WONDOM ADAU1701 DSP Active Audio Crossover with RCA daughter board option
Reference : 11213
31,90 €tax incl.
26,58 € tax excl.
Wondom ADAU1701
Compact DSP Module for Active Filtering RCA Board
This flexible DSP Audio SURE ADAU 1701 allows great possibilities for digital filtering and equalization processing in a very compact integrated format. An ideal device for DIY use to build compact 2.1 active speakers (with subwoofer filtering), acoustic correction for multimedia terminals, IN-WALL ceiling sound system equalized according to the room.
The DSP ADAU1701 can also be used to filter CAR Audio/boat speakers or subwoofer design. With a simple RCA JACK stereo connection and two RCA Jack outputs (optional card not included) and a filtered Subwoofer output, this filter can be easily integrated into any mounting requiring strong integration in a limited space. The interface is programmable by I2C connector with Sigma Studio software (Analog Device processor).
Note: In the "Download" tab of this page, you will find a PDF showing all the operating possibilities of the ADAU1701 processor as well as the complete technical diagram of the device.
This module is programmable in USB with the Wondom DB-DP11224 evaluation board.
Sigma Studio User Guide
Find on our blog a complete guide to discover the features of Sigma Studio software and learn how to use it to make an effective correction to your system.
Tutoriel Sigma Studio
Wondom ADAU1701 Compact DSP Module for Active Filtering RCA Board
RCA Board
The DSP ADAU1701 comes with an extension board, providing an analog RCA input and output, a 3.5mm Jack input and output, an RCA Subwoofer output and a 4-pin Molex input and output.
Product typeDSP Board for 2.1 speakers filtering
InputStereo on pins connector
OutputsPins connector
Subwoofer filtered filtered output
Programmation toolSigma Studio Tools
4 potentiometers for assignable functions-
Power supply5V via USB-C not included
Dimensions50 x 44.5mm
Package1x Wondom ADAU1701
1x RCA daughterboard
1x Interconnecting cable
Screws and spacers
Correspondence table of pins
Software Interface
InputPCB Connector
OutputJack 3.5mm
OutputPCB Connector
OutputMolex
Max sampling rateNC
Interface chipNC
4 reviews
100%
Simple et efficace, on trouve plein de tuto partout, un must pour chaque DIYer !
This review has been posted for WONDOM ADAU1701 DSP Active Audio Crossover with RCA daughter board option
Impressionnant
J'ai acheté ce DSP pour tester son potentiel en égalisation par convolution avec utilisation de fichiers issus de REPHASE afin d'envisager son utilisation en tandem ou en remplacement des mes DCX2496. Ne connaissant pas ce type de matériel, la prise en main m'a demandé un peu de persévérance mais le résultat est à la hauteur. Les possibilités de programmation sont impressionnantes et l’AUTO-EQ fait pratiquement jeu égal avec celui de ROOM EQ WIZARD.
Dans un premier temps j'utilise le DSP en écoute comparative avec EQUALIZER APO sur ordinateur avec carte son ZOOM UAC2, ampli SMSL SA-98E et enceintes DAVIS EVA.
En partant de l'égalisation d'une même mesure effectuée avec REW, les premières écoutes sont très encourageantes. La seule limitation de ce DSP est le nombre de TAPS utilisable. Sur une égalisation paramétrique cela ne pose pas de problème mais par convolution cela nécessite d'utiliser un module par voie.
Les difficultés que j'ai rencontrées sont:
- Il n'existe pas de manuel d'aide
- La syntaxe des lignes d'entête des fichiers à importer dans l'AUTO-EQ
- La position des switchs en phase de programmation et d'utilisation du DSP
- L'utilisation du driver USB dû au fait qu'il faut connecter la carte de programmation à l'ordinateur puis connecter le DSP à la carte de programmation. Je n'ai pas testé si la position des switchs a une influence sur ce point.
Il est à noter qu'il faut éviter d'utiliser un port USB de l'ordinateur pour alimenter le DSP sous peine de rencontrer des bruits parasites non négligeables.
petit dsp mais gros potentiel
Excellent produit pour le diy. Comparé à un mini-dsp, il faut un peu plus de patience et de connaissances pour le mettre en oeuvre (interface de programmation, cablage, sigma studio, etc...) mais la carte fille RCA permet de sortir du son rapidement pour tester ses filtres. En simple correction de réponse 2:2, ou en filtrage multi-voies il y a de quoi faire.
Pour ma part j'ai réussi à faire fonctionner 1 sortie i2s stéréo en plus des 3 sorties analogiques disponibles, en raccordant un petit DAC PCM5102 . Le son est clairement meilleur sur le DAC externe. Il me reste beaucoup de choses à expérimenter : entrée i2s, configuration de potentiometres ou encodeurs rotatifs pour modifier en live des parametres (volume, preset de filtres..) du DSP , plusieurs sorties i2s simultanées, test en 96kHz, etc... Pour le prix c'est parfait. Merci à audiophonics pour la mise à disposition d'explications de démarrage claires dans le blog.
Parfait
Module DSP "facilement" configurable grâce au logiciel SigmaStudio, l'exemple mis à disposition dans l'onglet téléchargement du module de programmation permet de le programmer simplement.
Pour information la sortie subwoofer est sur le DAC03
