Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Daniel W.
Connecteur
J'ai envoyé une photo et...
Moyen
Elle se retourne en...
Giacomo P.
No for me
Absolutely no!
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 12010
    In Stock
    Metal foil coils are physically the best designed. The output quality is constant up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 12008
    In Stock
    53,90 € 44,92 €Ex.
    In Stock
  • Ref : 12012
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 12013
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 12011
    In Stock
    67,90 € 56,58 €Ex.
    In Stock
  • Ref : 12014
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 11979
    In Stock
    99,90 € 83,25 €Ex.
    In Stock
  • 109,90 € 91,58 €Ex.
    In Stock
  • Ref : 12016
    119,90 € 99,92 €Ex.
    In Stock
  • Ref : 3832
    This new range of Zero-Ohm coils combines a hand-tuned Feron core with the extreme conductivity of a Copper ribbon. This technique allows to reach a very good pulse reproduction thanks to a very low internal impedance.
    157,90 € 131,58 €Ex.
    In Stock
  • Ref : 3833
    161,90 € 134,92 €Ex.
    In Stock
  • Ref : 3834
    In Stock
    166,90 € 139,08 €Ex.
    In Stock
  • Ref : 3835
    In Stock
    170,90 € 142,42 €Ex.
    In Stock
  • Ref : 3836
    175,90 € 146,58 €Ex.
    In Stock
  • Ref : 3823
    82,90 € 69,08 €Ex.
    In Stock
  • Ref : 3825
    In Stock
    86,90 € 72,42 €Ex.
    In Stock
  • Ref : 3826
    In Stock
    88,90 € 74,08 €Ex.
    In Stock
  • Ref : 3824
    84,90 € 70,75 €Ex.
    In Stock
  • Ref : 3827
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 3829
    In Stock
    121,90 € 101,58 €Ex.
    In Stock
  • Ref : 4271
    In Stock
    Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost reasons, as they are generally much more compact than their film counterparts. In particular, they are widely used in crossover filters.
    4,90 € 4,08 €Ex.
    In Stock
  • Ref : 4263
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 4264
    In Stock
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 4265
    In Stock
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 4266
    In Stock
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 4267
    In Stock
    3,40 € 2,83 €Ex.
    In Stock
  • Ref : 4268
    In Stock
    3,40 € 2,83 €Ex.
    In Stock
  • Ref : 4269
    In Stock
    4,10 € 3,42 €Ex.
    In Stock
  • Ref : 4270
    In Stock
    4,90 € 4,08 €Ex.
    In Stock
  • Ref : 4299
    In Stock
    8,90 € 7,42 €Ex.
    In Stock
  • Ref : 4294
    In Stock
    4,10 € 3,42 €Ex.
    In Stock
  • Ref : 4302
    In Stock
    3,40 € 2,83 €Ex.
    In Stock
  • Ref : 4295
    In Stock
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 4296
    In Stock
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 4292
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 4298
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 16230
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 5675
    In Stock
    The F-Series combines small size and low price, making it an excellent value for money for filtering woofers, or any other application requiring high inductance and/or low resistance in a small volume.
    14,30 € 11,92 €Ex.
    In Stock
  • Ref : 5659
    In Stock
    8,90 € 7,42 €Ex.
    In Stock
