The SMSL D1 is a budget DAC based on high-quality components. Digital-to-analog conversion is performed by a USB XMOS XU-316 interface combined with a Rhom BD34352EKV chip, enabling it to achieve an SNR of 126dB while supporting high-resolution streams up to PCM 32bit 768kHz and DSD512. The USB-C input is complemented by a Toslink optical input and a coaxial SPDIF input, and the output is on an RCA connector. The SMSL D1 can be adapted to a variety of scenarios, whether you need to connect a source such as a computer, a smartphone via USB, or a DVD player, a TV via optical/SPDIF.
1 | Touch input selector |
2 | Touch power button |
3 | RCA output |
4 | Coaxial input |
5 | Toslink optical input |
6 | USB-C DAC input |
7 | USB-C power port |
Product type | DAC |
DAC chip | ROHM BD34352EKV |
USB interface | XMOS XU316 |
Inputs | 1x USB-C 1x Toslink optical 1x Coaxial |
Outputs | 1x RCA output |
Output level | 2Vrms |
THD+N | 0.00038% (-108dB) |
Dynamic range | 119dB |
SNR | 119dB |
Supported sample rates | USB: PCM up to 32bit 768kHz, DSD up to DSD512 Toslink optical and coaxial: PCM up to 24bit 192kHz |
USB transmission | Asynchronous |
USB compatibility | Windows 7/8/8.1/10/11 Mac OS Linux |
Alimentation | 5V 1A via USB-C |
Power consumption | < 5W Standby: < 0.1W |
Dimensions | 101 x 33 x 90.1mm |
Weight | 201.1g |
Color | Black |
Package | 1x DAC SMSL D1 |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | RCA |
DAC / ADC Chip | ROHM BD34301EKV |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Networking | No |
Remote Control | No |
