TOPPING D30 USB DAC 24bit/192kHz DSD 128 XMOS CS4398 Silver
TOPPING D30 USB DAC 24bit 192kHz DSD 128 XMOS
The DAC TOPPING D30 offers high quality manufacturing at a reasonable budget. Based on proven circuits it provides a lot of music in a well finished aluminum case.
4.5 / 5
Reference : 12278
99,00 €tax incl.
82,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
This Topping D30 is now replaced by its successor, the Topping D30 Pro.
Topping d30
24bit 192khz CS4398 DAC
Topping D30
Musical and well built
USB XMOS and quality components Topping D30
The D30 features prominent components such as Wima and TDK Epcos film capacitors, KOA American-style resistors and Burr-Brown OPA 2134 stereo output amps. This DAC has two separate clocks for each multiple sampling frequency 44.1khz and 48Khz. The analog digital decoding component CS4398 is one of the rare chips on the market entirely native DSD making it an obvious choice for lovers of High Definition lovers.
https://www.audiophonics.fr/img/cms/cotation%20dac.jpg "alt =" quotation% 20dac.jpg "/>
Sampling rate24bit 192kHz
Digital input sensitivity0.5V pp (75Ω Coaxial) / 19dB on Toslink Optics
THD0.003% over 20 to 20kHz unweighted
Bandwidth20 to 20kHz +/- 0.03dB
Stereo output voltage level2.1V (RCA)
Signal / Noise Ratio108dB
Internal clockDual high precision clock
Sampling rate per digital inputs
USBPCM 44.1kHz - 192kHz 16-24bits
USB DSDDSD64 to DSD128
Input SPDIF Coaxial24bits max 44.1kHz - 192kHz
SPD inputIF Optical24bits max 44.1kHz - 192kHz
USB CompatibleWindows 7, 8, 8.1, 10 (requires a driver) Mac OS 10 and Linux
Miscellaneous
Power adapter15V DC 0.6A (via Jack DC 5,5 / 2,5 mm)
Dimensions122 x 177 x 38mm
Weight407g
Accessories1x USB cable, 1x IEC power cable, 1x AC adapter
DAC / ADC ChipCS4398
Max sampling rate192kHz
Max sampling rateDSD128
ColorSilver
8 reviews
Topping DD30 DAC
Se trata del primer DAC que he comprado por lo que no puedo ofrecer una opinión técnica. Creo que funciona muy bien. Respecto de la atención y el envío del producto a estado perfecta. Espero volver a comprar en Audiophonics. Muchas gracias.
Ceci est le premier DAC que j'ai acheté, je ne peux donc pas donner d'avis technique. Je pense que cela fonctionne très bien. Concernant l'entretien et l'expédition du produit en parfait état. J'espère acheter à nouveau chez Audiophonics. Merci beaucoup.
This review has been posted for TOPPING D30 USB DAC 24bit/192kHz DSD 128 XMOS CS4398 Silver
FANTASTIQUE
super DAC au rapport qualité/prix incroyable.
Beaucoup de gain ce qui permet d'avoir de la réserve pour l'ampli.
Je peux profiter de mon abonnement Qobuz en haute résolution sans souci et avec un grand plaisir !
Plug and play sous windows 10 ...
Merci encore Audiophonics pour le traitement et le suivi de la commande.
dac topping d 30
rapidite d'expedition j'ai aprecie sur cet appareil la mise en route immediate sans se creuser la tete comme sur un certain dac que j'ai eu avant le son est parfait tres satisfait de mon achat
Content !
Je ne suis pas un pro en écoute, j'avais besoin d'un remplacement de mon DAC Musical Fidelity V-DAC 2 (qui n'a pas tenu très longtemps : à peine 3 ans ...)
Celui-ci le remplace à merveille ! Peut être moins "clair", mais beaucoup plus "actif" (je ne suis pas certain que l'on arrivera à me comprendre ...)
J'en suis très très content. Il remplit son rôle à merveille !
Cerises sur le gâteau :
- très simple d'utilisation (sélecteur pour la source)
- très économique (un bouton on/off facile d'accès)
Et je remercie Audiophonics pour l'emballage et la rapidité de réception !
Bien mais peut mieux faire.
Après quelques temps d'utilisation, j'ai deux remarques à faire.
Il arrive assez régulièrement que le dac se "déconnecte" en interne, lorsque j'allume un amplificateur alors que le Topping est déjà en route, Il faut alors l'éteindre et le rallumer.
De plus, et c'est plus ennuyeux, le Topping pollue la réception FM quand il est en route, et ce de façon tout à fait audible lorsque celui-ci est connecté à un receiver ancien (essais sur plusieurs modèles différents).
The DAC TOPPING D30 offers high quality manufacturing at a reasonable budget. Based on proven circuits it provides a lot of music in a well...
