By buying this product you get 65 loyalty points
The ddHiFi BC130C Eryx earphones able features a high-end design using audiophile-grade materials. It is fitted with a Gold-plated copper 4.4mm balanced jack and a proprietary ddHiFi interchangeable connector system, allowing the user to choose between an MMCX or 0.78mm CIEM connection. The conductors in this cable are a hybrid blend of German OCC and OFC copper, pure silver and gold-plated OCC, for optimal signal transmission and improved signal clarity.
Furthermore, this cable features two layers of internal insulation for effective protection against interference and to reduce noise levels. This is complemented by a rosewood reinforcement combined with a titanium alloy, which absorbs micro-vibrations and reduces distortion to deliver the purest and most precise sound across the entire frequency range.
The ddHiFi BC130C Eryx cable features four 25.0AWG conductors, each made from a hybrid blend of German OFC copper, OCC copper, gold-plated OCC copper and high-purity silver. These characteristics ensure optimal signal transmission. Furthermore, each conductor is individually insulated to preserve the transmission of different frequencies. The cable features PVC insulation with double black braided mesh shielding.
The OFC version of the ddHiFi BC130C Eryx is equipped, as its name suggests, a balanced 4.4mm jack with gold-plated OFC copper contacts from Pentaconn, offering a richer and more refined sound than the original, as well as interchangeable connectors allowing you to choose between MMCX and 0.78mm CIEM. This cable is therefore compatible with the majority of IEMs available on the market. In addition, two versions of 0.78mm CIEM connectors are included:
| Specifications | |
| Product type | Headphone/IEM cable |
| Connectors | 1x 4.4mm balanced Gold-plated jack connector Pentaconn 3x interchangeable connectors (1x MMCX + 2x 0.78mm in-ear monitors) |
| Section | 4x 25.0AWG (4x 0.162mm²) |
| Conductive material | OCC Copper, German OFC Copper, Gold-plated OCC Copper, Pure Silver |
| Insulation | Double SoftPlex PVC (USA) braided in black mesh |
| Accessory | Rosewood combined with titanium alloy components |
| General | |
| Weight | 28g |
| Length | 1.2m |
| Packaging | 1x ddHiFi BC130C Eryx OFC headphone cable 1x Pair of MMCX connectors 2x Pair of 0.78mm in-ear connectors 1x Storage box |
| Length (m) | 1.2 |
| Shielding | No |
| Section (mm²) | 0.16 |
| Connector | CIEM 0.78mm |
| Connector | Jack 4.4mm |
| Connector | MMCX |
| Conductors material (Cable) | Silver |
| Conductors Plating (Cable) | Gold |
