TRN SCALLOP COMBO Bluetooth Receiver for Earphones
The TRN Scallop Combo is a Bluetooth receiver designed to extend the use of wired earphones by adding wireless connectivity, while preserving their original sonic signature. It relies on a Bluetooth 6.0 chip combined with an optimised decoding architecture, enabling stable, low-latency transmission to maintain signal coherence and soundstage integrity.
Reference : 22093
41,91 €tax incl.
34,92 € tax excl.
Shipping date: 24-11-2026.
TRN Scallop Combo Bluetooth 6.0 Receiver for MMCX CIEM 2-pin Type S Earphones
TRN Scallop Combo : Front view
TRN Scallop Combo: Bluetooth 6.0
The Scallop integrates a Bluetooth 6.0 interface, improving transmission stability and interference management, allowing more precise audio synchronisation in latency-sensitive applications such as gaming, video or streaming. This advancement extends to support for AAC and SBC codecs, ensuring broad compatibility while maintaining a balance between reproduction quality and energy efficiency.
TRN Scallop Combo : Bluetooth 6.0 chip
TRN Scallop Combo : Modular connectors
TRN Scallop Combo: Modular Architecture
The Scallop adopts a modular design allowing connector replacement, maintaining compatibility with different in-ear monitor standards. This approach is reflected in the inclusion of MMCX, 2-pin 0.78mm (CIEM) and 2-pin Type S terminations, enabling quick adaptation to the system without modifying the main equipment.
TRN Scallop Combo: Wearing Comfort
The over-ear structure follows the natural contour of the auricle, stabilising the assembly while distributing mechanical stress over time. Combined with a weight of approximately 6 g per side, this design limits fatigue during extended sessions while maintaining a secure fit during active use.
TRN Scallop Combo : in use
TRN Scallop Combo : 700mAh
TRN Scallop Combo: Up to 50 Hours Battery Life
The Scallop delivers up to 10 hours of continuous playback on a single charge, while the 700 mAh charging case extends total battery life to approximately 50 hours, allowing charging cycles to be spread across several days of use. This energy management relies on a low-consumption architecture, ensuring uninterrupted operation without frequent recharging.
TRN Scallop Combo: Moisture Protection
A water-resistant coating protects the internal circuitry against moisture, splashes and perspiration, maintaining operational stability across varied usage conditions. This protection extends system reliability without requiring special precautions in outdoor environments.
TRN Scallop Combo : water resistant
Product typeBluetooth receiver for IEM
ConnectorsMMCX
CIEM
2-pin Type S
Bluetooth version6.0
Supported Bluetooth codecsSBC, AAC
Bluetooth range20m
Battery capacityReceivers: 60mAh
Case: 700mAh
Battery lifeReceivers: 10h
Case: 50h
Charging timeReceivers: 1.5h ~ 2h
Case: 2.5h ~ 3h
ColourBlack
Weight6g per receiver
Package contents1x TRN Scallop Combo
1x Carrying case
1x MMCX termination
1x CIEM termination
1x 2-pin Type S termination
TRN SCALLOP COMBO Bluetooth 6.0 Receiver for MMCX CIEM 2-Pin Type S Earphones
The TRN Scallop Combo is a Bluetooth receiver designed to extend the use of wired earphones by adding wireless connectivity, while preserving their...
