TOPPING L50 Balanced Headphone Amplifier NFCA Black
The Topping L50 is a desktop headphone amplifier with an architecture optimized for incredible sound performance. It features a new generation NFCA circuit, based on the one used in the excellent A30 Pro. Versatile, it has a good power reserve and offers a gain control to adapt to all types of headphones.
Reference : 15586
169,00 €tax incl.
140,83 € tax excl.
Topping L50
Balanced Headphone Amplifier Preamplifier NFCA Black
Topping L50 Amplificateur Casque Préamplificateur Symétrique NFCA
NFCA Circuit
The L50's NFCA circuitry allows it to develop considerable power, twice that of the L30 at 300Ω impedance. This design also achieves a very low noise level of only 0.3µV, a dynamic range of 145dB and a THD+N of 0.00006%.
Single-ended & Balanced
The Topping L50 has both single-ended and balanced connectors to adapt to your listening equipment. It offers single-ended RCA and balanced 6.35mm TRS jacks as inputs. In the same way, at the output, we find a balanced XLR 4 poles and a single-ended 6.35mm jack.
Pass-through function
When the L50 is switched off, the input signal goes directly to the RCA and TRS outputs, without amplification. It can thus work with active speakers, if the DAC has a preamplification function.
Inputs1x Balanced stereo Jack 6.35mm TRS
1x Single-ended stereo RCA
Outputs1x Balanced XLR 4 poles headphone output
1x Single-ended Jack 6.35mm headphone output
Measurements
Single-endedBalanced
THD+N @ 1kHz, A-Weighting< 0.00006% @ 780mW, 32Ω< 0.00006% @ 780mW, 32Ω
< 0.00006% @ 333mW, 300Ω< 0.00006% @ 333mW, 300Ω
THD @ 20Hz-20kHz, 90kBW< 0.00008% @ 780mW, 32Ω< 0.0001% @ 780mW, 32Ω
< 0.00008% @ 76mW, 300Ω< 0.0001% @ 76mW, 300Ω
SNR @ Max Out, 1kHz, A-Weighting145dB140dB
SNR @ 50mV, 1kHz104dB104dB
Dynamic range @ 1kHz, A-Weighting145dB140dB
Frequency response20Hz - 40kHz (±0.05dB)20Hz - 40kHz (±0.1dB)
Output level35Vpp @ G=L6.6Vpp @ G=L
35Vpp @ G=M35Vpp @ G=M
37Vpp @ G=H37Vpp @ G=H
Measured noise level @ A-Weighting< 0.7µVrms @ G=L< 0.7µVrms @ G=L
< 0.7µVrms @ G=M< 0.7µVrms @ G=M
< 1.2µVrms @ G=H< 1.2µVrms @ G=H
Crosstalk @ 1kHz-119dB-113dB
Input sensitivity60Vrms @ G=L12.7Vrms @ G=L
12Vrms @ G=M12Vrms @ G=M
2.7Vrms @ G=H2.7Vrms @ G=H
Gain-14.3dB @ G=L-14.5dB @ G=L
-0.1dB @ G=M-0.3dB @ G=M
13.9dB @ G=H13.7dB @ G=H
Output impedance< 0.1Ω< 0.1Ω
Output power2x 3500mW @ 16Ω, THD+N < 0.1%
2x 2800mW @ 32Ω, THD+N < 0.1%
2x 2000mW @ 64Ω, THD+N < 0.1%
2x 540mW @ 300Ω, THD+N < 0.1%
2x 290mW @ 600Ω, THD+N < 0.1%
Adapter impedance> 8Ω
Power supply15V AC via Jack DC (included)
Dimensions129 x 166 x 41mm
Package1x Topping L50 Black
1x Jack 6.35mm to Jack 3.5mm adapter
1x Power Supply 15V AC
Topping L50 Amplificateur Casque Symétrique NFCA Topping L50 Amplificateur Casque Symétrique NFCA
InputJack 6.35mm
OutputJack 6.35mm
ClassN/A
2 reviews
rapport qualité prix imbatable
Topping fait très fort comme d'habitude... Il y a plus cher mais c'est moins bien !!!
Un seul mini regret: le "pass-through" ne fonctionne que lorsque l'ampli est éteint.
This review has been posted for TOPPING L50 Balanced Headphone Amplifier NFCA Black
Bon appareil
Testé en Jack TRS, pas en RCA, bon appareil bien fini.
Le sélecteur de gain est appréciable, je suppose pour les écouteurs IEM, par exemple. Si je garde le gain le plus élevé pour des casques à rendement faible ou moyen et impédance moyenne ou élevée, par contre même avec des casques à impédance de 32 ohms ou à rendement moyen ou élevée, je préfère rester sur cette position même si le potentiomètre n'est utilisé qu'au début de sa course: la restitution est plus incarnée: en position de gain 0dB, la clarté est excellente mais je trouve un aspect montant et désincarné gênant.
Gestion de la commande par Audiophonics: sans souci
The Topping L50 is a desktop headphone amplifier with an architecture optimized for incredible sound performance. It features a new generation NFCA...
