FOSI AUDIO C3 DAC Headphone Amplifier
The Fosi Audio C3 is a DAC with integrated headphone amplifier designed for high-resolution conversion and dedicated amplification in a gaming environment. It supports high-resolution streams up to PCM 32bits 384kHz and DSD256 via its USB-C interface, relying on an XMOS XU316 architecture combined with a CS43131 chip in order to produce a detailed and stable signal, while the optical and coaxial inputs allow extended use with other sources in PCM 24bits 192kHz.
Reference : 22046
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 24-11-2026.
Fosi Audio C3 DAC Headphone Amplifier CS43131 XMOS XU316 2xTPA6120 20Hz-20kHz 32bit 384kHz DSD256
Thumbnail of the Fosi Audio C3
Designed for gaming and multimedia use, it combines headphone amplification, audio processing and accessible adjustments, allowing improved perception of useful in-game sounds while adapting the rendering to user preferences. This approach extends with two TPA6120 amplifiers delivering up to 2x320mW under 32Ω, ensuring compatibility with headphones from 16 to 300Ω, while spatialization functions and equalization via application facilitate integration into a setup focused on immersion and sound precision.
Fosi Audio C3: Performance and Amplification
The Fosi Audio C3, thanks to its XMOS XU316 USB interface and CS43131 DAC chip, supports high-resolution audio streams up to PCM 32bits 384kHz and DSD256 via its USB-C input. The Toslink optical and SPDIF coaxial inputs support PCM up to 24bits 192kHz. The C3 thus provides an audiophile listening experience with faithful reproduction of details.
The circuit integrates two TI TPA6120 chips, allowing its 3.5mm jack headphone output a power of 2x320mW under 32Ω, enabling it to drive a wide range of headphones and earphones while revealing subtle details in gaming audio.
Image showing the chips of the Fosi Audio C3
Image showing the equalizer of the Fosi Audio C3
Fosi Audio C3: Gaming-oriented Features
Primarily designed for gaming use, the C3 integrates the StepSense™ feature allowing improved detection and amplification of footsteps, combined with multichannel support via activation of 7.1 audio enabling better distance perception and enhanced immersion.
To support these features, the C3 is compatible with a web application allowing configuration through presets or via equalization controls.
Overview of the Fosi Audio C3
1AI Noise reduction switch (ANC)
2USB power input
3Optical input
4Coaxial input
5RCA output
6Indicators
7On / Off / Input mode selector
8Microphone mute button
9UAC mode selector
10FPS / 7.1 selector
11Main volume control
12Microphone level control
133.5mm jack headphone and microphone
Technical specifications
Product typeDAC
Headphone amplifier
USB interfaceXMOS XU316
DAC chipCirrus Logic CS43131
Amplification chips2x Texas Instrument TPA6120
Inputs1x USB-C (Power and Data)
1x Optical Toslink
1x Coaxial
1x 3.5mm Jack microphone input
Outputs1x Stereo RCA line output
1x 3.5mm Jack headphone output unbalanced
Supported sample ratesUSB: PCM up to 32bit 384kHz, DSD up to DSD256
Optical Toslink / Coaxial: PCM up to 24bit 192kHz
Recommended headphone impedance16-300Ω
3.5mm Jack unbalanced headphone output
Output powerL+ R ≥ 2x 320mW (32Ω/THD+N<1%)
SNR123dB
THD+N< 0.0004%
Dynamic range123dB
Noise level≤ 3μV
Frequency response20Hz-20kHz (±0.06dB)
RCA line output
Output level≥ 2Vrms
SNR124dB
THD+N< 0.0005%
Dynamic range124dB
Noise level≤ 3μV
Frequency response20Hz-20kHz (±0.1dB)
Power supply5V DC
Dimensions94 x 93.8 x 43.8mm
Package contents1x Fosi Audio C3
1x USB-A/C to USB-C cable
1x 3.5mm Jack Y-split cable
InputJack 3.5mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
ClassClass A / AB
Remote ControlControl app
FOSI AUDIO C3 DAC Headphone Amplifier CS43131 XMOS XU316 2xTPA6120 20Hz-20kHz 32bit 384kHz DSD256
The Fosi Audio C3 is a DAC with integrated headphone amplifier designed for high-resolution conversion and dedicated amplification in a gaming...
