LAIV HARMONY UDAC Discrete Balanced R2R DAC Black
The LAIV Harmony µDAC, little brother of the LAIV Harmony DAC, is also a discreet, balanced R2R DAC. However, it features an ultra-compact form factor, similar to the brand's LEXT interfaces. Like its big brother, it supports high-resolution sampling rates up to PCM 32bit 768kHz and DSD256.
By buying this product you get 119 loyalty points
Reference : 20614
1 190,00 €tax incl.
991,67 € tax excl.
Shipping date: 22-07-2025.
LAIV Harmony µDAC Discrete Balanced R2R DAC 32bit 768kHz DSD256 Black
LAIV HARMONY uDAC photo
The LAIV Harmony µDAC, little brother of the LAIV Harmony DAC, is also a discrete, balanced R2R DAC. However, it features an ultra-compact form factor, similar to the brand's LEXT interfaces. Like its big brother, it supports high-resolution sampling rates up to PCM 32bit 768kHz and DSD256. LAIV has equipped its device with audiophile components within a high-end design. The digital and analog stages are galvanically isolated, and it features an Altera Cyclone IV CPLD, Accusilicon AS318 Femtosecond oscillators and a Class A discrete output stage for the most authentic and accurate sound reproduction. As well as its elegant looks, the µDAC boasts full connectivity: USB-B input, Toslink optical input, coaxial SPDIF input, I2S clock input via HDMI and balanced XLR output. As you can see, this little device from LAIV offers the very best in digital-to-analog conversion, all in a compact format.
LAIV Harmony µDAC: Balanced R2R DAC
The LAIV Harmiony µDAC is based on the same digital-to-analog conversion circuit as its big brother, namely a discrete balanced R2R circuit designed from audiophile components for precise signal processing. It supports high-definition sampling rates up to PCM 32bit 768kHz and DSD256. Each resistor in the circuit, with a tolerance of 0.05%, is carefully arranged to deliver superior, faithful and immersive sound quality.
The R2R circuit of the LAIV HARMONY uDAC
The LAIV HARMONY uDAC clock
LAIV Harmony µDAC: Clock optimization
The µDAC is based on an Accusilicon AS318 femtosecond oscillator with very low phase noise, guaranteeing uncompromising performance. In addition, an I2S port via HDMI allows integration of an external master clock for even greater performance. This flexible system will be particularly appreciated by the most demanding audiophiles.
LAIV Harmony µDAC: Discrete class A output buffer
The LAIV Harmony µDAC's Class A output buffer uses discrete components for precise impedance matching, to avoid signal degradation and ensure optimum transfer to an amplifier. The fact that it's in Class A ensures constant linearity and low noise, for the smooth, warm sound performance so highly prized by audiophiles.
LAIV HARMONY uDAC output buffer
LAIV Harmony µDAC: Galvanic isolation
The µDAC's digital and analog circuits are galvanically isolated to avoid ground loops and guarantee a clean, interference-free path for the sound signal.
Galvanic isolation of LAIV HARMONY uDAC circuits
LAIV Harmony µDAC overview
Overview of LAIV HARMONY uDAC
1Power button
2Display
3Menu button
4Return button
5Multifunction button
6Balanced XLR output
7I2S input via HDMI (accept MCLK clock)
8Coaxial input
9Toslink optical input
10USB-B input
1115V 2A power supply via DC jack
Product typeDAC R2R
Inputs1x USB-B input
1x Coaxial input
1x Toslink optical input
1x I2S input via HDMI
Output1x Balanced XLR output
ProcessorAltera Cyclone IV
Supported sampling ratesPCM up to 32Bit 768kHz
Native DSD up to DSD256
External clock via I2S HDMI
Power supply15V 2A via jack DC
Package1x LAIV Harmony µDAC
1x Power adapter
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD256
Max sampling rate768kHz
Remote ControlYes
LAIV HARMONY UDAC Discrete Balanced R2R DAC 32bit 768kHz DSD256 Black
The LAIV Harmony µDAC, little brother of the LAIV Harmony DAC, is also a discreet, balanced R2R DAC. However, it features an...
