Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Baptiste B.
Le mouton à 5 pates :)
A la recherche d'un DAC et d'un préamplificateur, j'avais acquis un ZP3, qui associé à un amplificateur...
Antonio C.
Amazing device
I recently purchased the Eversolo T8 and have been thoroughly impressed with its performance. When paired with my Denafrips...
sven m.
A real asset for the Buchardt Audio P300
Fast delivery and smaller than expected. So far, everything looks great and sounds fantastic. Thanks Audiophonics.
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 4247
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low internal impedance and zero...
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 4251
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4252
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 4250
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 4253
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 4254
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 4255
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4256
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 4540
    In Stock
    7,10 € 5,92 €Ex.
    In Stock
  • Ref : 4541
    In Stock
    7,50 € 6,25 €Ex.
    In Stock
  • Ref : 4542
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 4539
    In Stock
    6,70 € 5,58 €Ex.
    In Stock
  • Ref : 4543
    In Stock
    8,30 € 6,92 €Ex.
    In Stock
  • Ref : 4544
    In Stock
    8,70 € 7,25 €Ex.
    In Stock
  • Ref : 4545
    In Stock
    9,10 € 7,58 €Ex.
    In Stock
  • Ref : 4546
    In Stock
    9,50 € 7,92 €Ex.
    In Stock
  • Ref : 4547
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 4548
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 4549
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 4550
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4552
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 4553
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 4554
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4565
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4566
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 4567
    In Stock
    56,90 € 47,42 €Ex.
    In Stock
  • Ref : 4551
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4556
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 4557
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 4555
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 4559
    In Stock
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 4560
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 4558
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 4561
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 4562
    In Stock
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 4563
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 4564
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 1646
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 1645
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 1648
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
