais pourtant d'une bonne base avec le DAC intégré de mon amplificateur Advance Paris A10 Classic relié à des Focal Aria 936 et à un caisson de basses Velodyne pour les infra basses.
Je trouvais néanmoins que sur certains morceaux avec beaucoup d'instruments, la scène sonore manquait de précision, et que pour les graves, le contrôle pouvait être meilleur.
Après quelques semaines de recherches j'ai fini par découvrir ce DAC sur des vidéos YouTube en anglais, ainsi que sur des sites internet américain (en France, à part quelques revendeurs audio qui parlent toujours des mêmes marques, il n'y a pas grand monde pour s'intéresser au sujet...)
Il n'y a donc pas de puce(s) Delta Sigma sur ce Denafrips, mais un réseau de résistances.
Une technologie R2R plutôt ancienne, et théoriquement dépassée...sauf que les DAC R2R sont aujourd'hui parmis les plus haut de gamme pour ce type d'appareil.
Cela m'a intrigué, j'ai continué à creuser le sujet et cela a tout changé.
J'étais sur le point de commander un Topping D70 Pro Octo (qui me semble excellent), et puis j'ai finalement basculé sur Denafrips Enyo 15th.
Il coûtait certes un peu plus cher, mais sans tomber dans l'excès, et en restant en cohérence avec le reste de mon matériel.
Il s'agit donc d'un DAC et de rien d'autre (pas de possibilité d'usage en tant que pré-ampli, pas de sortie casque, pas de Wifi, pas de bluetooth, pas d'écran...) mais il fait un travail incroyable, et j'ajouterai que sa construction impeccable en métal et son poids qui atteste de la présence d'une alimentation massive sont vraiment impressionnants.
Il sait faire tout ce que j'espérais pour corriger les petits défauts que je mentionnais, mais aussi beaucoup plus.
En résumé, excellente organisation de la scène sonore aussi bien en largeur qu'en profondeur, élargissement de la scène sonore, très bonne dynamique (particulièrement en mode OS), contrôle des graves jusqu'au plus extrêmes absolument remarquable, présence des voix des chanteurs ou chanteuses juste incroyable, très beau travail pour révéler une multitude de détails dans les médiums et les aigus.
Je dirais qu'auparavant mon ampli et mes enceintes fonctionnaient à 85% de leurs possibilités, et qu'aujourd'hui, ils ne sont pas loin des 100%.
Il n'y a qu'un défaut sur ce DAC: l'absence totale de mode d'emploi. J'ai juste trouvé une vidéo du constructeur de deux minutes et quelques, mais c'est trop court, pas suffisamment détaillé et pas vraiment éclairant.
J'ai fini par demander de l'aide à une IA générative, cela a été utile, mais c'est quand même dommage que l'on soit obligé d'en arriver là.
Super Dac
Après de longues recherches pour remplacer mon SMSL SU-9, j'ai opté pour le Denafrips Enyo 15TH R2R. Le SU-9 est un bon appareil, mais sur mon système, il était trop analytique et avait la brillance des puces ESS. Mon cahier des charges était: son plus doux, voix incarnées, chaleur, émotion...J'écoute surtout du blues et du jazz. Résultat, le Enyo remplace avantageusement le SU-9. Les voix sont superbes, le grave a pris de l'ampleur, le médium est chaleureux, mon objectif est atteint. Suivant votre système et vos goûts, le Enyo est à recommander +++
Beautyful Sound
I used the internal DAC of my Wiim pro plus for about a year, but after a while came to the conclusion, that the Sound lacks a lot of the attributes I love about my Vinyl Setup. And as i digged into the rabbit hole of DAC Systems, I soon found out about Denafrips.
To put it short, this comes very clone to the vinyl sound, and absolutely makes a huge difference to the Wiim dac. So open, airy, wide soundstage. Listening fatigue is gone and it just makes me want to Listen to my digital chain more often.
Definetly recommended!
The Denafrips Enyo 15TH DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R...
