Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Color
Electronic components
André G.
Câble secteur au top
Ayant testé de ombreux câbles secteur de moyen et haut de gamme, le câble Audiophonics répond à mes attentes après avoir écouté...
Marco R.
AUDIOPHONICS LPA-S450ET
È da qualche giorno che ho questo finale di potenza, ma devo dire che,quanto già scritto da altre persone sulla qualità...
David S.
impeccable
Exactement la bonne dimension, identique à ceux endommagés sur mon...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 4554
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low internal impedance and zero...
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4565
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 4566
    In Stock
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 4567
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 4551
    In Stock
    14,50 € 12,08 €Ex.
    In Stock
  • Ref : 4556
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 4557
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 4555
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 4559
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 4560
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 4558
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 4561
    In Stock
    31,00 € 25,83 €Ex.
    In Stock
  • Ref : 4562
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 4563
    In Stock
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 4564
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 1646
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 1645
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 1648
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 1647
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 1649
    In Stock
    13,50 € 11,25 €Ex.
    In Stock
  • Ref : 1650
    In Stock
    14,50 € 12,08 €Ex.
    In Stock
  • Ref : 1651
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 1652
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 1653
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 1654
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 1655
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 1656
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 1658
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 1659
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 1660
    In Stock
    36,90 € 30,75 €Ex.
    In Stock
  • Ref : 1669
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 1670
    In Stock
    63,90 € 53,25 €Ex.
    In Stock
  • Ref : 1657
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 1661
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 1662
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 4574
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 1663
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 1664
    In Stock
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 4575
    In Stock
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 1665
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
