By buying this product you get 94 loyalty points
The iBasso DX260MK2, the brand's new digital audio player, is a true concentrate of technology. Featuring a perfectly optimized design and audiophile-grade components, it offers a beautifully rich listening experience. Its new interface guarantees intuitive, fluid navigation and seamless operation.
The iBasso DX260MK2 features 8 high-end Cirrus Logic CS43198 DAC chips. These offer excellent performance, with a wide dynamic range, incredible reproduction of micro-detail and extremely low noise floor.
This Octa DAC matrix and its integration guarantee both superb sound quality and exceptional measurements with a THD+N of up to -123dB.
After years of development work on a high-performance algorithm, the FPGA-Master has now reached version 2.0. As an audio controller, it retrieves audio data directly from the SoC and plays a major role in reproducing the signal and maintaining its integrity. It synchronizes and generates all audio clocks using two NDK femtosecond oscillators for total synchronization of clock sources. The FPGA-Master 2.0 also features extremely precise control and adjusts the DAC clock, data and builds the FIR filter.
Thanks to the new FPGA-Master 2.0 algorithm, the potential of the 8 CS43198 DACs is maximized.
Parallel synchronous output mode :
Reduces distortion between DAC chips to improve overall performance.
FIR 2x mode, FIR 4x mode :
With FPGA-Master 2.0, picosecond control and precise adjustment of the DAC clock is implemented, allowing independent adjustment for each conversion chip. Through this architecture, the DACs form an analog FIR filter that reduces distortion while improving sonic accuracy.
At the heart of the iBasso DX260MK2 is a Qualcomm Snapdragon 665 processor, 4GB RAM and 128GB ROM. This design ensures smooth operation.
The DX260MK2 benefits from an OS based on Android 13, enabling the installation of numerous streaming applications. The DX260MK2 effectively bypasses SRC at system level. Whether with its Mango player or a third-party streaming application, you can enjoy exceptional sound quality.
The iBasso DX260MK2 also uses Mango OS, a Linux audio system meticulously designed to deliver excellent playback performance. Over time, this system has benefited from numerous optimizations to its algorithms, focusing on audio playback. Resolutely audiophile, this system generates no WiFi or Bluetooth interference, has very low EMI levels and offers a pure listening experience.
With its dedicated USB receiver, the DX260MK2 can also be used as a low-latency USB DAC. It also supports ASIO / WASAPI drivers, so you can easily enhance your computer's sound reproduction.
The new Mango player interface offers a revamped design and an optimized user experience. Navigation is fluid and intuitive, and the DAP is a pleasure to use.
Based on the design of the DX260, the DX260MK2 sports an industrial look. Its rear panel can be removed, providing access to the battery for easy replacement.
| Specifications | |
| Product type | Digital audio player (DAP) |
| Touchscreen | IPS Sharp 5", 1080x1920px |
| Audio formats | APE, FLAC, WAV, WMA, ACC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, DST |
| Connectivity | USB-C 3.1 |
| Inputs | WiFi Bluetooth Micro SD USB DAC |
| Outputs | Jack 4.4mm balanced headphone output Jack 3.5mm single-ended headphone output Jack 4.4mm line output Jack 3.5mm line outpuit Jack 3.5mm coaxial output USB OTG output |
| WiFi | 802.11b/g/n/ac (2.4GHz/5GHz) |
| Bluetooth | 5.0 |
| RAM | 4Go LPDDR4X |
| ROM | 64Go |
| Battery | LiPo 3.8V 4400mAh |
| Charging time | 2.5h |
| Average playback lifetime | 14h (may vary depending on the files played, the volume used and the impedance of the headphones/earphones) |
| Jack 4.4mm balanced headphone output measurements | |
| Max output level | 6Vrms |
| Output power | 2x1015mW @ 32Ω, THD < 0.5% |
| Frequency response | 10Hz ~ 75kHz (-1dB) |
| SNR | 133dB |
| Dynamic range | 133dB |
| THD+N | -121dB (A-wt, 600Ω) -114dB (A-wt, 32Ω) |
| Crosstalk | 145dB |
| Noise floor | < 930nV (gain faible) |
| Jack 3.5mm single-ended headphone output measurements | |
| Max output level | 3Vrms |
| Output power | 2x280mW @ 32Ω, THD < 0.5% 2x586mW @ 16Ω, THD < 0.1% |
| SNR | 128dB |
| Dynamic range | 128dB |
| THD+N | -115dB (A-wt, 600Ω) -110dB (A-wt, 32Ω) |
| Crosstalk | 118dB |
| Noise floor | < 850nV (gain faible) |
| Jack 4.4mm balanced line output measurements | |
| Max output level | 4Vrms |
| SNR | 133dB |
| Dynamic range | 134dB |
| THD+N | -123dB |
| Crosstalk | 145dB |
| Jack 3.5mm single-ended line output measurements | |
| Max output level | 2Vrms |
| SNR | 128dB |
| THD+N | -112dB |
| Crosstalk | 115dB |
| General | |
| Dimensions | 123 x 74.5 x 17.5mm |
| Weight | 229g |
| Color | Silver |
| Package | 1x iBasso DX260MK2 1x USB-C cable 1x Coaxial cable 1x TPU cover 1x Screen protections |
| Input | Bluetooth |
| Input | WiFi |
| Input | Micro SD |
| Output | Jack 4.4mm |
| Output | Jack 3.5mm |
| Output | USB |
| DAC / ADC Chip | CS43198 |
| Max sampling rate | DSD256 |
| Color | Silver |
