Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Barco V.
Trigger 12v
Barco V.
Pavel V.
Very good streamer
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 3661
    In Stock
    The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity.
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 3670
    In Stock
    329,90 € 274,92 €Ex.
    In Stock
  • Ref : 3660
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 3662
    119,90 € 99,92 €Ex.
    In Stock
  • Ref : 3664
    In Stock
    139,90 € 116,58 €Ex.
    In Stock
  • Ref : 3665
    In Stock
    159,90 € 133,25 €Ex.
    In Stock
  • Ref : 3666
    In Stock
    189,90 € 158,25 €Ex.
    In Stock
  • Ref : 3668
    In Stock
    269,90 € 224,92 €Ex.
    In Stock
  • Ref : 3669
    In Stock
    151,90 € 126,58 €Ex.
    In Stock
  • Ref : 3667
    219,90 € 183,25 €Ex.
    In Stock
  • Ref : 2035
    In Stock
    These capacitors combine high dielectric strength with low residual inductance. They have been developed to offer a high quality alternative to high voltage electrochemical capacitors and are therefore ideal for use in tube amplifiers.
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 2031
    In Stock
    129,90 € 108,25 €Ex.
    In Stock
  • Ref : 2030
    In Stock
    In Stock
  • Ref : 2033
    In Stock
    42,90 € 35,75 €Ex.
    In Stock
  • Ref : 2032
    In Stock
    53,90 € 44,92 €Ex.
    In Stock
  • Ref : 2034
    In Stock
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 20371
    In Stock
    The Mundorf VL250 coil is constructed in solid copper according to design specifications specially developed to enhance audio quality in a loudspeaker crossover context. This format belongs to the Mundorf family of high-fidelity components, and is used in professional studios.
    122,90 € 102,42 €Ex.
    In Stock
  • Ref : 21135
    This Mundorf VL300 coil is build from massive copper wires specially developed to help improve the audio quality when it comes to speaker filtering. This format belongs to Mundorf 's family of high-fidelity components the series of which is made for professional studio use.
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 21134
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 21133
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 21136
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 21137
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 21138
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 21139
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 21140
    109,90 € 91,58 €Ex.
    In Stock
  • Ref : 21141
    124,90 € 104,08 €Ex.
    In Stock
  • Ref : 21142
    In Stock
  • Ref : 21143
    In Stock
  • Ref : 15201
    In Stock
    199,90 € 166,58 €Ex.
    In Stock
  • Ref : 21145
    This Mundorf VL300 coil is build from OFC copper wires specially developed to help improve the audio quality when it comes to speaker filtering. This format belongs to Mundorf 's family of high-fidelity components the series of which is made for professional studio use.
    In Stock
  • Ref : 21146
    249,90 € 208,25 €Ex.
    In Stock
  • Ref : 21154
    659,90 € 549,92 €Ex.
    In Stock
  • Ref : 21155
    749,90 € 624,92 €Ex.
    In Stock
  • Ref : 21156
    849,90 € 708,25 €Ex.
    In Stock
  • Ref : 21144
    179,90 € 149,92 €Ex.
    In Stock
  • Ref : 21147
    279,90 € 233,25 €Ex.
    In Stock
  • Ref : 21148
    314,90 € 262,42 €Ex.
    In Stock
  • Ref : 21132
    349,90 € 291,58 €Ex.
    In Stock
  • Ref : 21149
    389,90 € 324,92 €Ex.
    In Stock
  • Ref : 21150
    429,90 € 358,25 €Ex.
    In Stock
