AUDIOPHONICS LPSU25 Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA
4.9 / 5
Reference : 11364
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 16-09-2025.
Linear Power Supply
Low noise USB 5V 2A 25VA / 220V
audiophonics linear regulated power supply
Audiophile regulated power supply for any Hifi device running on 5V (DAC, digital sources for example).
Here is a regulated and stable linear power supply for any high quality DIY audiophile project. All the necessary technical refinements are incorporated into this dedicated audio power supply.
It includes a Hexfet IRF controller of series 34Z driven by low-noise OP Analog-Device and not an integrated circuit. The incorporated EMI RFI filtering ensures a very low noise (ripple) of electrical pollution (- of 30mv).
The components of this power supply are of first quality with DALE resistors and 4 capacitors of filtering BC of 220μf each. A fuse F0.25A 250V ensures the protection of the device.  The benefits of a linear quality feed are better readability of the acute medium and a much better cut out.
This regulated linear power solution developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two DC 5.5 / 2.1mm output jacks, this power supply with an extremely stable 25VA transformer even under heavy load will allow you to make the best of audio connected.
As this power supply do not have over current protection, the load should not exceed it's capacity.
For use with a RaspTouch: If a yellow flash appears on the screen, you can adjust the output voltage of the power supply using the screw on the back of the unit until the flash disappears.
AC Power cable sold separately.
Input voltageAC 220V
Output Voltage / current5V 2.0A MAX Continuous
5V 3.5A DC (5 min)
OutputsJack DC 5.5/2.1mm
2x USB-A 5V
InputIEC
Vibration-proof molded transformer 25VA shielded-
Internal fuse0.5A Fast
Case material100% Brushed & Sandblasted Aluminium
AnodisingYes
Dimensions174 x 100 x 51mm
Weight0.85kg
DC 5.5/2.1 jack cord and mains cable not included.
Audiophonics alimentation linéaire régulée
Presentation of the linear power supply regulated by
The Hans Beekhuyzen Channel
We recommend for the ALLO DIGIONE this
Power supply
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)5.0
Output current (A)2.0
Input voltage (V)230.0
Power SupplyLinear
56 reviews
Excellent avec Ifi Audio LAN ipurifier Pro
Utilisée sur un filtre Ifi Audio LAN iPurifier Pro, cette alimentation linéaire transcende le produit !
Meilleure aération et surtout disparition complète de la dureté dans le haut médium et des sibilances qui sont très présentes avec l'alimentation à découpage d'origine.
Pour ceux qui ont un LAN iPurifier Pro, je vous recommande absolument d'essayer avec cette alimentation !
This review has been posted for AUDIOPHONICS LPSU25 Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA
un son meilleur sur toutes les fréquences
J'ai longuement réfléchi avant l 'achat pour upgrader mon wiim pro plus ,foncé car cette alimentation vaut vraiment le coup .Un câble neotech nep 3003 G lui convient a merveille et MERCI a audiophonics de leur livraison rapide
Une révélation
Avec l’alimentation AUDIOPHONICS LPSU25 branchée sur mon streamer Wiim Pro Plus, le bond en qualité sonore est immédiat. La musique gagne en impact, en précision et en naturel — chaque note est plus vivante, plus juste, plus intense
Une révélation
Rapport qualité prix imbattable
Après 2 semaines d'utilisation je dois avouer que le changement a été immédiatement perçu, cette alimentation linéaire alimente un Octavio Stream, branché sur un Onkyo TX-rz 50 et enceintes Klipsch rp-8000f.
Dès les premières secondes d écoute, on ressent la différence surtout à mi-volume, un son aéré avec plus de détails et de précision sur les instruments.
Cette alimentation est le produit le moins cher de mon installation complète mais sans aucun doute là ou j ai été le plus bluffé par la qualité du son.
Merci à Audiophonics de m'avoir proposé un tel produit pour un prix défiant toute concurrence
