SMSL SA400 Balanced FDA Amplifier 2x STA516B Bluetooth 5.0 2x230W 4 Ohm
SMSL offers with its SA400 an excellent Class D symmetrical amplifier, integrating two STA516B amplification chips capable of developing an important power of 2x 230W under 4Ω. It also has a subwoofer output, allowing to set up a 2.1 audio system. It also benefits from a beautiful design, either by its internal architecture or its sober and modern aesthetic.
By buying this product you get 62 loyalty points
Reference : 15354
629,00 €tax incl.
524,17 € tax excl.
SMSL SA400
Balanced Class D FDA Amplifier 2x STA516B Bluetooth 5.0 2x230W 4 Ohm
SMSL SA400 Amplificateur Class D Symétrique 2x MA12071 Bluetooth 5.0 2x230W 4 Ohm
Bluetooth 5.0
The SA400 benefits from a Bluetooth 5.0 reception, allowing you to broadcast your music at a distance and with great stability. Moreover, it is compatible with the aptX codec, allowing a fast transmission, without latency, for a quality close to that of the CD.
Numerous EQs
The amplifier integrates many predefined equalizers. These will allow you to adapt the sound reproduction according to your listening, your equipment or the genre of your music.
Tone setting
The SMSL SA400 also offers tone controls for bass, midrange and treble, so you can precisely match the sound reproduction to your taste. It is also possible to adjust the level of the subwoofer output for a perfect balance.
High-end components
The SA400's circuitry is packed with high-performance audio components. These include two independent STA516B amplifier chips, a NJW1195 low distortion volume controller, three EQ chips and an excellent LLC power supply with PFC and EMI filtering.
1IR Receiver
2Screen
3LED indicator
4Multi-functions knob
5Balanced input (XLR)
6Single-ended line input (RCA)
7Subwoofer output
8Bluetooth antenna
9Right speaker output
10Left speaker output
11Power connector (100-240V AC)
SMSL SA400 Review by Audio Science Review (Amir)
" SMSL brings us an interesting and unique power amplifier to us. Love the load independence and small packaging plus tons of power. "
Test du SMSL SA400 par Audio Science Review (Amir)
Product typeFull digital Balanced Class D Amplifier
Amplifier chip and controller2x STA516B / 1x AX5689
Inputs1x Balanced XLR
1x Single-ended RCA
Bluetooth
OutputsSpeaker terminals
1x Subwoofer output (RCA)
THD+N0.003%
SNR96dB
Channels separation94dB
Output power2x 230W @ 4Ω
2x 110W @ 8Ω
Consumption50W
Housing materialAluminum
Dimensions210 x 48 x 235mm
Weight1.95kg
Package1x SA400 Black
1x Bluetooth antenna
1x Remote
1x Schuko power cable
InputXLR
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Amplifier chipSTA516B
Power (W)230.0
Remote ControlYes
SMSL offers with its SA400 an excellent Class D symmetrical amplifier, integrating two STA516B amplification chips capable of developing an...
