SMSL VMV P2 MK2 Headphone Amplifier Preamplifier
The SMSL VMV P2 MK2 is a headphone amplifier designed to deliver high power whilst maintaining linear signal response. It delivers up to 14 W into 16 Ω, utilising a 99-channel op-amp array combined with a balanced topology to provide high current output whilst minimising common-mode noise.
By buying this product you get 119 loyalty points
Reference : 21929
1 190,00 €tax incl.
991,67 € tax excl.
Shipping date: 01-12-2026.
SMSL VMV P2 MK2 Balanced Headphone Amplifier Preamplifier
SMSL P2 MK2 : Front view
The SMSL VMV P2 MK2 is a headphone amplifier designed to deliver high power whilst maintaining linear signal response. It delivers up to 14W under 16Ω, utilising a 99-channel op-amp array combined with a balanced topology to provide high current output whilst minimising common-mode noise.
It combines three-stage gain control with a proprietary PLFC+ feedback circuit, which linearises the signal whilst stabilising the amplification, resulting in reduced distortion and low background noise. This approach is complemented by a high-frequency GaN switching power supply, which contributes to overall operational stability, whilst allowing for use as a preamplifier thanks to its dedicated analogue outputs.
SMSL VMV P2 MK2: 99 OPA matrix
The SMSL VMV P2 MK2 utilises a matrix of 99 operational amplifiers arranged in a symmetrical configuration to deliver up to 14W under 16Ω, thereby providing high current whilst minimising common-mode noise interference. This output stage configuration ensures a stable power supply to demanding loads, resulting in the ability to drive low-sensitivity headphones without loss of dynamic range or signal compression.
This approach is complemented by the integration of the proprietary PLFC+ feedback circuit, which linearises the signal in real time whilst stabilising the gain, thereby reducing distortion components without compromising the overall stability of the amplification. Adjustment via three gain levels extends this logic by precisely adapting the behaviour of the output stage to the impedance and sensitivity of the headphones, ensuring consistent performance across the volume range.
SMSL P2 MK2 : OPA matrix
SMSL P2 MK2 : GaN power supply
SMSL VMV P2 MK2: GaN switching power supply
The power supply is based on a switching topology utilising GaN transistors, whose high switching frequency shifts noise residues beyond the audible range, thereby limiting their interaction with the analogue stages. This increase in frequency is accompanied by improved energy efficiency, which reduces thermal losses whilst stabilising the output voltage during load variations.
SMSL P2 MK2: Preamplifier function
The P2 VMV MK2 features a preamplifier section that allows its volume control to be used upstream of a power amplifier, whilst maintaining the integrity of the signal processed by its analogue stage. To achieve this, it utilises balanced XLR and single-ended RCA outputs, enabling it to be adapted to a variety of installation environments.
SMSL P2 MK2 : with speaker
Product typeHeadphone Amplifier
Preamplifier
Inputs1x Stereo XLR
1x Stereo RCA
Outputs1x Stereo XLR
1x Stereo RCA
1x Jack 4.4mm
1x Jack 6.35mm
1x XLR 4 pins
Balanced output power2x14W @16Ω
2x8W @32Ω
2x1W @300Ω
2x500mW @600Ω
Single-ended output power2x4W @16Ω
2x2W @32Ω
2x300mW @300Ω
2x150mW @600Ω
Signal-to-noise ratio (SNR)135dB
Dynamic range135dB
Total harmonic distortion more noise (THD+N)-123dB
0.00006%
Input impedance47kΩ
Amplified output impedance→0Ω
Pre-out output impedanceBalanced : 44Ω
Single-ended : 22Ω
Frequency response20Hz-100kHz (-0.5dB)
Balanced output gainLow : -3dB
Mid : +6dB
High : +24dB
Single-ended output gainLow : -9dB
Mid : 0dB
High : +18dB
Power supply100-240V AC
Consumption≤100W
Dimensions280 x 51 x 235.7mm
Weight3.25kg
Package1x SMSL VMV P2 MK2
1x Power cable
InputXLR
OutputJack 4.4mm
OutputJack 6.35mm
ClassN/A
The SMSL VMV P2 MK2 is a headphone amplifier designed to deliver high power whilst maintaining linear signal response. It delivers up to 14 W into...
