Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Pascal H.
Marc C.
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 10787
    In Stock
    Since 2015, the MCap Supreme EVO SilverGold capacitors have been the undisputed top-of-the-line product from Mundorf. It combines all of the brand's technical strengths, such as SilverGold metallization, SUPREME and EVOLUTION winding technology and more than 30 years of experience in the manufacture of capacitors for incredible musicality.
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 10789
    In Stock
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 10790
    In Stock
    53,90 € 44,92 €Ex.
    In Stock
  • Ref : 10791
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 10792
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 10785
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 10794
    In Stock
    Since 2015, the MCap Supreme EVO SilverGold and MCap Supreme EVO SilverGold OIL capacitors have been the undisputed top-of-the-line products from Mundorf. It combines all of the brand's technical strengths, such as SilverGold metallization, SUPREME and EVOLUTION winding technology, and more than 30 years of experience in manufacturing capacitors that...
    79,00 € 65,83 €Ex.
    In Stock
  • Ref : 10793
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 10811
    629,00 € 524,17 €Ex.
    In Stock
  • Ref : 10812
    In Stock
    529,00 € 440,83 €Ex.
    In Stock
  • Ref : 10810
    In Stock
    359,00 € 299,17 €Ex.
    In Stock
  • Ref : 10808
    219,00 € 182,50 €Ex.
    In Stock
  • Ref : 10795
    In Stock
    109,00 € 90,83 €Ex.
    In Stock
  • Ref : 10797
    In Stock
    96,00 € 80,00 €Ex.
    In Stock
  • Ref : 10798
    In Stock
    129,90 € 108,25 €Ex.
    In Stock
  • Ref : 10799
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 10800
    In Stock
    120,00 € 100,00 €Ex.
    In Stock
  • Ref : 10801
    119,00 € 99,17 €Ex.
    In Stock
  • Ref : 10803
    136,00 € 113,33 €Ex.
    In Stock
  • Ref : 10804
    144,00 € 120,00 €Ex.
    In Stock
  • Ref : 10805
    In Stock
    205,90 € 171,58 €Ex.
    In Stock
  • Ref : 10806
    163,00 € 135,83 €Ex.
    In Stock
  • Ref : 10807
    In Stock
    195,00 € 162,50 €Ex.
    In Stock
  • Ref : 1770
    In Stock
    Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor coating and the winding is impregnated with a special oil.
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 1776
    In Stock
    Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor coating and the winding is impregnated with a special oil that has been developed through extensive testing and listening.
    34,90 € 29,08 €Ex.
    In Stock
  • 39,90 € 33,25 €Ex.
    In Stock
  • Ref : 1779
    In Stock
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 1780
    In Stock
    65,90 € 54,92 €Ex.
    In Stock
  • Ref : 1782
    In Stock
    56,90 € 47,42 €Ex.
    In Stock
  • Ref : 1785
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 1784
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 1787
    109,00 € 90,83 €Ex.
    In Stock
  • Ref : 1789
    In Stock
    In Stock
  • Ref : 1790
    In Stock
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 1791
    In Stock
    205,00 € 170,83 €Ex.
    In Stock
  • Ref : 1792
    In Stock
    209,00 € 174,17 €Ex.
    In Stock
  • Ref : 1793
    In Stock
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 2181
    In Stock
    The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 2174
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 2182
    31,50 € 26,25 €Ex.
    In Stock
