MUSICIAN DELPHINUS Discrete R2R DAC Black
The Musician DELPHINUS is a discrete stereo R2R DAC designed to convert high-resolution digital streams into analog signal. It supports PCM up to 24bit / 1536kHz as well as DSD1024 via its USB and I2S inputs, while offering NOS and OS modes. Its architecture combines a 0.005% R2R network, an Altera chip and a dedicated FPGA for signal processing.
By buying this product you get 59 loyalty points
Reference : 22410
599,00 €tax incl.
499,17 € tax excl.
Shipping date: 24-11-2026.
Musician DELPHINUSDiscrete R2R DAC 24 bit / 1536 kHz DSD1024
Photo du MUSICIAN DELPHINUS Discrete R2R DAC 24 bit / 1536 kHz DSD1024
The Musician DELPHINUS is a discrete stereo R2R DAC designed to convert high-resolution digital streams into analog signal. It supports PCM up to 24bit 1536kHz as well as DSD1024 via its USB and I2S inputs, while offering NOS and OS modes. Its architecture combines a 0.005% R2R network, an Altera chip and an FPGA dedicated to signal processing.
Intended for digital Hi-Fi setups, it combines five digital inputs with RCA and XLR outputs, allowing you to connect a computer, a digital transport, a player or a source equipped with an I2S output to an analog amplifier or preamplifier. The front panel gathers the controls and operating indicators, while the remote control allows adjustments to be made remotely without interacting directly with the unit.
Musician DELPHINUS: List of key features
Musician DELPHINUS: R2R architecture and signal processing
The DELPHINUS uses a discrete R2R architecture based on resistors with a tolerance of 0.005%. This design ensures the conversion of digital signals into stereo analog signal, while the Altera chip and the FPGA handle digital processing. The DAC offers two operating modes. The NOS mode disables oversampling in order to keep the stream in its native form, while the OS mode applies oversampling before conversion. The USB and I2S inputs allow the highest-resolution streams to be used, up to PCM 24bit 1536kHz and DSD1024.
Musician DELPHINUS: Photo of the internal circuits
Musician DELPHINUS: Photo of the inputs and outputs
Musician DELPHINUS: digital connectivity and analog outputs
The digital connectivity includes a coaxial input, an optical input, a USB input, an AES input and an I2S input. The DAC can thus receive the signal from a computer, a network player, a digital transport or a source equipped with an I2S output. The analog section includes a pair of unbalanced RCA outputs and a pair of balanced XLR outputs. The XLR outputs deliver a level of 4Vrms, suited to balanced connections between the DAC and a compatible preamplifier or amplifier.
It is not recommended to use the XLR and RCA outputs simultaneously.
Musician DELPHINUS: I2S input configurations
The I2S input offers 8 pinout modes in order to adapt the mapping of the DATA, BCK and LRCK signals to the connected source. This function compensates for wiring differences between manufacturers, which can prevent correct signal transmission despite the use of I2S connectivity. The appropriate mode can be selected directly on the unit.
Musician DELPHINUS: Table summarizing the I2S configurations
Musician DELPHINUS: indicator lights and controls
The indicator lights show the operating status of the DAC, the selected digital input as well as the processing mode used. They also allow you to identify the format of the received signal and to quickly verify that the connected source is properly recognized. The front panel gathers the controls needed to select the input, choose the OS or NOS mode and access the various settings. The remote control repeats these functions in order to allow their modification from the listening position, without interacting directly with the DAC.
Musician DELPHINUS: Photo of the transformer
Musician DELPHINUS: power supply and integration
The power supply relies on an 80W toroidal transformer, which provides the energy needed for the digital and analog circuits. The DELPHINUS thus fits between a digital source and an amplification device equipped with analog inputs, with an RCA or XLR connection depending on the system configuration.
Technical specifications
Product typeR2R DAC
Inputs1x USB-B
1x Coaxial
1x Optical Toslink
1x AES/EBU
1x I2S via HDMI
Outputs1x Single-ended RCA
1x Balanced XLR
Supported sampling ratesUSB / I2S: PCM up to 32bit 1536kHz, DSD up to DSD1024, DSD DoP64
Optical Toslink, coaxial, AES/EBU: PCM up to 24bit 192kHz, DSD DoP up to DSD64
Frequency response20Hz-75kHz (+1/-3dB)
THD+N< 0.002% (A-Weighted)
SNR≥ 120dB (A-Weighted)
Dynamic range≥ 121dB
Crosstalk≥ 110dB
Output levelRCA: 2Vrms
XLR: 4Vrms
Operating modeNOS/OS
Power supply230V/50Hz
Consumption≤ 20W
Dimensions200 x 195 x 45mm
Weight2.35kg
Package1x Musician DELPHINUS
1x IR remote control
1x Power cable
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipNC
Max sampling rate1536kHz
Max sampling rateDSD1024
Remote ControlYes
MUSICIAN DELPHINUS Discrete R2R DAC 24bit 1536kHz DSD1024
The Musician DELPHINUS is a discrete stereo R2R DAC designed to convert high-resolution digital streams into analog signal. It supports PCM up to...
