TOPPING EHA5 Electrostatic Headphone Amplifier Balanced
Most electrostatic headphones offer excellent musical potential, but their performance is often limited by the associated headphone amplifier. The Topping EHA5 electrostatic headphone amplifier helps your headphones to reach their full potential, with detailed and dynamic sound reproduction.
By buying this product you get 44 loyalty points
Reference : 17617
449,00 €tax incl.
374,17 € tax excl.
Last items in stock !
Shipping date: 08-07-2025.
Topping EHA5
Electrostatic Headphone Amplifier Balanced 700Vrms
Topping EHA5 Amplificateur casque électrostatique symétrique 700Vrms
This headphone amplifier will work perfectly with STAX electrostatic headphones or even Kingsound.
An incredible reserve of energy
Topping's EHA5 offers a large power reserve to accompany demanding electrostatic headphones. With an output level of 700Vrms and 2000Vp-p, it will have no trouble driving the vast majority of headphones with efficiency.
12V Trigger
The Topping EHA5 provides a 12V trigger input that can be connected to other devices to automatically turn the amplifier on and off. It allows a practical and fluid use to enjoy the best of your music.
Pass-through feature
When the headphone output of the EHA5 is switched off, the input signal is routed directly to the balanced XLR and single-ended RCA outputs at the rear. This allows the EHA5 to be used with electrostatic headphones as well as with other audio devices with a preamp function.
1Output selection
2Gain selection
3Headphone output
4Volume button
5Balanced input
6Single-ended input
7Balanced output
8Single-ended output
9ON/OFF switch
1012V trigger input
11USB-C input for firmware update
12Power input
Inputs1* Balanced stereo XLR / Jack 6.35mm
1* Single-ended stereo RCA
Outputs1* Headphone output
Trigger12V input
Measurements
InputSingle-endedBalanced
THD+N @ 1kHz (A-weighted)< 0.0009% @ 100Vrms
THD+N @ 20kBw (No-weighted)< 0.07%< 0.05%
SNR @ Max out, 1kHz (A-weighted)140dB146dB
Dynamic range @ 1kHz (A-weighted)140dB146dB
Frequency response20Hz-40kHz (±2.5dB)
Noise (A-weighted)< 35µVrms @ G=L
< 80µVrms @ G=H
Crosstalk @ 1kHz-89dB
Input sensitivity10Vrms @ G=L
2Vrms @ G=H
20Vrms @ G=L
3.9Vrms @ G=H
Gain36.8dB @ G=L
50.8dB @ G=H
30.9dB @ G=L
44.9dB @ G=H
Channel balance0.5dB
Output level700Vrms
Bias voltage580VDC
Dimensions (L*P*H)23.2*17.3*9.3cm
Package1* Topping EHA5
1* Power supply 15V DC
InputJack 6.35mm
InputXLR
ClassN/A
2 reviews
Good entry-level electrostatic amplifier
This amp is a good match for my STAX Lambda SR-300 headphones. It drives the headphones effortlessly. Sound quality is outstanding, especially for classical music - every instrument is rendered with clarity and precision.
This review has been posted for TOPPING EHA5 Electrostatic Headphone Amplifier Balanced
Works Well
I just moved to France and am setting up my sound system. I purchased this and Stax Lambda headphones for my new home audio system, and it works well and looks good. I can not compare it with the other electrostatic headphone amplifiers available for Stax headphones because I have not heard any of those available now, but this is a fraction of the cost and sounds clear and clean to me. I like the visual aesthetic (and the fake tube glow, which amuses me, but...I like it), and I am contented with this product's ability to drive my difficult-to-drive headphones.
Most electrostatic headphones offer excellent musical potential, but their performance is often limited by the associated headphone amplifier. The...
