Fosi Audio GR40 DAC Tube Preamplifier Headphone amplifier
Fosi Audio's GR40 is a versatile, compact stereo DAC and tube preamplifier, featuring full connectivity and Bluetooth 5.1. The digital-to-analog conversion section is based on an ESS9028Q2M DAC chip, and enables signal conversion up to PCM 32bit 384kHz and DSD256. Coupled with the tube preamplifier stage, the GR40 delivers the rich, warm sound characteristic of tube preamplifiers.
Reference : 20239
139,90 €tax incl.
116,58 € tax excl.
Shipping date: 08-07-2025.
Fosi Audio GR40 DAC ESS9028Q2M Tube Preamplifier 2x JAN5654W Headphone Amplifier Bluetooth 5.1 32bit 384kHz DSD256
Fosi Audio GR40 : 3/4 view
Fosi Audio's GR40 is a versatile, compact stereo DAC and tube preamplifier, featuring full connectivity and Bluetooth 5.1. The digital-to-analog conversion section is based on an ESS9028Q2M DAC chip, and enables signal conversion up to PCM 32bit 384kHz and DSD256. Coupled with the tube preamplifier stage, the GR40 delivers the rich, warm sound characteristic of tube preamplifiers. The whole unit is housed in an attractive, precision CNC-machined aluminum case.
Fosi Audio GR40: ESS9028Q2M DAC
Fosi Audio's GR40 features an ESS9028Q2M DAC chip for precise digital-to-analog conversion. This DAC supports audio streams up to PCM 32bit 384kHz and DSD256, guaranteeing faithful, detailed sound reproduction.
Fosi Audio GR40 : DAC chip
Fosi Audio GR40 : JAN5654W tubes
Fosi Audio GR40: Tube preamplification & Tone control
The GR40's preamplifier stage is based on two JAN 5654W tubes. The use of tube amplification technology gives the sound reproduction a warm, rich timbre, ideal for rediscovering your favorite tunes in a new light.
The Fosi Audio GR40 also features a 3.5mm headphone output, capable of delivering 300mW at 16 Ohm or 40mW at 300 Ohm.
In addition, two buttons on the front panel provide access to tone control. This makes it quick and easy to adjust bass and treble levels to suit your listening style and audio system.
Fosi Audio GR40: Puce Bluetooth 5.1 QCC3031
The GR40 integrates Bluetooth 5.1 connectivity thanks to the Qualcomm QCC3031 chip, offering high-quality wireless broadcasting. Compatible with aptX, aptX HD, aptX Low Latency, SBC and AAC codecs, the GR40 ensures an optimal sound experience even when wireless.
Fosi Audio GR40 : QCC3031 Bluetooth chip
Product typeDAC
Preamplifier
Headphone amp
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth 5.1
Outputs1x Stereo RCA
1x Jack 3.5mm headphone output
ChannelsStereo (2)
SNR103dB
Dynamic range104dB
THD≤ 0.03%
Headphone impedance32Ω-300Ω
Headphone output power300mW @ 16Ω
250mW @ 32Ω
50mW @ 250Ω
40mW @ 300Ω
Frequency response20Hz-20kHz (±1dB)
DSD up to DSD256
Bluetooth chipsQualcomm QCC3031
Bluetooth version5.1
Max Bluetooth range10m (clear of obstacles)
Supported Bluetooth codecsaptX, aptX HD, aptX Low Latency, SBC, AAC
Supply voltage12V DC
Dimensions200 x 180 x 60mm
Weight800g
Package1x Fosi Audio GR40
1x Bluetooth antenna
2x JAN5654W tubes
2x Decorative rings
1x Power adapter
OutputJack 3.5mm
DAC / ADC ChipES9028Q2M
Max sampling rate384kHz
Max sampling rateDSD256
ClassTube amp
FOSI AUDIO GR40 DAC ESS9028Q2M Tube Preamplifier 2x JAN5654W Headphone Amplifier Bluetooth 5.1 32bit 384kHz DSD256
Fosi Audio's GR40 is a versatile, compact stereo DAC and tube preamplifier, featuring full connectivity and Bluetooth 5.1. The...
