Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
yoan R.
Passé d'un ampli cambridge de 20 ans, qui chauffait, à lui, qui chauffe aussi. Mais la séparation des basses, m'a...
yoan R.
Premier ampli R2R, et je voulais pas casser mon PEL pour gouter a cette techno. Ca fait plus de 6 mois que je l'ai, et...
Xavier B.
Objectivement excellent rapport qualité prix, Très bon résultat "out of the box" chez moi avec un ampli de puissance...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 3667
    The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity.
    219,90 € 183,25 €Ex.
    In Stock
  • Ref : 2035
    These capacitors combine high dielectric strength with low residual inductance. They have been developed to offer a high quality alternative to high voltage electrochemical capacitors and are therefore ideal for use in tube amplifiers.
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 2031
    In Stock
    129,90 € 108,25 €Ex.
    In Stock
  • Ref : 2030
    In Stock
    In Stock
  • Ref : 2033
    42,90 € 35,75 €Ex.
    In Stock
  • Ref : 2032
    In Stock
    53,90 € 44,92 €Ex.
    In Stock
  • Ref : 2034
    In Stock
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 20371
    In Stock
    The Mundorf VL250 coil is constructed in solid copper according to design specifications specially developed to enhance audio quality in a loudspeaker crossover context. This format belongs to the Mundorf family of high-fidelity components, and is used in professional studios.
    122,90 € 102,42 €Ex.
    In Stock
  • Ref : 21135
    This Mundorf VL300 coil is build from massive copper wires specially developed to help improve the audio quality when it comes to speaker filtering. This format belongs to Mundorf 's family of high-fidelity components the series of which is made for professional studio use.
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 21134
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 21133
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 21136
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 21137
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 21138
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 21139
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 21140
    109,90 € 91,58 €Ex.
    In Stock
  • Ref : 21141
    124,90 € 104,08 €Ex.
    In Stock
  • Ref : 21142
    139,90 € 116,58 €Ex.
    In Stock
  • Ref : 21143
    159,90 € 133,25 €Ex.
    In Stock
  • Ref : 15201
    In Stock
    199,90 € 166,58 €Ex.
    In Stock
  • Ref : 21145
    This Mundorf VL300 coil is build from OFC copper wires specially developed to help improve the audio quality when it comes to speaker filtering. This format belongs to Mundorf 's family of high-fidelity components the series of which is made for professional studio use.
    In Stock
  • Ref : 21146
    249,90 € 208,25 €Ex.
    In Stock
  • Ref : 21154
    659,90 € 549,92 €Ex.
    In Stock
  • Ref : 21155
    749,90 € 624,92 €Ex.
    In Stock
  • Ref : 21156
    849,90 € 708,25 €Ex.
    In Stock
  • Ref : 21144
    179,90 € 149,92 €Ex.
    In Stock
  • Ref : 21147
    279,90 € 233,25 €Ex.
    In Stock
  • Ref : 21148
    314,90 € 262,42 €Ex.
    In Stock
  • Ref : 21132
    349,90 € 291,58 €Ex.
    In Stock
  • Ref : 21149
    389,90 € 324,92 €Ex.
    In Stock
  • Ref : 21150
    429,90 € 358,25 €Ex.
    In Stock
  • Ref : 21151
    469,90 € 391,58 €Ex.
    In Stock
  • Ref : 21152
    519,90 € 433,25 €Ex.
    In Stock
  • Ref : 21153
    579,90 € 483,25 €Ex.
    In Stock
  • Ref : 19879
    In Stock
    The Zero Ohm Coil (ZOC) is a transformer format coil. It is made of Feron, a material with high electronic qualities that minimizes induced distortions.
    In Stock
  • Ref : 18899
    In Stock
  • 359,90 € 299,92 €Ex.
    In Stock
  • Ref : 18900
    189,90 € 158,25 €Ex.
    In Stock
  • Ref : 17323
    299,90 € 249,92 €Ex.
    In Stock
  • Ref : 18127
    The Mundorf VN390 Zero Ohm Coil (ZOC) is a transformer format coil. It is made of Feron, a material with high electronic qualities that minimizes induced distortions.
    239,90 € 199,92 €Ex.
    In Stock
