LHY AUDIO UIP-LITE USB 2.0 Isolator and Purifier
New
The LHY Audio UIP-Lite is a USB 2.0 isolator designed to physically separate a source, computer or streamer, from a DAC, while maintaining high-speed audio data transmission. Based on the ADuM3165 chip, with 3.75 kV RMS isolation, it supports a 480 Mbps data rate and streams up to DSD512 and PCM 768kHz.
Reference : 22693
219,00 €tax incl.
182,50 € tax excl.
LHY Audio UIP-Lite USB 2.0 Isolator and Purifier
LHY AUDIO UIP-LITE: Front view
The LHY Audio UIP-Lite is a USB isolator 2.0 designed to physically separate a source, computer or streamer, from a DAC, while maintaining high-speed audio data transmission. Based on the ADuM3165 chip, with 3.75kV RMS isolation, it supports a 480Mbps data rate and streams up to DSD512 and PCM 768kHz.
Its power supply, regulated by LT3042 and PNP, delivers noise below 1μV at idle and 20μV under a 2A load; secondary stabilization accompanies the 5V 3A output. This architecture aims to limit interference from USB power, while a ground switch allows selection between isolated ground and connected ground in order to address ground loops responsible for hum or buzz.
A low-jitter silicon oscillator contributes to the timing accuracy of the signal. Compatible with computers, streamers, USB DACs and USB flash drives, the UIP-Lite is placed between the source and the USB device to isolate their link while ensuring audio data transfer.
Technical specifications
Product typeUSB isolator
Inputs1x USB-B
Outputs1x USB-A
Supported sampling ratesPCM up to 768kHz
DSD up to DSD512
Supply voltage220~240V AC
Dimensions115 x 110 x 63mm
Weight1.1kg
Package1x LHY Audio UIP-Lite
1x USB-A to USB-B cable
1x Main cable
OutputUSB
Max sampling rateDSD512
Max sampling rate768kHz
Interface chipADUM4165
The LHY Audio UIP-Lite is a USB 2.0 isolator designed to physically separate a source, computer or streamer, from a DAC, while maintaining...
