FIIO M27 Digital Audio Player DAP
The FiiO M27 is a high-end audiophile music player designed to deliver high-resolution audio playback, utilising advanced digital and analogue architecture to ensure stable and detailed sound reproduction. It delivers an output power of up to 5000 mW + 5000 mW at 32 Ω, whilst incorporating dual conversion based on ES9039SPRO DACs, enabling it to handle both demanding portable use and high-power listening setups.
By buying this product you get 179 loyalty points
Reference : 21647
1 790,00 €tax incl.
1 491,67 € tax excl.
FiiO M27 Digital Audio Player DAP 2x ES9039SPRO Bluetooth 5.4 32bit 768kHz DSD512
FiiO M27 : Front view
The FiiO M27 is a high-end audiophile music player designed to deliver high-resolution audio playback, utilising advanced digital and analogue architecture to ensure stable and detailed sound reproduction. It delivers an output power of up to 5000mW + 5000mW at 32Ω, whilst incorporating dual conversion based on ES9039SPRO DACs, enabling it to handle both demanding portable use and high-power listening setups.
Designed for hybrid setups, it combines power, extensive connectivity and advanced processing capabilities, making it suitable for use as a primary source both on the move and as part of a desktop hi-fi system. This approach allows it to centralise local playback, streaming and digital-to-analogue conversion, whilst ensuring thermal and power management suited to prolonged use.
FiiO M27: Qualcomm Dragonwing processor
The FiiO M27 is powered by an 8-core Qualcomm Dragonwing QCS6490 processor, featuring an architecture similar to that of the Snapdragon 778G, with four cores clocked at 2.7GHz and four others at 1.9GHz, ensuring smooth processing of audio applications and high-definition streams. This processing power, supplemented by 8GB of RAM, enables responsive navigation through large libraries whilst maintaining stable background processing, allowing simultaneous use—playback, streaming and equalisation—without any perceptible latency.
FiiO M27 : Processor
FiiO M27 : MicroSD slots
FiiO M27: Extended storage
The 256 GB internal storage is optimised for read speeds of up to 920MB/s, ensuring rapid access to high-resolution audio files and reducing loading times. This approach is further enhanced by the inclusion of two microSD slots, each supporting up to 2 TB, allowing for a massive expansion of total capacity whilst maintaining a segmented organisation of content, ideal for very large local libraries.
FiiO M27: Hybrid device
In addition to its portability, the M27 features a wide range of connectivity options, including a 6.35mm headphone jack, a coaxial input/output, and an optical output, allowing it to be integrated directly into a desktop Hi-Fi setup. This versatility allows it to serve both as a standalone portable music player and as a centralised digital source, whilst ensuring compatibility with external equipment without the need for complex adapters.
FiiO M27 : When used in a sedentary manner
FiiO M27 : XMOS XU316
FiiO M27: High-end components
The audio processing is based on two ES9039SPRO DACs paired with an XMOS XU316 interface, ensuring precise digital-to-analogue conversion and stable handling of high-resolution audio streams. This architecture enables local playback of files up to 32bit 768kHz PCM and DSD512, whilst the Qualcomm QCC5181 Bluetooth 5.4 chip allow wireless transmission via high-resolution codecs such as aptX Lossless and LDAC, thereby ensuring consistent sound quality between wired and wireless use.
FiiO M27: Output power: 5000 mW + 5000 mW
The M27 features an amplifier capable of delivering up to 5000mW + 5000mW into a 32Ω load, with five gain levels to precisely match the power output to different headphones and earphones. This gradation allows for precise control of the signal at low volumes whilst providing sufficient power reserve for the most demanding drivers, thereby ensuring stable reproduction across the entire operating spectrum.
FiiO M27 : Power output: 5000 mW + 5000 mW
FiiO M27 : 9200 mAh battery
FiiO M27: 9200 mAh battery
The power supply is provided by a 9200mAh battery offering up to 9 hours of continuous playback, allowing for extended use without frequent recharging. It supports 35W fast charging via the QC 3.0, QC 4.0, PD 2.0, PD 3.0 and PPS protocols, whilst its replaceable design is part of a commitment to sustainability. This approach is further enhanced by a Desktop mode that allows the battery to be bypassed when using the device on mains power, thereby limiting wear and tear over time.
FiiO M27: DAPS treatment
The M27 incorporates the sixth generation of the proprietary DAPS (Digital Audio Purification System), utilising a latest-generation FPGA coupled with RIVER femtosecond crystal oscillators to ensure jitter-free digital signal transmission. This architecture stabilises the signal stream prior to conversion, resulting in a more coherent reproduction, particularly in terms of micro-details and spatialisation.
FiiO M2: 31-band equaliser
The device features a 31-band equaliser that allows for fine-tuning of the frequency response, offering precise control over the sound output to suit personal preferences or the characteristics of the headphones being used. This flexibility is enhanced by the inclusion of built-in presets, which allow you to quickly adjust the sound whilst retaining a customisable foundation for your settings.
