IFI AUDIO ZEN ONE SIGNATURE DAC Burr Brown XMOS Bluetooth 5.0 32bit 384kHz DSD256 MQA
The iFi Audio Zen One Signature uses the DAC stage of the Zen DAC V2, while adding SPDIF inputs (optical and coaxial) to complement the USB port, as well as the Bluetooth technology of the Zen Blue V2. It takes advantage of this to add circuit improvements to offer a particularly complete and powerful product that will benefit your entire audio system.
By buying this product you get 34 loyalty points
Reference : 15986
349,00 €tax incl.
290,83 € tax excl.
This product is available here: IFI AUDIO ZEN ONE SIGNATURE DAC.
iFi Audio Zen One Signature DAC Burr Brown XMOS Bluetooth 5.0 32bit 384kHz DSD256 MQA
A true audio hub for the home
The Zen One Signature is the first product in the Zen DAC series to support so many sample rates: PCM up to 32bit 384kHz, DSD up to DSD256, MQA 384kHz and Bluetooth up to 96kHz.
Bluetooth HD
Thanks to its Qualcomm QCC5100 chip and in combination with iFi Audio's proprietary circuitry, the Zen One Signature is able to deliver a high-quality Bluetooth 5.1 music experience. In addition, it supports all current high-resolution transmission codecs: aptX, aptX Low Latency, aptX Adaptive and aptX HD, LDAC and HWA as well as LHDC are therefore supported.
High level digital technology
The Zen One Signature is packed with technology to deliver exceptional performance. It features a True Native Burr Brown DAC that supports high-resolution streams, a 16-core XMOS USB interface capable of decoding MQA, an improved femtosecond GMT clock and a custom digital filter to eliminate jitter, all accompanied by a complete set of connectivity.
Balanced & Analog Outputs
The balanced circuit is the basic element of the Zen range. The Zen Signature One takes up this architecture by using high-end audio components in order to reduce the distortion level of the device as much as possible.
In addition, it proposes in analog output 4.4mm balanced jack and unbalanced stereo RCa. It can therefore be associated with most amplifiers, preamplifiers, headphone amplifiers or active speakers.
Signature Serie
iFi Audio's Signature line always includes high-end components:
  • Low jitter femtosecond clock.
  • USB XMOS interface 160 cores 2000MIPS for high computing power.
  • C0G capacitors for high linearity and excellent temperature and frequency characteristics.
  • High precision and low noise MELF resistors.
  • Taiyo Yuden and Murata inductors for low impedance of the power supply stage.
  • High gain antenna for increased transmission distance.
Product typeDAC
DAC ChipBurr Brown
Inputs1x USB-B 3.0
1x Coaxial
1x Optical Toslink
Bluetooth 5.1
1x Balanced Jack 4.4mm
1x Coaxial
DSD up to DSD256
DxD up to 384kHz
MQA
Supported Bluetooth codecsSBC, AAC, LHDC/HWA, aptX, aptX LL, aptX HD, aptX Adaptive, LDAC
Bluetooth chipQualcomm QCC5100
Frequency response5Hz - 80kHz ±3dB
Output levelBalanced : 4V
Single-ended : 2V
Output impedanceBalanced : ≤ 72Ω
Single-ended : 36Ω
SNR-105dB(A) @ 0dBFS
THD+N< 0.002% @ 0dBFS
Supply voltage5VDC
ConsumptionNo signal : ~0.7W
Max signal : ~1W
Dimensions158 x 100 x 35mm
Weight485g
Package1x iFi Audio Zen One Signature
1x Power supply
1x Bluetooth antenna
1x RCA cable
1x USB cable
OutputJack 4.4mm
OutputCoaxial SPDIF
DAC / ADC ChipBurr Brown
Max sampling rateDSD256
Max sampling rate384kHz
Max sampling rateMQA
The iFi Audio Zen One Signature uses the DAC stage of the Zen DAC V2, while adding SPDIF inputs (optical and coaxial) to complement the USB port,...
