VIBORG LAN8 Ethernet RJ45 Cable Cat8 Pure Silver Cryo Treatment 1.5m
The Viborg LAN8 RJ45 Ethernet cable is a high-end Ethernet cable with an exceptional design. This cable features 99.998% pure solid silver conductors. The VIBORG LAN8 features a 2000MHz transmission speed and 40Gbps fiber synchronization.
Reference : 19026
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 09-06-2026.
VIBORG LAN8 cable picture
The Viborg LAN8 RJ45 Ethernet cable is a high-end Ethernet cable with an exceptional design. This cable features 99.998% pure solid silver conductors. It also features double shielding with metallic foil and silver-plated copper braid, as well as PTFE insulation. It has been cryogenically treated at -196°C. The cable also features CAT8 network connectors with gold-plated contacts on both sides. The VIBORG LAN8 features a maximum frequency of 2000MHz and a bandwidth of up to 40Gbps.
Overview of VIBORG LAN8 cable structure
Viborg LAN8 cable structure diagram
1Pure solid silver
2PTFE insulation (Teflon)
3Metal foil shielding
4Silver-plated copper braid shielding
5PE sheath
6Braided nylon + PPS
Product typeRJ45 ethernet cable
Connectors2x RJ45
Conductors materialPure solid silver (99.998%)
InsulationPTFE
ShieldingMetal foil + silver-plated copper braid
External sheathPE (Polyéthylène)
Covering sheathNylon + PPS
Length1.5m
Package1x Viborg LAN8 RJ45 ethernet cable
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorRJ45
Conductors material (Cable)Silver
Très large, médium crépitant mais chaud et aigu hyper-soyeux :-o
Installé derrière une box et un isolateur galvanique (iFilter). La connexion source-preampli-ampli est déjà en neotech (argent pur).
La différence de restitution est évidente dès la connexion. L'excellent cable Ethernet cuivre-argent installé avant produisait déjà un son bien solide, pêchu, parfaitement défini et propre, plein et doux. Avec ce viborg, l'impression de retirer un filtre physiologique est déroutante la première heure. Le médium crache une tonalité générale soyeuse sur tout l'aigu (sans distorsion) comme un bruit rose, crépitante sur les voix parlées (radio) et très aérée sur les basses dont la tonalité s'éclaircit en semblant recentrée vers l'infra, Après une journée, reprise du cable cuivre argent et comparaison, l'impression de bruit rose du viborg est atténuée et laisse place à celle d'une réponse en fréquence très linéaire/plate, faisant penser que le cuivre-argent pourrait encore atténuer le médium selon les standards usuels de confort d'écoute, bien que déjà très aéré, clair et complet en comparaison de cuivre standard faisant sourdine. La partie médium-aigue du Viborg coule comme l'eau d'un ruisseau dans les oreilles, définitivement plus présente, jusque dans les graves de fait moins prépondérants, mais clairs et lourds comme du verre blindé? Ce câble ne devrait pas donc convenir à un système de petit volume et puissance, susceptible dans ce cas de rendre l'écoute diaphane et très/trop articulée, manquant de chair, voire douloureuse. Au contraire, sur une installation de dimensions généreuses (Martin audio, Magnepan, Audio research, Krell et autres Pass Lab), l'air qu'il apporte sur tout le spectre, avec les transitoires exceptionnelles sur le médium et la libération d'un soyeux d'une rare douceur sur le haut-medium et l'aigu raviront les oreilles sur tous les enregistrements, de prises des années 60 aux énormes atmosphères de Boris Blank à l'institut Franhofer... Un câble de très haut niveau, très linéaire, sans filtre ni correction, mais qui ne pourra pas convenir pas à tout les systèmes ou toutes les oreilles. Ne conviendra pas sur les systèmes manquant de basses mais jubilatoire sur ceux en disposant généreusement.
This review has been posted for VIBORG LAN8 Ethernet RJ45 Cable Cat8 Pure Silver Cryo Treatment 1.5m
The Viborg LAN8 RJ45 Ethernet cable is a high-end Ethernet cable with an exceptional design. This cable features 99.998% pure solid silver...