FiiO M27 : 31-band EQ
FiiO M27: Balanced architecture
The internal circuitry features a fully balanced design, which reduces crosstalk whilst improving the overall signal dynamics. This arrangement of the audio stages promotes clearer channel separation, resulting in a more detailed sound and a better-defined soundstage when listening.
FiiO M27 : Balanced architecture
FiiO M27: Impeccable power supply
The power supply separates the analogue and digital sections, thereby minimising interference between signal processing and conversion. This separation, combined with the use of high-capacity capacitors, stabilises the current supply, ensuring a cleaner sound and improved handling of transients, particularly during dynamic passages.
FiiO M27 : Power supply architecture
FiiO M27 : Cooling system
FiiO M27: Efficient cooling
The cooling system is based on an internal structure combining a graphite vapor chamber, a graphene heat spreader and copper heat sinks, ensuring efficient heat dissipation. This approach helps maintain stable performance even during long periods of high-power use.
FiiO M27: As durable as it is stylish
The M27 features a 5.99-inch 1080p display protected by 5th-generation Gorilla Glass, ensuring comfortable readability whilst providing enhanced resistance to everyday wear and tear. This robustness is further enhanced by a CNC-machined titanium chassis, offering high structural rigidity whilst aiding heat dissipation, ensuring a device that is both durable and suited to a variety of environments.
FiiO M27 : Protective cover
FiiO M27: Accessories included
The package is completed by a protective leather case featuring a rear compartment designed to accommodate an active cooling unit, thereby optimising heat dissipation during intensive use. This design philosophy is extended with a desktop stand featuring a built-in fan and USB power supply, enabling prolonged use in desktop mode, whilst a dedicated carry bag makes it easy to transport the device and its accessories (cables, earphones, etc.) in an organised manner.
FiiO M27 Overview
FiiO M27 : Diagram
1Volume control knob
26.35mm line-out/headphone jack
34.4mm line-out/headphone jack
43.5mm line-out/headphone jack
5Previous track
6Play / Pause
7Next track
8Multifunction button
9Side ambient lighting
10Antenna
11MicroSD ports
12Optical Toslink output
13USB-C charging port
14HOLD switch
15USB-C charging/data port
16DESKTOP mode switch
17USB-C charging/data port
18Coaxial input / output
Product typeDigital Audio Player (DAP)
Inputs2x USB-C
1x Coaxial
Bluetooth
WiFi
Outputs1x Single-ended headphone/line jack 6.35mm output
1x Balanced headphone/line jack 4.4mm output
1x Balanced headphone/line Jack 3.5mm output
1x Coaxial
1x Optical Toslink
Bluetooth
DAC chip2x ES9039SPRO
SoCQualcomm Dragonwing QCS6490
Internal memory8Go RAM + 256Go ROM
2x 2To microSD slot
USB interfaceXMOS XU316
Bluetooth chipQualcomm QCC5181
Screen5.99" (1080x2160)
Battery9200mAh
Supported Bluetooth codecsReception : SBC, AAC, aptX, aptX Lossless, aptX HD, aptX Adaptive, LDAC
Transmission : SBC, AAC, aptX, aptX HD, aptX Adaptive, LDAC, LHDC
Supported sampling ratesLocal reading / USB : PCM 32bit 768kHz / DSD512
Coaxial : PCM 24bit 384kHz / DSD128
Optical : PCM 24bit 192kHz
WiFiWiFi 2.4GHz/5GHz
DLNA
AirPlay
Balanced output power5000mW + 5000mW @32Ω THD+N<1% 12.7Vrms Ultra high gain mode
2250mW + 2250mW @32Ω THD+N<1% 8.5Vrms Super high gain mode
805mW + 805mW @300Ω THD+N<1% 15.5Vrms Ultra high gain mode
320mW + 320mW @300Ω THD+N<1% 7.6Vrms Super high gain mode
Single-ended output power1800mW + 1800mW @32Ω THD+N<1% 7.6Vrms Ultra high gain mode
660mW + 660mW @32Ω THD+N<1% 4.6Vrms Super high gain mode
200mW + 200mW @300Ω THD+N<1% 7.8Vrms Ultra high gain mode
80mW + 80mW @300Ω THD+N<1% 4.9Vrms Super high gain mode
Frequency response20Hz - 85kHz
Signal-to-noise ratio (SNR)≥ 127dB
Background noise< 1.9µV
Total harmonic distorsion more noise (THD+N)0.0027%
Crosstalk≥107dB
Line output level4.2Vrms
Dimensions157.4 x 85 x 28mm
Weight556g
Package1x FiiO M27
1x Protective case
1x Storage bag
1x Desk stand
1x USB-C to USB-C cable
1x USB-C to Lightning cable
1x USB-A to USB-C adapter
Download
FIIO M27 Digital Audio Player DAP 2x ES9039SPRO Bluetooth 5.4 32bit 768kHz DSD512
The FiiO M27 is a high-end audiophile music player designed to deliver high-resolution audio playback, utilising advanced digital and analogue...
