SMSL VMV V2 USB DAC ES9023 24bit/192kHz / Amplificateur casque 500mW
Reference : 9870
179,90 €tax incl.
149,92 € tax excl.
DAC / Headphone Amplifier having nothing to envy to the high-end sedentary market, the VMV V2 is designed around a Saber ES9023 converter and a CM6631A Asynchronous USB interface to make the most of your high fidelity audio sources.
Versatile, it has an Optical Toslink output allowing you to use it as a digital interface.
The VMV V2 has four gain types dedicated to amplification for your headphones and intras selectable under the housing.
This small concentrate of efficient technology is above all enjoyable and efficient.
Characteristics :
  • DAC Saber ES9023
  • CM6631A Asynchronous USB 2.0 Interface
  • Supports files up to 24bit 192kHz (including 88.2kHz)
  • Signal to noise ratio:> 105dB
  • Dynamic range: 108dB
  • THD + D: <0.003%
  • Supported Impedances: 32 - 600 Ohms
  • Output power: 500mW under 32 Ohms
  • Output voltage: 2Vrms
  • Consumption: <3W
  • 4 gain selections: 8dB, 11dB, 15dB, 16.5dB
  • RCA line out
  • Toslink Optical Digital Output
  • Jack 6.35mm headphone outputs
  • Chassis 100% Aluminum silver
  • Dimensions: 120x92.8x23mm
  • Weight: 550g
  • Power supply 9V DC 500mA
  • Supplied with: 1 USB-A to USB-B cable, 1 manual, 1 driver CD and 1 AC adapter
  • Recommended Software: Foobar 2000 on Windows, Pure Music on Mac OS
  • Windows, Mac OS, iOS, Android 4.0 compatible
[Img-10813-left-thickbox_default]
[Img-10814-left-thickbox_default]
[Img-10815-left-thickbox_default]
[Img-10816-left-thickbox_default]
[Img-10817-left-thickbox_default]
