MUSICIAN PEGASUS III DAC R2R Silver
Building on the concept of version II, the Musician Pegasus III is a highly performant R2R DAC based on audiophile-grade components. Like its predecessor, it features a low-noise power supply as well as a FIFO buffer. For signal processing, it integrates an Altera Cyclone IV FPGA, a FIR filter and an STM32F446 interface. This concentration of technology allows it to support ultra-high resolution streams up to PCM up to 32bit 1536kHz and DSD up to DSD1024.
By buying this product you get 135 loyalty points
Reference : 21606
1 359,00 €tax incl.
1 132,50 € tax excl.
Musician Pegasus III Discrete Balanced R2R DAC 32bit 1536kHz DSD1024 Silver
Photo of the MUSICIAN PEGASUS III
The main improvements brought to the Pegasus III include the optimization and enhancement of its R2R architecture, now fully balanced, the addition of high-speed multi-channel digital isolators, and the upgrade of its crystal oscillator with two custom high-precision oscillators for outstanding clock stability.
In terms of connectivity, it retains a complete range of digital inputs including USB-B, I2S via HDMI, optical Toslink, coaxial and AES/EBU. For signal output, classic analog RCA and balanced XLR outputs are available.
Advantages of the MUSICIAN PEGASUS III
Musician Pegasus III: High-performance balanced R2R DAC with dedicated DSD architecture
The fully balanced R2R circuit is built using 0.005% high-precision resistors for accurate digital-to-analog conversion. Furthermore, this architecture allows processing of high-resolution sampling rates up to PCM 32bit 1536kHz and DSD1024.
MUSICIAN PEGASUS III : high-performance balanced R2R DAC with dedicated DSD architecture
MUSICIAN PEGASUS III : Custom TCXO crystal oscillator
Musician Pegasus III: Custom TCXO crystal oscillators
The Musician Pegasus III is equipped with two custom TCXO clocks supporting its FPGA chip. These new crystal oscillators provide excellent clock stability, allowing the Pegasus III to handle numerous sampling rates.
Overview of the Musician Pegasus III connectivity
Overview of the Musician PEGASUS III connectivity
1Input selection
2Power button
3NOS button
4Single-ended RCA output
5Balanced XLR output
6I2S input via HDMI
7Coaxial input
8Optical Toslink input
9AES/EBU input
10USB-B input
11IEC power input
It is not recommended to use XLR and RCA outputs simultaneously, as they share the same circuitry.
I2S pinout configuration
To ensure compatibility with most devices, the Musician Pegasus offers several I2S pinout configurations. To change this setting, follow the steps below:
  1. Select the I2S input.
  2. Press and hold the NOS button for 3 seconds until the I2S indicator starts blinking.
  3. Press the NOS button again to change the I2S mode.
  4. Once the correct mode is selected, the device confirms the setting and automatically exits the configuration mode.
I2S PIN OUT configuration PEGASUS III
If the setting does not provide satisfactory sound (for example if a whistling noise is heard), this should not be considered a device malfunction but simply an incompatibility. The recommended solution is to use a custom HDMI cable adapted to the pinout of your source device and the Pegasus.
Technical specifications
Product typeR2R DAC
Inputs1x USB-B
1x Coaxial
1x Optical Toslink
1x AES/EBU
1x I2S via HDMI LVDS
Outputs1x Single-ended RCA
1x Balanced XLR
Supported sampling ratesUSB: PCM up to 32bit 1536kHz, DSD up to DSD1024, DSD DoP64
I2S: PCM up to 32bit 768kHz, DSD up to DSD1024, DSD DoP64
Optical Toslink, coaxial, AES/EBU: PCM up to 24bit 192kHz, DSD DoP up to DSD64
Frequency response10Hz - 75kHz (+1/-3dB)
THD+N< 0.002% (A-Weighted)
SNR≥ 120dB (A-Weighted)
Dynamic range≥ 121dB
Crosstalk≥ 110dB
Output levelsRCA: 2Vrms
XLR: 4Vrms
Operating modeNOS/OS
Power supply115V/60Hz, 230V/50Hz (Auto switch)
Power consumption≤ 20W
Dimensions280 x 250 x 50mm
Weight3.9kg
ColorSilver
Package1x Musician Pegasus III
1x IR remote control
1x Power cable
I2S Pinout
PINMode 1Mode 2Mode 3Mode 4Mode 5Mode 6Mode 7Mode 8
1DATA-DATA-DATA+DATA+DATA-DATA-DATA+DATA+
3DATA+DATA+DATA-DATA-DATA+DATA+DATA-DATA-
4BCK-BCK-BCK-BCK-BCK+BCK+BCK+BCK+
6BCK+BCK+BCK+BCK+BCK-BCK-BCK-BCK-
7LRCK-LRCK+LRCK-LRCK+LRCK-LRCK+LRCK-LRCK+
9LRCK+LRCK-LRCK+LRCK-LRCK+LRCK-LRCK+LRCK-
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate1536kHz
ColorSilver
Remote ControlYes
MUSICIAN PEGASUS III DAC R2R Discrete Balanced 32bit 1536 kHz DSD1024 Silver
Building on the concept of version II, the Musician Pegasus III is a highly performant R2R DAC based on audiophile-grade components. Like its...
