XDUOO TA68 Balanced Preamplifier Headphone Amplifier
The xDuoo TA68 is a fully balanced audiophile headphone amplifier built around a true all-tube architecture designed to deliver a rich, natural and warm musical presentation.
By buying this product you get 155 loyalty points
Reference : 22363
1 559,00 €tax incl.
1 299,17 € tax excl.
XDUOO TA68 Balanced Tube Headphone Amplifier 5U4G/12AU7/6C19
XDUOO TA68
The xDuoo TA68 is a fully balanced audiophile headphone amplifier built around a true all-tube architecture designed to deliver a rich, natural and warm musical presentation. Its circuit features two 5U4G tubes dedicated to high-voltage rectification, two matched 12AU7 dual triodes for the preamplification stage, and four 6C19 power tubes handling the output amplification. The entire circuit is powered by two independent transformers providing complete isolation between the left and right channels. Compatible with headphones featuring an impedance between 60Ω and 600Ω, the TA68 delivers up to 330mW into 300Ω and provides two gain levels to accommodate different headphone models. Connectivity includes RCA, balanced 4.4mm jack and XLR inputs, along with 6.35mm jack, balanced 4.4mm jack and 4-pin XLR headphone outputs. Each channel features its own dedicated volume control for precise stereo balance adjustment. The unit employs audiophile-grade Nichicon and VISHAY capacitors, integrates an intelligent relay protection circuit with a 45-second warm-up delay at startup, supports tube rolling, and is housed in a robust sandblasted aluminum chassis measuring 33 × 30 × 18.5cm and weighing 11kg.
XDUOO TA68: A True All-Tube Architecture
The TA68 adopts a genuine all-tube architecture in which the entire signal path is handled by vacuum tubes. The two 5U4G tubes provide high-voltage rectification with an independent power supply for each channel, while the two 12AU7 tubes handle preamplification before four 6C19 tubes, two per channel, operate as the power and buffer stage. This design fully preserves the sonic characteristics unique to tube amplification, delivering a rich harmonic presentation with a smooth and natural sound.
XDUOO TA68: Fully Balanced Circuit and Dual-Transformer Power Supply
The xDuoo TA68 features a fully balanced signal path from the inputs to the headphone outputs, improving channel separation, reducing crosstalk and lowering the noise floor. Its power supply uses two low-noise, low-leakage transformers, each dedicated to a single channel, ensuring completely independent power delivery and excellent operational stability. The design is complemented by audiophile-grade Nichicon capacitors for power filtering and VISHAY capacitors dedicated to signal coupling.
XDUOO TA68: Comprehensive Connectivity and Audiophile Controls
The TA68 offers highly versatile connectivity with RCA, balanced 4.4mm jack and XLR inputs, as well as 6.35mm jack, balanced 4.4mm jack and 4-pin XLR headphone outputs. Its two independent volume controls allow precise adjustment of the left and right channel levels to compensate for any stereo imbalance. Two gain levels are available to match different headphones, while the intelligent relay protection circuit combined with a 45-second warm-up delay effectively protects both the tubes and the connected headphones during power-up.
XDUOO TA68 Overview
XDUOO TA68 Overview
1Left channel volume control
26.35mm headphone output
34-pin XLR headphone output
4Balanced 4.4mm headphone output
5Input selector
6Right channel volume control
7RCA input
8Balanced XLR input
9Balanced 4.4mm jack input
10100-240V AC power input
Technical Specifications
ArchitectureBalanced
Tubes5U4G / 12AU7 / 6C19
Inputs1x RCA input
1x Balanced XLR input
1x Balanced 4.4mm jack input
Outputs1x 6.35mm headphone output
1x Balanced 4.4mm headphone output
1x 4-pin XLR headphone output
Headphone output power (balanced outputs)120mW @ 75 ohms
160mW @ 150 ohms
200mW @ 250 ohms
330mW @ 300 ohms
240mW @ 600 ohms
Headphone output power (single-ended output)60mW @ 75 ohms
100mW @ 150 ohms
130mW @ 250 ohms
210mW @ 300 ohms
160mW @ 600 ohms
GainBalanced: 24dB
Single-ended: 18dB
Frequency response10Hz-80kHz (±0.5dB)
Channel separation80dB (Balanced)
71dB (Single-ended)
SNR116dB (Balanced, A-WT)
110dB (Single-ended, A-WT)
THD0.1% (1kHz @ 300 ohms)
Recommended headphone impedance60-600 Ohms
Power supply100-240V AC (Selectable via rear panel switch)
Dimensions33 x 30 x 18.5cm
Weight11kg
Package contents1x XDUOO TA68
1x AC power cable
InputXLR
InputJack 4.4mm
OutputJack 6.35mm
OutputJack 4.4mm
ColorSilver
ClassTube amp
XDUOO TA68 Balanced Preamplifier Headphone Amplifier with 5U4G/12AU7/6C19 Tubes
The xDuoo TA68 is a fully balanced audiophile headphone amplifier built around a true all-tube architecture designed to deliver a rich, natural and...
