Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Adam K.
Holo Cyan 2 - wysyłka do Polski
Na początku kilka słów o samym zakupie. DAC został bardzo szybko wysłany, był dobrze zabezpieczony i dotarł bez żadnych...
Francois P.
J'ai associé ce préampli avec l'ampli de puissance AUDIOPHONICS LPA-S450ET et j'avoue que je suis séduit par le...
dominique w.
Qualité apparente des connecteurs. Câble trés souple. Permet avant tout de profiter des bénéfices d'une liaison symétrique...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 16061
    In Stock
    The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer details and a much better spatialization.
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4072
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4073
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4074
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 16109
    The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors.
    16,10 € 13,42 €Ex.
    In Stock
  • Ref : 16113
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16114
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16115
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16116
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16122
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16123
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16124
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16125
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16134
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16136
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16137
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16126
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16127
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16138
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16143
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16128
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16129
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16140
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16141
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 16130
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16142
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 16131
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16132
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16133
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 1696
    The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
    154,90 € 129,08 €Ex.
    In Stock
  • Ref : 1695
    159,90 € 133,25 €Ex.
    In Stock
  • Ref : 1697
    In Stock
    he Zero Ohm Coil (ZOC) is a transformer format coil. It is made of FERON, a high quality material that limits distortion to a minimum.
    164,90 € 137,42 €Ex.
    In Stock
  • Ref : 1707
    In Stock
    339,90 € 283,25 €Ex.
    In Stock
  • Ref : 1708
    In Stock
    359,90 € 299,92 €Ex.
    In Stock
  • Ref : 1709
    In Stock
    379,90 € 316,58 €Ex.
    In Stock
  • Ref : 1710
    399,90 € 333,25 €Ex.
    In Stock
  • Ref : 1694
    149,90 € 124,92 €Ex.
    In Stock
  • Ref : 1698
    169,90 € 141,58 €Ex.
    In Stock
  • Ref : 1699
    189,90 € 158,25 €Ex.
    In Stock
  • Ref : 1701
    199,90 € 166,58 €Ex.
    In Stock
