GAE Potentiometer with ON/OFF Rotary Switch 500K 250V 4A
Reference : 6671
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 10-06-2026.
GAE potentiometer with ON / OFF
Linear potentiometer 500k - Rotary Switch Bistable 250V / 4A
Replacement potentiometer / switch for amplifier or other devices that require repair or upgrade. Model approved 4A250V VDE / UL / CSA.
This potentiometer is designed to control a microcontroller, not to receive an audio signal directly. The three main soldering points on the side control the track. The two soldering points at the rear correspond to the switch.
Maximum power4A250V / 8A125V
Resistance500k (linear)
CertificationsVDE / UL / CSA
Global dimensions47 x 30 x 24 mm
Shaft diameter6mm
Drilling diameter8 mm
Shaft length18 mm
ShaftNotched
ChannelN/A
LED ColorN/A
Resistance (Ohm)500000.0
Tolerance (%)N/A
Internal widthN/A
Internal depthN/A
Internal heightN/A
Number of positionsN/A
Button typeN/A
2 reviews
Very good for the right application.
As per title really.
This review has been posted for GAE Potentiometer with ON/OFF Rotary Switch 500K 250V 4A
Tout bon !
Produit conforme, envoyé immédiatement, arrivée comme prévu : un sans faute !
