Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Yves F.
Marvelous DAC
Ma configuration : Denon PMA 3000NE, streamer dmp a6 master edition gen 2 + dac holo cyan 2 (connection en USB : câble Black...
Raymond L.
Service Clientèle c'est une sans faute et en plus !
Sans parler de cet achat, le service clientèle est parfait avec une aide qui ne pousse pas à acheter plus et plus cher....
Luca R.
Excellent distributeur électrique
Avec ce prix, vous ne pouvez pas demander plus , ici nous avons :
· Un beau châssis entièrement en aluminium noir.
· 5...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 5673
    In Stock
    The F-Series combines small size and low price, making it an excellent value for money for filtering woofers, or any other application requiring high inductance and/or low resistance in a small volume.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 5674
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 5672
    In Stock
    8,00 € 6,67 €Ex.
    In Stock
  • Ref : 4233
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low internal impedance and zero...
    5,20 € 4,33 €Ex.
    In Stock
  • Ref : 4235
    In Stock
    5,50 € 4,58 €Ex.
    In Stock
  • Ref : 3415
    In Stock
    5,80 € 4,83 €Ex.
    In Stock
  • Ref : 4232
    In Stock
    4,90 € 4,08 €Ex.
    In Stock
  • Ref : 4234
    In Stock
    6,10 € 5,08 €Ex.
    In Stock
  • Ref : 4236
    6,40 € 5,33 €Ex.
    In Stock
  • Ref : 4237
    In Stock
    6,70 € 5,58 €Ex.
    In Stock
  • Ref : 4238
    In Stock
    7,00 € 5,83 €Ex.
    In Stock
  • Ref : 4239
    In Stock
    7,30 € 6,08 €Ex.
    In Stock
  • Ref : 4240
    In Stock
    7,60 € 6,33 €Ex.
    In Stock
  • Ref : 4241
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 4242
    In Stock
    8,30 € 6,92 €Ex.
    In Stock
  • Ref : 4244
    In Stock
    9,30 € 7,75 €Ex.
    In Stock
  • Ref : 4245
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 4246
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 4257
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 4258
    In Stock
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 4259
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 4260
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 4243
    In Stock
    8,70 € 7,25 €Ex.
    In Stock
  • Ref : 4248
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 4249
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4261
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 4262
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4247
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 4251
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4252
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 4250
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 4253
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 4254
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 4255
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4256
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 4540
    In Stock
    7,10 € 5,92 €Ex.
    In Stock
  • Ref : 4541
    In Stock
    7,50 € 6,25 €Ex.
    In Stock
  • Ref : 4542
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 4539
    In Stock
    6,70 € 5,58 €Ex.
    In Stock
  • Ref : 4543
    In Stock
    8,30 € 6,92 €Ex.
    In Stock
