FIIO M33 R2R Digital Audio Player DAP R2R
The FiiO M33 R2R is an audiophile portable music player based on discrete R2R conversion, designed to play and process high-resolution audio streams in both portable and stationary settings. It delivers 2x 1100mW into 32Ω, utilising a balanced architecture and a network of resistors calibrated to 0.1% to ensure stable conversion and consistent reproduction across the entire spectrum.
By buying this product you get 64 loyalty points
Reference : 21679
649,00 €tax incl.
540,83 € tax excl.
Shipping date: 26-11-2026.
FiiO M33 R2R Digital Audio Player DAP R2R XMOS XU316 Bluetooth 5.0 WiFi DLNA AIrPlay 32bit 768kHz DSD512 Black
FiiO M33 R2R : Front view
Designed for versatile use combining local playback, streaming and USB DAC functionality, it features a smooth Android 13 platform with WiFi and Bluetooth backed by sophisticated digital processing, enabling playback of files up to 32bit 768kHz PCM and DSD512. This approach enables it to occupy a central position in a mobile or hybrid audio system, whilst maintaining rigorous signal management, from processing right through to amplification.
FiiO M33 R2R: R2R DAC
The M33 R2R is based on a discrete architecture comprising 192 resistors matched to 0.1% tolerance and featuring low thermal drift, which stabilises the conversion over time whilst minimising linearity deviations between channels. This approach ensures consistent reproduction across the entire spectrum, whilst the precision of the components reduces the quantisation errors typical of R2R networks. In addition to this hardware foundation, two sound profiles are available: a Flat mode favouring a neutral and linear response, whilst the Warm mode slightly shifts the sound towards denser timbres, allowing the sound to be adapted to different headphones or listening preferences.
FiiO M33 R2R : DAC R2R
FiiO M33 R2R : Snapdragon 680 processor
FiiO M33 R2R: Snapdragon 680 processor
The processing is handled by a 6nm-processed Snapdragon 680 octa-core processor, combining four cores running at 2.4GHz and four others at 1.9GHz, which effectively balances raw performance with power management. This architecture is complemented by 8GB of RAM, allowing audio applications and system services to remain in memory without any noticeable slowdown. This combination enables Android 13 to run smoothly, whilst ensuring stable playback of high-definition streams and streaming apps.
FiiO M33 R2R: XMOS interface
The USB interface is based on an XMOS XU316 controller, whose processing power enables it to handle PCM streams up to 32bit  768kHz as well as native DSD512. This integration ensures controlled asynchronous transmission, reducing synchronisation errors whilst preserving the integrity of the digital signal. This approach results in extensive compatibility with external sources, allowing the M33 to function as a USB DAC with no limitations on high-resolution formats.
FiiO M33 R2R : XMOS
FiiO M33 R2R: DAPS treatment
The M33 R2R incorporates the proprietary DAPS (Digital Audio Purification System), which utilises a latest-generation FPGA coupled with femtosecond crystal oscillators to ensure jitter-free digital signal transmission. This architecture stabilises the signal stream prior to conversion, resulting in a more coherent sound reproduction, particularly in terms of micro-details and spatialisation.
FiiO M33 R2R : DAPS treatment
FiiO M33 R2R : EQ
FiiO M33 R2R: 10-band equaliser
The device features a 10-band equaliser that allows for fine-tuning of the frequency response, offering precise control over the sound output to suit your preferences or the characteristics of the headphones being used. This flexibility is enhanced by the inclusion of built-in presets, allowing you to quickly adjust the sound whilst retaining a customisable foundation for your settings.
FiiO M33 R2R: Balanced amplification
The output stage utilises four INA1620 amplifiers, configured in a balanced topology to deliver 2x 1100mW under 32Ω. This configuration improves channel separation and minimises internal interference, thereby maintaining a well-defined soundstage even at high volumes. This available power allows for the driving of both low-sensitivity headphones and high-impedance models without any loss of dynamic control.
FiiO M33 R2R : Amplification diagram
FiiO M33 R2R: Segmented power supply circuit
The M33 features a power supply architecture that separates the analogue and digital sections, thereby limiting the propagation of switching noise to the most sensitive stages and thus preserving the stability of the audio signal. This functional separation is complemented by three dedicated circuits for the R2R DAC, the preamplifier and the power amplifier stage respectively, allowing the power supply conditions to be precisely tailored to the specific requirements of each section. This targeted distribution helps maintain clean and constant voltages, resulting in clearer reproduction and better control of micro-details in real-world use.
FiiO M33 R2R : Power supply diagram
FiiO M33 R2R: Shielded design
Each internal section features specific shielding designed to contain electromagnetic interference and reduce crosstalk between circuits. This physical isolation complements the electronic architecture, ensuring signal integrity is maintained throughout the internal signal path. This approach results in improved channel separation and reduced noise interference under real-world operating conditions.
