SMSL D1 DAC
The SMSL D1 is a budget DAC based on high-quality components. Digital-to-analog conversion is performed by a USB XMOS XU-316 interface combined with a Rhom BD34352EKV chip, enabling it to achieve an SNR of 126dB while supporting high-resolution streams up to PCM 32bit 768kHz and DSD512.
Reference : 20843
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 03-04-2026.
SMSL D1 DAC ROHM BD34352EKV XMOS XU316 32bit 768kHz DSD512
Photo du SMSL D1
The SMSL D1 is a budget DAC based on high-quality components. Digital-to-analog conversion is performed by a USB XMOS XU-316 interface combined with a Rhom BD34352EKV chip, enabling it to achieve an SNR of 126dB while supporting high-resolution streams up to PCM 32bit 768kHz and DSD512. The USB-C input is complemented by a Toslink optical input and a coaxial SPDIF input, and the output is on an RCA connector. The SMSL D1 can be adapted to a variety of scenarios, whether you need to connect a source such as a computer, a smartphone via USB, or a DVD player, a TV via optical/SPDIF.
Les connexions du SMSL D1
SMSL D1 overview
Aperçu du SMSL D1
1Touch input selector
2Touch power button
3RCA output
4Coaxial input
5Toslink optical input
6USB-C DAC input
7USB-C power port
Product typeDAC
DAC chipROHM BD34352EKV
USB interfaceXMOS XU316
Inputs1x USB-C
1x Toslink optical
1x Coaxial
Outputs1x RCA output
Output level2Vrms
THD+N0.00038% (-108dB)
Dynamic range119dB
SNR119dB
Supported sample ratesUSB: PCM up to 32bit 768kHz, DSD up to DSD512
Toslink optical and coaxial: PCM up to 24bit 192kHz
USB transmissionAsynchronous
USB compatibilityWindows 7/8/8.1/10/11
Mac OS
Linux
Alimentation5V 1A via USB-C
Power consumption< 5W
Standby: < 0.1W
Dimensions101 x 33 x 90.1mm
Weight201.1g
Package1x DAC SMSL D1
DAC / ADC ChipROHM BD34301EKV
Max sampling rate768kHz
Max sampling rateDSD512
Bon et pas Cher
Trois entrées , DSD sur USB mais pas de télécommande. Le son est doux et plutot precis, je le prefere à mon DAC actuel 3 fois plus cher mais de conception plus ancienne qui est plus neutre et peut parfois avoir quelques duretés sur certains enregistrements. Pour le prix si vous pouvez vous passer de télécommande c'est un bon choix.
This review has been posted for SMSL D1 DAC ROHM BD34352EKV XMOS XU316 32bit 768kHz DSD512
The SMSL D1 is a budget DAC based on high-quality components. Digital-to-analog conversion is performed by a USB XMOS XU-316 interface combined...