FiiO M33 R2R : shielded internal modules
FiiO M33 R2R : 4400mAh battery
FiiO M33 R2R: 4400mAh battery
The power supply is provided by a 4400mAh battery offering up to 15.5 hours of continuous playback, allowing for extended use without frequent recharging. It supports 30W fast charging via the PD 2.0 and PD 3.0 PPS protocols. This is complemented by a Desktop mode that bypasses the battery when the device is plugged into the mains, thereby reducing wear and tear over time.
Product typeDigital Audio Player (DAP)
Inputs1x USB-C
1x microSD slot (2To)
Bluetooth
WiFi
Outputs1x Balanced headphone/line jack 4.4mm output
1x Single-ended headphone/line Jack 3.5mm output
1x USB-C
Bluetooth
DACR2R
SoCQualcomm Snapdragon 680
Internal memory8Go RAM + 128Go ROM
USB interfaceXMOS XU316
Screen5.5" (1080x2160)
Battery4400mAh
Supported Bluetooth codecsReception: SBC, LDAC
Transmission: SBC, aptX, aptX HD, LDAC, LHDC
Supported sampling ratesLocal reading: PCM up to 32bit 384kHz, DSDS up to DSD256
USB: PCM up to 32bit 768kHz, DSD up to DSD512
Coaxial: PCM up to 32bit 384kHz, DSD up to DSD128
WiFi2.4GHz/5GHz, DLNA, AirPlay
Balanced output power1100mW + 1100mW @ 32Ω THD+N <1% 6Vrms Super high gain mode
900mW + 900mW @ 32Ω THD+N <1% 5.4Vrms High gain mode
240mW + 240mW @ 300Ω THD+N <1% 8.5Vrms Super high gain mode
165mW + 165mW @ 300Ω THD+N <1% 7Vrms High gain mode
Single-ended output power470mW + 470mW @ 32Ω THD+N <1% 3.9Vrms Super high gain mode
300mW + 300mW @ 32Ω THD+N <1% 3.1Vrms High gain mode
Frequency response20Hz - 40kHz
Signal-to-noise ratio (SNR)≥ 117dB
Background noise< 5.5µV
Total harmonic distorsion more noise (THD+N)PCM: 0.0183%
DSD: 0.0033%
Crosstalk≥ 74dB
Line output levelBalanced: 4Vrms
Single-ended: 2Vrms
Dimensions138 x 71.5 x 17mm
Weight258g
Package1x FiiO M33 R2R
1x Protective case
1x USB-C cable
MERVEILLE
Reçu ce jour, alors déjà MERCI a Audiophonics qui, comme d'habitude, déboite tout sur les délais de livraison, et même pour ce FIIO en précommande ! Déballage, le bestiau est plus grand de 0.5 pouces que mon Fiio M11S, revendu pour financer le M33 ;) Bref, on allume, mise en route, c'est hyper fluide, connexion wifi, carte micro SD. On installe Tidal. On branche les IEM FIIO FH3, et aussi pour après le FIIO FT1 Pro. MAZETTE ! Quel son !!! C'est aussi précis que le 11s MAIS ça RESPIRE, ça a du corps dans les notes, les instruments. Sur la BOF de Dans avec les loups, l'attaque des Pawnees devient fantastique. Les peaux des grosses caisses sont palpables, tout simplement. Sur L'album des lockdown sessions de Waters pendant la covid, les voix sont sublimées, tant la sienne (pourtant de plus en plus "gutturale"), que celles des choristes. Les cordes de guitare sonnent avec rondeur, on perçoit physiquemeent les pincements, le frottement, c'est incroyable. Pas encore testé sur mon ampli a tube prima luna mais ça promet ! Et je suis loin d'avoir fait le tour de tout les réglages (vu que c'était tellement bon que j'ai piqué un roupillon !) même si je ne met jamais d'équalizer pour ma part. Les différences entre le mode pur et enhanced sont bien perceptibles, je préfère le pur pour classique, jazz ou voix (youn sun nah) mais le enhanced sur du rock c'est a tester car pas mal du tout. en tout cas, zero fatigue auditive, moi qui suis sensible aux aigus trop brillants... Le mode bureau va préserver la batterie, ce que ne permettait pas le M11S, d'autant que quand il était en charge avec écoute audio, ça ronflait dans les enceintes de l'ampli a tubes pendant les pauses de musique (lecture sur pause, pas pendant les blancs d'un morceau). Seul HIC, la protection installée d'origine sur le lecteur ne donne que peu de relief aux touches de commande, un peu galère a manipuler dans le noir ou les yeux fermés quand on plane sur une musique. Sur le m11S, elles étaient facilement perceptibles au touche, c'était bien mieux. Fallait bien un défaut ;)
MERCI FIIO ET AUDIOPHONICS!!!
This review has been posted for FIIO M33 R2R Digital Audio Player DAP R2R XMOS XU316 Bluetooth 5.0 WiFi DLNA AIrPlay 32bit 768kHz DSD512 Black
The FiiO M33 R2R is an audiophile portable music player based on discrete R2R conversion, designed to play and process high-resolution audio...
